Hand Winch?
Discussion in 'Recovery' started by Carpedm, Sep 1, 2023.
  1. Sep 1, 2023 at 8:43 AM
    Carpedm
    Carpedm [OP] Well-Known Member
    Annapolis MD
    2023 Lunar Rock TRD Sport DC SB
    Cup Holder Mod, bed cover, and steps.
    Anyone have a hand-operated winch they recommend? I don't want to add a lot of weight in the form of a bumper up front but I would like a recovery option! I plan to tow a camper and a hand winch seems like something I could use to get out of many sticky situations!
  2. Sep 1, 2023 at 8:46 AM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Carpedm[OP] likes this.
  3. Sep 1, 2023 at 9:34 AM
    Carpedm
    Annapolis MD
    Interesting take. I guess I am looking at it more of a (Oh Crap) than being a true off roader that would need it often! Thoughts to think through!
  4. Sep 1, 2023 at 9:45 AM
    t1m829
    t1m829 Well-Known Member
    RVA
    2012 Silver Access Cab 4x4 I4 MT
    One can use a hi-lift jack in the same capacity as one of these come-alongs. Just need to attach some static recovery ropes between your truck, the jack, and something sturdy (please use a tree saver) and start cranking. I'd recommend any quality brand 60in hi-lift. Plus you get the added bonus of having a spare jack. Just please don't store this thing on the outside of your truck, keep it in the bed or something unless you want it stolen. Same goes for traction boards and whatever other recovery gear you may need.
    Speedbird likes this.
  5. Sep 1, 2023 at 9:53 AM
    Carpedm
    Annapolis MD
    Nice plan, I like the dual use aspect. I happen to know one of the guys who started Deadman Offroad ( https://www.deadmanoffroad.com/ ) I could get a decent tree hugger from him!
  6. Sep 1, 2023 at 9:55 AM
    t1m829
    RVA
    Good deal! I'll have to check them out.
    Carpedm[QUOTED][OP] likes this.
  7. Sep 4, 2023 at 12:13 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I think the know How to look and know your going to need help to get out is even better.
    In a emergency I have use 2 or 3 different 2" ratchet straps to self recovery it was a good 8 hours of constant work or longer.
  8. Sep 9, 2023 at 6:37 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    The morepower puller is like an overbuilt come-along. With synthetic line, it's fairly easy to handle (and reduced risk of damage if it snaps under load).
    Actual handwinches that you might actually pull a heavy load without wanting to commit sudoku while using are into the same price range as a decent winch. 4000lb hand winches exist, but theyre not super light, and realistically you're going to need more line (again, going to suggest the expense of synthetic), and several pulleys to reduce the load your winch experiences (and you, by extension).
    And you still need to look at upgrading your recovery points.
    Marc70 likes this.
  9. Sep 15, 2023 at 3:01 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Yes a come along works just get a 4 ton or 8000lb one and realize they only pull 6-8 ft at a time without a reset.
    Easy to pull out from rear also if you hit a deep mud hole.
    Good if sliding sideways on slippery stuff to stop.
    Carry the tree strap and a hardened crowbar or rod for no tree locations and a 4 lb mini sledge.
    I also have a 25' aircraft braided cable with ring and hook to extend. Then of course standard big yellow tow strap if another truck around.
    If you plan on Moab or Ouray rock crawling/trails up stuff that is highly rated a winch would be easier - or not if you use more caution on picking trails and lines.
    Then if deep woods old trails and cutting/dragging trees out a winch is nice. But again how often.
    Then front weight, bumper, and cost. So after many trucks and 40 years I used my come along about 4 times.
    So depends on what you are going to try. But cheap insurance for the unplanned mess you could get in.
  10. Sep 16, 2023 at 7:27 AM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
  11. Sep 17, 2023 at 10:23 AM
    Toy_Runner
    99 4Runner SR5
    Another option is a tirfor wire puller. I have one. I had to use it. It sucks much less than a comealong. But they're pricey.
  12. Sep 17, 2023 at 6:52 PM
    pinem56
    NE
    2018 TRDOR DCSB AT
    I had read you can't run the cable around a pully with a tirfor. I suppose you could use a section of synthetic line in between with a pully though. I looked pretty hard at getting one once, but the size was too much to fit in my bed with other gear.
  13. Sep 18, 2023 at 6:11 AM
    Toy_Runner
    99 4Runner SR5
    Not sure why you couldn't use snatch blocks/pulleys with a tirfor, rigging would be similar to any other comealong pull. Perhaps they say not to for liability reasons, as with enough line and blocks you could move or lift weights greatly outside the ratings of the tirfor. But that could be done with an ATV winch and the same...
  14. Sep 24, 2023 at 11:49 AM
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    ^ On a related note; do not discount the qty and cost of quality rigging... Certainly you do not want unknown quality [imported/Amazon/Horror Freight] in this application... I would dare use only certified kit from a known rigging supplier.
    I ended up spending ~ 2x as much on [MIA] shackles, straps and chain as I did on the Hi-Lift. (An entry level [HF] winch on sale would have been maybe only $100 or $200 more.)
    FWIW: I bought in based on a need taking down a tree in a precarious location with very little margin of error. The $300 ish I spent on the whole kit was half what a tree guy would charge... The job got done and in my head I now have a complete Hi-Lift kit.
    Marc70 and Carpedm[OP] like this.
