H11 HID kit.
Discussion in 'Lighting' started by swtaco10, Dec 27, 2019.
  1. Dec 27, 2019 at 6:03 AM
    swtaco10
    swtaco10 [OP] Well-Known Member
    Dave
    South of Tampa
    2010 Tacoma TRD off-Road
    Bilstein 5100's, LED interior and puddle lights, 17" XD revolver's, Grabber A/T2's
    Who is a good/solid company to buy a HID kit for the wife's Camry from? Don't want to go TRS, bad past experience.
  2. Dec 27, 2019 at 6:12 AM
    klavender1
    klavender1 Well-Known Member
    Columbia/Lugoff, South Carolina
    2005 GX 470
    Not an HID kit suggestion but I went thru the same research looking for better bulbs for the GF's Lexus CT200h. I'm just not a big fan of aftermarket HID or LED kits. It seems very hit or miss when it comes to actual lumen output and longevity. And prices are all over the place. I've decided to try using Philips H9 bulbs. You have to very slightly modify the tabs and lumens is said to be about double of the H11. While being safe to use as they don't get too hot for the housing or the wiring. I've got them ordered from Amazon for $7 each. So it's a cheap experiment/upgrade. They should be here tomorrow and I'll let you know how they turn out.
  3. Dec 27, 2019 at 6:19 AM
    swtaco10
    Dave
    South of Tampa
    Please do. I'd be interested to see a before and after.
    klavender1 likes this.
  4. Dec 27, 2019 at 10:14 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    The Phillips really don't compare to HIDs. I pulled out my HIDs to try them and let's just say I went back to my HIDs when I got back from the test drive lol. They are a simple and cheap upgrade from the stock lights.
    I run XD HIDs (5000k) and I like them, minus the headlight shake but that is on Toyota, not the HIDs.
  5. Dec 27, 2019 at 10:22 AM
    swtaco10
    Dave
    South of Tampa
  6. Dec 27, 2019 at 10:25 AM
    Technique
    Alex
    Utah
    Yessir.
  7. Dec 27, 2019 at 10:26 AM
    BlackGT99
    BlackGT99 Well-Known Member
    Noel
    2019 VooDoo Blue Tacoma TRD Pro
    Morimoto. I went through Amazon
  8. Dec 27, 2019 at 10:39 AM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    I went thru HIDconcept.com as they offered a Philips option. I’ve been running them for a year and a half with zero issues and the Philips glass is amazing.
  9. Dec 27, 2019 at 10:41 AM
    Technique
    Alex
    Utah
    Phillips 4300k HIDs were great and super bright but man, they HID shake I had with those was unbearable. The intensity of the bulb made it SO noticeable going over any imperfection in the road for me. I switched to XD 5000k bulbs and its a lot better, still pretty bright but not as much noticeable shake.
  10. Dec 27, 2019 at 10:58 AM
    ST77
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    Different bases... that was the sole reason not going with XD. The HIDconcepts are a better rebase than XD. Mine only shake when doing some serious off-roading and it’s still not bad considering the terrain.
  11. Dec 27, 2019 at 11:03 AM
    Technique
    Alex
    Utah
    I've seen reports of shaking from all different brands of HIDs in the tacoma. The same HIDs won't shake in a different make of vehicle but put them in the Tacoma and they do. I have tried a lot of different..uh gaskets/orings for the bulbs, some being so thick I could barely get them to lock in the headlights and they still shake.
  12. Dec 27, 2019 at 1:59 PM
    swtaco10
    Dave
    South of Tampa
    Not too worried on the shake yet, I'm sure that'll change. Haven't looked into HIDconcepts yet.
  13. Dec 27, 2019 at 2:02 PM
    PureWhiteYotee
    PureWhiteYotee Well-Known Member
    2015 White TRD Sport Long Bed
    What about LED bulbs vs HID?
  14. Dec 27, 2019 at 3:22 PM
    swtaco10
    Dave
    South of Tampa
    Thought about that but wasnt too sure if they were up to par for headlights yet.
  15. Jan 3, 2020 at 6:21 AM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Why go with a "kit?" Put your own together if you want the best. Here is a set up I put together for the wifes 2018 4runner. It is Philip's XV2 rebase H11 bulbs, HD relay harness, and denso OEM Lexus ballasts. Extremely quick start up and perfect white light. None of the funky tones like most aftermarket HIDs have. This is basically like an OEM HID system.
  16. Jan 3, 2020 at 8:33 AM
    klavender1
    2005 GX 470
    Sorry I couldn't get good before and after pics as I did the work in the morning. I will say it's a nice upgrade from stock. Especially for the money. I'm sure it doesn't compare to a nice HID system. But it's hard to beat $14 for 2 bulbs.
