hand winch
Discussion in 'Off-Roading & Trails' started by taco06, Aug 23, 2011.
  1. Aug 23, 2011 at 11:03 PM
    taco06
    taco06 [OP] Well-Known Member
    Alex
    pomona ,California
    06 sprt
    I can't let the wife know
    Wondering if any one could recommend a hand winch they have used to get unstuck. I rarely hit trails and just need a winch just in case..
  2. Aug 24, 2011 at 6:56 AM
    ewa2fl
    ewa2fl Taco Jinx...
    Ed
    Wayne Co. 14516
    Tacoma DBLB V6 4x4
    Plati-Dip Badges & Removed a few, added D-rings in Bed, added recovery D-shackle, Added Front Recovery Hook, TRD Skid Plate-Rhinoed, added 2 mini tie downs, removed rear seat headrests.
    Try a High Lift Jack, works as a come-a-long too, google it.
  3. Aug 24, 2011 at 7:18 AM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    I agree w/ using a come-along.
    I'm imagining a hand-winch as what you'd pull a boat onto a trailer with... that thing would be flopping all over when you try to crank on it, unless it's mounted to a hitch or some other hard point. The come-along is pulled taut at each end and you can go back and forth easily instead of trying to stabilize the winch as you go around and around.
  4. Aug 24, 2011 at 7:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Hand winches aren't that difficult to stabilize. The pressure on the line holds them fairly steady. I have an older hand winch but I'm not sure if it's heavy enough to drag out a truck. They have gear reducers so you can be cranking furiously and you're only going to move it an inch a minute. I guess it's better than nothing though...
  5. Aug 24, 2011 at 8:05 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Definitely get a hi-lift jack and make sure you have jacking points on your vehicle and/or the right adapters to hook the jack to the wheels. Getting the vehicle up and out of whatever it's stuck in or on will make the winching job easier.
    Have you considered a small electric winch with several pulley blocks to increase the pulling capacity? Would save you a ton of work and it's nice to have the peace of mind.
    It's all dependent on your budget of course, but you can get a 4500 lb winch, single pulley block, and mount that wraps around your tow ball for around $250.
    http://www.amazon.com/Superwinch-11...YE5U/ref=sr_1_1?ie=UTF8&qid=1314197990&sr=8-1
  6. Aug 24, 2011 at 10:35 AM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Not to sure about ahand winch. Puts you in the line of fire if the line was to break. Manmade is bound to break sometime.
  7. Aug 24, 2011 at 10:53 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    My old man always kept a come a long in his truck tool box. It saved us a couple of times out in BFE. he has only ever owned 2wd trucks and has covered hundreds and hundreds of miles out in the middle of no where hunting and fishing. When a good line and lots of momentum wont get you through its good to have something for back up!
    Any tractor supply store should sell a good come a long. Just make sure and have a long enough recovery strap in case there arent any trees realy close :D
  8. Aug 24, 2011 at 10:56 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  9. Aug 24, 2011 at 11:06 AM
    socal4x
    socal4x Well-Known Member
    CA
    '16 MGM DCSB OR 4x4 6MT
    You might need more cable? Experts chime in. I guess it depends on distance to attachment point.
    ARB makes a hand winch, but its probably $$$.
    If you go with the hilift, practice with it before you get stuck so you will know what it takes, what accessories to have on hand.
  10. Aug 24, 2011 at 11:20 AM
    horwitzs
    Seth
    Dayton, WA
    TX Pro
    ^^^ Good find, I think I'm going to jump on that!
  11. Aug 24, 2011 at 11:35 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I would replace the cable with a synthetic line and also keep a normal 20'-30' recovery strap in the truck as well. Every vehicle should have a recovery strap regardless though :cool:.
  12. Aug 24, 2011 at 1:02 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Yes, this. You can also use the tow strap to extend the reach of your winch cable if needed...
  13. Aug 24, 2011 at 1:13 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    yup. I keep a recovery strap and two 10' chains for bak up if I need more length or dont want to tear up my strap
  14. Aug 24, 2011 at 1:29 PM
    mjp2
    NJ
    The free shipping makes it a no-brainer if you're an Amazon Prime member. :)
  15. Aug 24, 2011 at 1:32 PM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
  16. Aug 24, 2011 at 1:42 PM
    mjp2
    NJ
    ^ $200 for a hand winch? :eek:
  17. Aug 24, 2011 at 1:49 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    geez. I wouldnt pay more than like $50 for a hand winch
  18. Aug 24, 2011 at 2:00 PM
    jbrandt
    Justin
    Another $100 and you can push a button to winch yourself out...
    KRUD likes this.
  19. Aug 24, 2011 at 2:05 PM
    mjp2
    NJ
    For the same money, actually. See my post above with the link to Amazon.
  20. Aug 24, 2011 at 2:11 PM
    jbrandt
    Justin
    I meant a GOOD one... :D
