Hack your factory satellite antenna. XM Sirius shark fin DIY
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vr6pilot, May 20, 2015.
  1. May 20, 2015 at 4:29 PM
    vr6pilot
    vr6pilot [OP] rather be dubbin'
    Dan
    Viva New Mexico!!
    2016 Quicksand SR5
    You have an aftermarket head unit or you bought a portable sat radio with vehicle kit and thought, "hey, I already have a roof-mounted sat antenna so why not use that?"
    Then you search the forums and discover that the plug is proprietary to Toyota and Lexus but that you can buy an adapter cable for anywhere from 50-70 bucks and you're like, "WTF?" Reeling from the bitter pill of having to pay for radio in the first place, the last thing you want to do is dole out even more money. So here's the down and dirty DIY to connect the radio's antenna cable to the truck's antenna cable.
    How you route these cables is up to you. This is the Cliff's notes edition.
    Note: you will be cutting the proprietary connector off the end of the shark fin antenna wire and you will be cutting the antenna off the vehicle kit's antenna wire then splicing them together. That's the name of the game, kids.
    The factory satellite antenna wire runs under the driver's side sill plate and terminates under/behind the left side kick panel. Pull those panels off, unwrap the tape from the wire harness and look for the black coaxial cable that is a tad thicker than all the rest.
    CBA3417A-89AF-41A2-B5AD-E45E36835394_zps_0819220478428aaca714c777bf2d046011a5e6b5.jpg
    Cut the cable up near the foot rest and strip about 1.5" of the outer jacket and then carefully peel back the braided shielding.
    164104A4-0157-4B57-99E8-A3C232AA4E7B_zps_9fcf57928201741307a1be45499803c3398c584a.jpg
    Once the shielding is pulled back, carefully strip about 1/2 ~ 3/4 inches of the center wire's insulation. Then do the same with the antenna wire coming out of the XM/Sirius unit.
    Remember to slip some heat shrink tubing over your wires before joining them together (if you're going to use that but you can get away with just electrical tape).
    Twist and solder the center conductors together and seal up with heat shrink or tape or both.
    Then slide your frayed shielding back together over your first connection. So long as the shielding from both wires is touching, you should be able to test-fire your connection.
    44290F5F-FA88-4BA6-914D-429C04928BBC_zps_7a31da28364b3a5ee92da75ea528210b287f5cc5.jpg
    If you have a good signal, continue by ensuring a sound electrical connection for the shielding by applying solder in a few locations around the perimeter of the cable. Then, seal it up with heat shrink.
    79C1F7D9-9AA9-4B41-85AF-9DEFF51220DB_zps_c0f029c3fa41af4bf266e5c49c5583c1817764e6.jpg
    For abrasion resistance, wrap it all up with more electrical tape.
    FCC4416A-46B9-4B89-BC72-819220853AC1_zps_cb1c23745cb00f9d53fd9452a249d30534287b53.jpg
    Route your antenna wire as desired and put all your panels, carpet, etc back in.
    Enjoy.
    Ihatetacomas and BUZZCUT like this.
  2. May 24, 2015 at 7:29 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Pretty cool mod but I hate my shark fin antenna, my reception blows. My cheap aftermarket unit in my Camry, coupled with a $10 magnetic antenna, blows away the reception if my stock unit. If I had my choice, I'd ditch the OEM antenna.
  3. May 25, 2015 at 12:47 PM
    vr6pilot
    Dan
    Viva New Mexico!!
    2016 Quicksand SR5
    No problems with mine whatsoever. Got it plugged into an Edge portable unit and it links up within 3 seconds and hasn't dropped yet.
  4. Dec 9, 2015 at 7:26 PM
    RDawg
    RDawg Active Member
    2012 Supercharged 4.0L TRD 44
    exactly what I was looking for...don't want a second antenna on my truck!
  5. Apr 18, 2016 at 12:13 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I need more info on this one. What did you hack into it? A plug for the aftermarket radio or what? I feel like there is some missing info here.
    I am going to be switching to an aftermarket unit here really soon and need to decide if I am going to get a converter plug which costs stupid money, or if I'm better off hacking the shark fin.
  6. Apr 18, 2016 at 12:15 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
  7. Apr 18, 2016 at 1:06 AM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    Totally doing that this summer
    Although before I do, is the reception really that bad with the sharkfin XM?
  8. Apr 18, 2016 at 1:49 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    No, but you do lose it going under overpasses. Which is annoying while listening to music.
  9. Apr 18, 2016 at 4:45 AM
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    You're going to get that with any XM unit / antenna. It's satellite radio just like satellite TV or GPS. When you don't have a clear view of the sky, you lose reception. Doesn't matter how expensive your components are, that's just how the technology works.
    Sugar Silva likes this.
  10. Apr 18, 2016 at 6:03 AM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    Mine on my 2010 drops off under clear open sky, and will stay that way for miles sometimes. Never could figure out why, neither could the dealer. Maybe I should of tried for lemon law.
  11. Apr 19, 2016 at 5:55 PM
    Ihatetacomas
    Dylan
    Elko NV
    Is this for 2016 or 05-15?
  12. Apr 19, 2016 at 6:03 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    I did this accidentally in my 2011. I stripped the wire back and plugged it directly into the XM tuner. Plugged in is a stretch, I have metal tape holding it in place. Not ideal, but been good for two years running.
    I thought it would be more similar to a coaxial cable (which is why I stripped it to begin with) and I could crimp on a tiny coax connector, but I was wrong about that.
  13. Apr 19, 2016 at 6:04 PM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    Read the title of this thread and was hoping I was gonna learn how to get some free xm.
    I was let down.
  14. Apr 20, 2016 at 1:22 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Still inquiring about this as I have everything ready to do the install today.
  15. Apr 29, 2016 at 7:23 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Signal blocked near airports, military, navy bases... do you live near/drive by alot of this kind of stuff?
  16. Apr 29, 2016 at 7:34 PM
    toomanytoys84
    Stock
    Nope. I was driving today. Clear skies. No trees over head. Started breaking up and I lost it for 12 miles. Then it came back perfect
  17. Apr 29, 2016 at 7:39 PM
    IronPeak
    AuggieX
    Back to Back
    Huh that Sucks if Howard Stern got cut off during an interview id be pissed.... maybe there is a bad connex somewhere, maybe where the cable terminates at the radio or at the antenna? I had Sirius xm for years and I know their home antennas are very easy to ruin by messing up the shielding... maybe ask for a new wire and to have it run /installed for you. Thats why I checked out this thread, I wasn't aware the cable could be repaired, surprised that it can.
  18. Apr 29, 2016 at 7:43 PM
    toomanytoys84
    Stock
    I don't even have a subscription. I listen to the preview channel when I can find nothing on the regular radio.
  19. Jul 29, 2016 at 5:31 AM
    canmoretaco
    canmoretaco New Member
    Will
    2011 Double Cab
    Did this today, but a little different. On my 2011 the OEM head unit had Sirius, but I wanted a better stereo so I set out to replace it, and wanted to continue using the shark antenna with the sat radio module for the new head unit. As the OEM unit had Sirius there had to be an antenna connection at the head unit somewhere, right? After hooking the new head unit up I went through the "left over" plugs and found a blue one with what looked like coax cable going into it... Snip, yep, coax like VR6. I then cut the coax going to the new Sirius control box, did a Frankenstein splice job of the two and boom, 3 bars of Sirius. No cables to run! I'm too embarrassed to show photos of the splice, but I did as VR6 did but with a crimp connector to connect the internal wire. I then used a piece of wire with lots of thin strands, not one thick one, and wrapped it around the outside of the plastic crimp connector a bunch, basically replicating the "weave" wire that was too short and frayed to connect. I was careful to make sure the interior single wire was totally encased in my plastic splice thingy so nothing would short. Finish by wrapping the while skid rig in tape, enjoy your factory antenna working with the new head unit!
  20. Jul 29, 2016 at 5:35 AM
    canmoretaco
    Will
    2011 Double Cab
    Photo of the factory coax antenna cable at my head unit. The wire is black, the silver is the weave stuff inside, I'd already cut it and started stripping it then thought a photo might be useful...image.jpg image.jpg
