Ham GMRS or CB
Discussion in 'Audio & Video' started by MDOverlander, Nov 23, 2021.
  1. Nov 23, 2021 at 12:25 AM
    MDOverlander
    MDOverlander [OP] Well-Known Member
    Looking for a radio for overlanding.
    1. Which one…. Ham GMRS or CB?
    2. Which brand
    3. What antenna
  2. Nov 23, 2021 at 11:55 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
  3. Nov 23, 2021 at 12:43 PM
    MDOverlander
  4. Nov 23, 2021 at 12:56 PM
    Browner
    Browner Well-Known Member
    Shawn
    Central Iowa
    2020 TRD OR
    Prinsu Rack, CBI Sliders, UpTop Truss Rack, Softtopper, TRD OEM 2" Lift, SCS Rims, Wildpeak tires, OVS RTT and 270 Awning, Off-Grid Engineering Dual Battery tray, Red-arc BCDC, Switch Pros Controller, cheap Amazon lights.
    Go with the type that the people you run with use. Around my area, most of the clubs have moved to GMRS. No one uses CB unless you're a trucker. And Ham is kind of intimidating for people, along with needed to take a test to get licensed. GMRS needs a license as well, but you pay the fee online and have a license within a few minutes or hours.
    The one thing that does irritate me with GMRS/FRS, is a lot of businesses are using them around here. Specifically, daycares calling up kids for parent pick up, and Chick-fil-a in their long ass lines. Kind of fun to jump in their conversations and order a free meal for the guy in the white taco! (Which hasn't worked yet, but the confusion is totally worth it.)
  5. Nov 23, 2021 at 1:19 PM
    MDOverlander
    Probably going to go with HAM or GMRS or both. I’m looking at the thread above to get ideas about install. What radio and antenna do u recommend
  6. Nov 23, 2021 at 2:05 PM
    Browner
    Shawn
    Central Iowa
    2020 TRD OR
    The group I run with all have Midland radios. I went with a Midland MXT275. I liked that the controls are built into the mike. I mounted the base under the passenger seat with a couple screws just into the carpet. It doesn't slide around at all.
    As far as antenna, most of my buddies use either the Midland 3DB Ghost antenna or the Midland 6DB Whip. That is the "Easy Button" way. I wanted a small whip without the exposed coil. I also wanted to mount it to my passenger ditch light bracket with a custom length cable. So I went with a Laird BB4505CNS 5DB non-ground plane antenna. And you also need a NMO style mount, a amphenol connector and some soldering skills to go that direction. And maybe a friend with a meter to tune the antenna.
    MDOverlander[OP] likes this.
  7. Nov 23, 2021 at 2:07 PM
    tacoman45
    Orygun
    I've heard this about GMRS - lots of businesses using it. We don't have too many repeaters in my area, so it hasn't really taken off yet.
    I'd argue there are quite a few people still using CB, especially in my area. I feel like enough people still use it to where it'd be worthwhile to have a CB, even if it's just a handheld unit. My vote is you get all three - HAM, CB & GMRS ;)
  8. Nov 23, 2021 at 8:30 PM
    MDOverlander
    I like that the MXT275 has everything on the handle. I’m also looking at the MTX 400 since it has more power. and probably go with the 3DB Ghost antenna
  9. Nov 23, 2021 at 8:31 PM
    MDOverlander
    Not sure if I’ll have enough room but good idea to have all 3
  10. Nov 27, 2021 at 12:09 AM
    tacoman45
    Orygun
    Being serious, I'd just run whatever your buddies offroad run. I'd say a decent enough amount of people still run CB and you can find very small CB radios nowadays that won't take up much room on your dash. You can always upgrade or add a radio down the road.
    If you're new to CB radios and don't want something complicated, take a look at the President Bill CB radio - it's about the same size as an iPhone and kicks out decent power for the size. Hook it up to their detatchable pretuned antenna (New Virginia) and you'll be in business in no time. President makes some damn good radios and they have some great options if/when you decide to step up to something a little more heavy duty.
  11. Nov 28, 2021 at 4:16 AM
    MDOverlander
  12. Nov 28, 2021 at 4:16 AM
    MDOverlander
    Good info. I like small and simple
    tacoman45 likes this.
  13. Nov 28, 2021 at 5:24 AM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    I'm an old timer, but I've used cb for many years, hunting and driving long trips. Good to hear of an accident miles before you get there, stuck in a standstill, and how to get around it if needed. gmrs is nice also, my suggestion is get both. I run a 30yr old K40 magnet mount, as good as they get and removable when not used. Wilson also makes a good mag mount.
    tacoman45 and MDOverlander[OP] like this.
