Gunner kennel (question)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Inverted, Jan 9, 2020.
  1. Jan 9, 2020 at 4:50 PM
    Inverted
    Inverted [OP] Well-Known Member
    For those that own one: Has anyone successfully fit two in the bed? I have an intermediate sized one and I’m hoping to squeeze a second one next to it.
    On paper it shouldn’t fit, but the wheel well housing actually gets wider the higher up you measure. I fit a Large Ruff Tough kennel next to it recently ..
  2. Feb 9, 2020 at 5:32 PM
    dubsout
    dubsout Member
    Did you ever figure this out? Wonder the exact same thing...was hoping to avoid building a platform
  3. Feb 9, 2020 at 5:48 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Inside the wheel wells it’s 43” at the bottom and 45” at the top. You need 46”, right?
  4. Feb 9, 2020 at 8:09 PM
    dubsout
    dubsout Member
    On paper, yes. Curious if it was tried where you can find an ~1-2” to squeeze somewhere. The gunner kennels aren’t perfectly square on the sides either. They flair out from the bottom to the middle
  5. Feb 9, 2020 at 8:32 PM
    dubsout
    dubsout Member
  6. Feb 10, 2020 at 6:57 AM
    PacoDevo
    PacoDevo Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    a couple of 2 X 4's under one or both to raise one or both up higher and allow the taper of the kennels to work with the taper of the wheel wells and give more room width-wise???
  7. Feb 10, 2020 at 12:55 PM
    dubsout
    dubsout Member
    Possibly! I went ahead and bit the bullet on the second kennel. Will keep ya'll posted on how I get it to work
  8. Feb 10, 2020 at 7:01 PM
    Inverted
    Dubsout:
    Just saw these replies. Very interested to see if it fits and pics. Please keep us posted.
    I haven’t purchased a second intermediate yet.
  9. Feb 14, 2020 at 6:58 PM
    rasber3140
    rasber3140 Well-Known Member
    2021 TRDOR Barcelona Red
    I am also interested in this. Please report back.
  10. Feb 17, 2020 at 5:22 PM
    dubsout
    dubsout Member
    Crate will be delivered late this week - will report back then
    Inverted[OP] and rasber3140 like this.
  11. Feb 17, 2020 at 6:32 PM
    rasber3140
  12. Feb 20, 2020 at 3:01 PM
    dubsout
    dubsout Member
    Alright...reporting back with so-so news.
    Short is they don't fit (well) between the wheel wells. The below picture took some love to get into place.
    I'm limited due to the topper. I can't build a full platform above the wheel wells since the crates are too tall. But...I think if I get a couple 4x4s and secure them to the bed to raise it within the wheel well towards the top of the taper it might work. Ill be going to the hardware store later to see if I can make this work.
    I tried by just shove something below one crate and it fit quite a bit better. Pretty sure I can them close to even with the right elevation.
    A little deceptive due to wide angle lens, looks better in person.
  13. Feb 20, 2020 at 6:19 PM
    dubsout
    dubsout Member
    Good news! I was able to get it to work with a set of 4x4's. Cut one for the back and one for between the wheel wells. May want to build something a little more permanent...but this works for now. It didn't require any force to get them to sit next to each other.
    These are two intermediate crates side by side.
  14. Feb 21, 2020 at 6:16 AM
    Inverted
    Thanks for responding. This looks great
    Did you attach the 4x4s to the bed? Do you have a pic without the kennels installed ? It looks like you raised it roughly 2”?
    Thinking about doing the same, but with aluminum since I have an open bed
    thanks
  15. Feb 21, 2020 at 10:02 AM
    dubsout
    dubsout Member
    I did not attach them to the bed (yet). I ratcheted the crates down so I'm going to see how this works first. I will build something more permanent if it seems like it'll be an issue.
    Unfortunately I got ahead of myself and didnt take a pic with just the wood in place. I just bought an 8ft 4x4 and cut two pieces. One approximately 42" between the wheel wells and the other at 53" for behind the wells.
    The 4x4's measure at a true 3.5" so that's how much the crates are currently raised.
    Inverted[QUOTED][OP] likes this.
  16. Feb 21, 2020 at 10:19 AM
    Charlyc
    Charlyc Well-Known Member
    Jarrettsville, MD
    2023 Winter Chill Pearl Tacoma Limited
    They need short legs attached and rubber mat so they don't slide on the bed.
  17. Oct 6, 2020 at 1:57 PM
    waytolatetothegame
    waytolatetothegame Well-Known Member
    James
    2016 Inferno Tacoma TRD OR
    @dubsout - Thanks for sharing your setup. I'm thinking about something similar and wanted to see if you had any insight now that you've had this for a little while. How's the setup working out for you? How are your dogs doing in the kennel inside the topper? What size/breed of dogs do you have VS size of kennel? Any other feedback or insights would be great. Thanks!
  18. Oct 6, 2020 at 4:35 PM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    FYI - Two large Ruffland crates will fit between the wheelwells. Good for 70lbs dogs. XL should also fit - crates will be taller and block more of the view out of the back window.
  19. Oct 6, 2020 at 4:45 PM
    slistings
    slistings Well-Known Member
    SoCal
    This is awesome. Thanks for the info.
  20. Oct 19, 2020 at 5:06 AM
    Inverted
    Ruff lands are pretty good, I have one. The shipping costs are outrageous though. Quality is nothing near Gunner...
    But awesome to put inside of a truck. Lighter too, which makes it a lot easier to maneuver
