GT86 seats in 2019 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by black3rdgen, Mar 3, 2024.
  1. Mar 3, 2024 at 6:41 PM
    black3rdgen
    black3rdgen [OP] Well-Known Member
    STL
    3G on 35s, 5.29s
    YW E30 tune, 5.29s, equal length dual exhaust, 2000w audio system
    My buddy just got some racing buckets in his 2018 GT86, and he had a set of the oem buckets laying around. I got em for $200 and a few beers, so I’m gonna toss them in my 3g. Ordering the planted seat brackets tomorrow, will update the thread when they come in.
    Ngneer, Emmohl, Beams37 and 2 others like this.
  2. Mar 3, 2024 at 7:30 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i feel like the seating position is all wrong for the taco. too scooped. i mean, it's not a race truck...
    jmneill and Chew like this.
  3. Mar 3, 2024 at 8:05 PM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Agreed. I will modify the brackets so the seats sit a little higher than stock. With that and the added bolstering these should be super comfortable.
  4. Mar 4, 2024 at 5:16 AM
    boi951
    boi951 Well-Known Member
    Boo
    Galveston Island, Republic of Texas
    2020 SR5 2.7 2WD 2009 OR................. 2006 AC.................
    Just wondering if the airbags and connections will be compatible.
    Malvolio likes this.
  5. Mar 4, 2024 at 11:44 AM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Yes they will. Driver side is “plug and play”, passenger side needs a resistor until I can figure out the wiring for it.
    Malvolio and Emmohl like this.
  6. Mar 4, 2024 at 12:28 PM
    Bart1
    Bart1 Well-Known Member
    Bart
    Tupelo MS
    21 Tacoma TRD Pro
    Diamondback Total Chaos bed stiffeners
    My previous DD was a 2013 FRS and I have to say my wife and I both loved those seats.
  7. Mar 4, 2024 at 2:55 PM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Test fitted the seats before the brackets came in. They’re super comfortable even without the raised bracket, would totally suggest this to anyone unsatisfied with the OEM seats.
    eurowner, Malvolio, jwcox72 and 10 others like this.
  8. Mar 4, 2024 at 3:31 PM
    Bart1
    Bart
    Tupelo MS
    21 Tacoma TRD Pro
    Bolsters are great. Fit about like Recaro SRDs (I think that’s the right model)
  9. Mar 4, 2024 at 4:53 PM
    Slow_sr20
    Slow_sr20 Well-Known Member
    23’ DCSB O/R
    This is awesome. Please update once you iron out the install details.
  10. Mar 4, 2024 at 5:31 PM
    black3rdgen
    STL
    3G on 35s, 5.29s
    So far I think I’ve got it about figured out, here’s a step by step.
    1. remove seats from taco
    2. Remove black wires from both seats, yellow wires don’t need to be touched
    Transfer black wires and seatbelt buckle from the stock seat to the 86 seat
    3. There’s a weird little black box that one wire goes to, remove that with a torx bit and leave it on the wiring.
    4. Install lhttps://www.plantedtechnology.com/p...ta-tacoma-3rd-generation-2016-passenger-right
    4. Put GT86 seat onto the bracket, plug in all wires.
    honestly that’s about it and you’re good to go. Passenger side is apparently a little finicky on 2nd gen’s, not sure about ours. Will update the thread when my brackets come in.
    GTGallop, gilligoon, Emmohl and 2 others like this.
  11. Mar 4, 2024 at 6:15 PM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    Looks good so far. Keep us updated on the final product. Reminds me of the 80's trucks sport seats. Lots of bolster, and a good amount of bucket. Maybe they had heated versions of these?
  12. Mar 4, 2024 at 7:25 PM
    black3rdgen
    STL
    3G on 35s, 5.29s
    The improvement in comfort over the stock seats is insane. I may have to weld the bracket to sit a tiny bit higher but I’m pretty tall so I don’t really need to. Would definitely recommend doing this.
  13. Mar 5, 2024 at 5:07 PM
    soundman98
    NW Indiana
    yes, my brz has heated seats. heated gt86/fr-s seats came mostly in the special-edition trims. the standard toyota model was the same as the brz premium. brz limited comes standard with heated mirrors, and seats.
    but they don't work all that well. my tacoma's heated seats work way better. there's suspicion that subaru insisted on a thermal limit switch that stays far too low
    513Mugsy[QUOTED] likes this.
  14. Mar 6, 2024 at 6:07 AM
    Emmohl
    Emmohl Well-Known Member
    2019 SR5
    So these straight wire right up? What's your height? I'm 6'3 and if it's that simple I'm bout to order a seat!
  15. Mar 6, 2024 at 7:14 AM
    Slow_sr20
    23’ DCSB O/R
    No. OP provided a link to a planted seat bracket you will need to purchase in order for the seats to “bolt in”
    Emmohl[QUOTED] likes this.
  16. Mar 6, 2024 at 7:27 AM
    Emmohl
    2019 SR5
    Sorry I was referencing the wiring aspect of it. Changed my wording
  17. Mar 6, 2024 at 9:02 AM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Yes it plugs right in, but I still have an airbag light which I’m gonna figure out this weekend. It’s a simple fix and I’ll keep you updated.
    I’m also 6’3 and I fit super well. They do sit a little bit low so I’m gonna buy some front and rear seat jackers, but I’d have no problem driving it as is.
  18. Mar 18, 2024 at 5:29 PM
    black3rdgen
    STL
    3G on 35s, 5.29s
    seat is fully in, 0 airbag lights, no issues. Only trouble it gave me was the rivets on the 86 seat rails.
  19. Mar 19, 2024 at 8:40 AM
    Emmohl
    2019 SR5
    Will have to look into this. Appreciate the pics!
  20. Mar 19, 2024 at 4:56 PM
    K9tacoma
    K9tacoma Well-Known Member
    Austin
    Central Ohio
    2023 Tacoma TRD Off Road - Lunar Rock
    Looks killer! What was the fix for the airbag light?
