Handle Repair/Replacement Cost?
Discussion in '1st Gen. Tacomas (1995-2004)' started by shweezytime, Jul 21, 2022.
  1. Jul 21, 2022 at 11:55 AM
    shweezytime
    shweezytime [OP] New Member
    Troy
    1999 4x4 SR5 V6
    My driver's side door handle has been acting up and would occasionally lock the door when I tried to open it. I was planning to replace the handle soon, but hadn't gotten around to it yet.
    Took my 99 in to the shop to get the AC fixed and asked them to take a peak at the door as well while they had it.
    Turns out the cost to fix and replace the handle + locking mechanism is $680 total after labor...
    Not much I can do about it now, but seems like a pretty high cost for this type of work.
    Am I getting raked over the coals or is this cost expected?
    ztwatson likes this.
  2. Jul 21, 2022 at 11:57 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Takes about 2 minutes to pull the door handle off with a screw driver.
    There are little plastic clips that clip onto the rod/locking mechanism.
    A youtube video will show you how quick and easy it is to check it out.
  3. Jul 21, 2022 at 12:58 PM
    manapiko
    manapiko Well-Known Member
    Patrick
    Lynnwood, WA
    2003 Tacoma TRD
  4. Jul 21, 2022 at 12:59 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    You could probably find a whole door for that much.
    DK117 likes this.
  5. Jul 21, 2022 at 3:49 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Portland, Oregon
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
  6. Jul 22, 2022 at 10:30 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    $680 for a door handle and a lock?! That must be for the entire mechanism from inner handle to outer lock. Its still a ripoff. The handles are about $40/pair and the locks are about the same. This job takes a flathead screwdriver, a phillips screwdriver, and a 10mm (I think) socket wrench w/extension. Total repair time about 1.5 hrs if you've never done it before and half that with experience. I would never pay $680 for such a simple job.
  7. Jul 22, 2022 at 10:58 AM
    Cucvfan
    Cucvfan Well-Known Member
    Don't forget the shop owner has to charge for "shop supplies ".GUEST_d6c6a7f3-02b5-42bb-94c6-21e874e99395.jpg
  8. Jul 22, 2022 at 11:45 AM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    Shop owners when they get inexperienced drivers:
