H13 led light bulbs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Obedlee, Nov 16, 2017.
  1. Nov 16, 2017 at 9:47 AM
    Obedlee
    Obedlee [OP] New Member
    Obed
    2017 Toyota Tacoma 4x2
    Recently bought a set of light bulbs h13's by mistake, they did fit but I was supposed to put the h11 will the h13 do anything to my tuck or should I change them thank you
    Argo98 likes this.
  2. Nov 16, 2017 at 11:13 AM
    Argo98
    Argo98 Well-Known Member
    Argo
    2017 Toyota Tacoma TRD-Sport 4x4
    Rough Country 3" spacer lift w/ shocks 285 KO2's wrapped around 16' ProComp Series 7069 Misc. bibbidybob lights
    Subbed to watch... Have you called the dealer?
  3. Nov 16, 2017 at 11:24 AM
    Argo98
    Argo
    I think I found the answer... H11 is single beam, H13 is dual beam... Single beam is for either your high-beam or low-beam which means it is going to go into only one of the housings of the two I mentioned. A dual beam headlight only has one housing and changes the voltage to change between low and high beam.... Check out this page I found on them: https://www.vehicode.com/blog/the-complete-beginner-s-guide-to-led-headlight-bulbs.html (Ignore the fact that its for LED's and just focus on the H11/H13 part)
    TL/DR I believe you should be fine running H13's
    JoeCOVA likes this.
  4. Nov 23, 2017 at 9:11 PM
    Obedlee
    Obed
    Thank you for the info
