Halogen fog light bulb 2020
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacos4u, Jan 7, 2023.
  1. Jan 7, 2023 at 8:52 AM
    tacos4u
    tacos4u [OP] Active Member
    What’s a good replacement that’s bright and last? It’s a h11/h16 bulb I tried some but they don’t last. I don’t won’t a new pod light looking for best bulb replacement.
  2. Jan 7, 2023 at 9:12 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    eurowner and Tacospike like this.
  3. Jan 7, 2023 at 10:23 AM
    tacos4u
    I read these may not last very long though
  4. Jan 7, 2023 at 11:16 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    You need to pick one...
    Performance or Durability. You will not find both.
  5. Jan 7, 2023 at 11:55 AM
    tacos4u
    Where do you get the GE’s say sold out
  6. Jan 7, 2023 at 12:03 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    You need to make sure yours has the H11 fog lamp. The H11 is not compatible with the H16 fog lamp. If its the H16 bulbed lamp, then you should save your money trying to find good h16 bulbs, and pick up a set of h11 oem fogs or take a look at the SAE J583 LED fog lamp thread at the top of the "Lighting" subforum.
    MikeyMcFly likes this.
  7. Jan 7, 2023 at 1:02 PM
    tacos4u
    Mines h11
  8. Jan 7, 2023 at 1:37 PM
    tacos4u
    Guess you can’t buy the ge h11 anymore
  9. Jan 7, 2023 at 2:52 PM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    Get the OEM Toyota LED fog lights. Once adjusted they are really good.
    atc250r likes this.
  10. Jan 7, 2023 at 3:44 PM
    tacos4u
    Don’t wanna do anything else to the truck just want a good bulb. It’s paid for I’m done with it doesn’t interest me anymore just need good bulbs.
  11. Jan 7, 2023 at 3:48 PM
    Tacospike
    Two Trucks
  12. Jan 7, 2023 at 6:08 PM
    Toy_Runner
    99 4Runner SR5
    GE sold off their lighting division to Tungsram, which still makes very good bulbs. The 3rd gen H11 headlight thread has sources for the tungsram bulbs.
    davidstacoma likes this.
  13. Jan 7, 2023 at 7:00 PM
    tacos4u
    Oh ok. I saw the Tungsram bulbs thought it was a knockoff.
  14. Jan 7, 2023 at 7:10 PM
    tacos4u
    Guess not I thought I saw those sold out too!!
  15. Jan 7, 2023 at 7:39 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
  16. Jan 8, 2023 at 8:01 AM
    tacos4u
    That’s overwhelming and confusing all the info in those threads. Page 1 at the top needs a list of the bulbs from best to worst. So I’m still unsure especially since I can’t find the best recommended bulb.
  17. Jan 8, 2023 at 8:14 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Your truck is not H11 unless you modified it, it is H16. H11 was only available 2016-2019 on TRD trucks for 3rd Gen. 2020+ are all H16.
    There are no performance or better H16 bulbs. H16 is a very low performance low power bulb, thus no manufactures bother with a performance version.
    The least expensive option is to find some used OEM 16-19 TRD H11 assemblies, these are referred to as wide-angle fogs, which are significantly higher performing that the standard H16 fogs. From there the best H11 bulb available is the H11 Tungsram Platinums. The Platinums are higher performing than the GE (Tungsram) +130s.
    I’d suggest watching the marketplace section for fog takeoffs people sell when upgrading to SAE LED fog assemblies. You might even consider posting a wanted post in there for looking to buy fogs.
    t2c, Speedfreak, Toy_Runner and 5 others like this.
  18. Jan 8, 2023 at 8:22 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    That’s good advice, I got my H11 55W wide angle fogs off the marketplace for around $50. My GE (Tungsram) +130 H11 in my low beams are still good after two years but I don’t drive often at night.
    Here’s a link to the part numbers for the OEM Valeo H11 55W wide angle fog lights:
    https://www.tacomaworld.com/threads...ctor-headlights.589465/page-147#post-23887408
    I would pass on the H16 19W fogs.
    crashnburn80[QUOTED] likes this.
  19. Jan 8, 2023 at 8:26 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Minor correction, the H11s are 55w. :)
    The GE/Tungsram +130s are a good bulb, especially in the 3rd Gen projector headlight. The Platinums are just a little better. 2 years is a pretty good run.
    davidstacoma[QUOTED] likes this.
  20. Jan 8, 2023 at 8:27 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    @crashnburn80 I could be wrong but I thought I read that the TRD Off Road came with H11 even in the newer years?
    @tacos4u if you keep checking you can find a returned set of OEM LED fogs on Amazon for under $100. That's probably what 3 sets of high performance halogen bulbs would cost you and you only need to install them once. Its a really simple install. Took me less than 10 minutes.
    https://www.amazon.com/gp/product/B07DBPYC4D?ie=UTF8
    davidstacoma and rsimi72 like this.
