Grounding locations
Discussion in 'Technical Chat' started by the.sight.picture, Jun 11, 2021.
  1. Jun 11, 2021 at 7:22 AM
    the.sight.picture
    the.sight.picture [OP] Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    Does anyone have a wiring diagram that shows the ground locations on the vehicle?
    I have a wiring diagram, but it isnt showing where on the vehicle the grounds are actually located.
    I'm having an issue with my Turd gen and I need find the ground location for the rear brake lights, stop light switch and possibly the ECM. I keep blowing the STOP light fuse in the engine bay, not allowing me to start the push button normally or shifting outta park without the override.
    I've checked rear brake lights (havent checked the cab brake light) replaced the stop light fuse (multiple times) and relay, stop light switch. Checked the rear for rubbed wires, disconnected the trailer harness and code (1426) is still there.
    So any ground locations besides the obvious (body in engine bay ground, and the under kick panel ground) would sure be appreciated
    Grounding Locations listed in this thread ( Pictures if located)
    - Rear, Drivers side, top of the frame rail just inside of the left rear tire near the upper shock mount (BK is ground location)
    - Drivers side Kick panel
    - Passenger side kick panel
    - Drivers side Battery ground to body
  2. Jun 11, 2021 at 7:36 AM
    GSRON
    GSRON Well-Known Member
    Ron
    Northern CA
    2019 TRD OR Cement
    Quikfix seat risers and lic plate mount, MESO interior and stage 1 tails, glove box and console dividers, shelf for center console, FACTOR 55 hitch link, TC bed stiffeners, OE bed mat,
    There's a ground behind both kick panels.
    There's one on top of the frame rail just inside of the left rear tire near the upper shock mount.
    Those are the only three I know of that might help.
    the.sight.picture[OP] likes this.
  3. Jun 11, 2021 at 9:13 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Thank you, Ill update the OP with with grounding locations.
    Ill run through them later today. Ill tighten them all down, just to make sure. Just from visual inspection, appears the back rear over shock is in place. I have not tried testing it yet tho.
  4. Jun 11, 2021 at 9:18 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    If you are blowing fuses, it sounds like something is shorting out rather than a grounding issue. What electrical mods have been done?
    GrundleJuice and SR-71A like this.
  5. Jun 11, 2021 at 9:20 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    None. other than fog lights from BD, plugged into my front bumper (Which I know isnt the cause). If it was shorting I think the issue would be intermittent, instead of straight blowing the fuse.
    wb7ubb likes this.
  6. Jun 11, 2021 at 9:35 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    At what point does it blow the fuse? Like immediately when you start the truck, only when you hit the brakes, or when you turn on the lights?
    You mentioned you checked the rear brake lights, did you replace all the bulbs? That is a cheap and easy thing to try.
    Usually (and I stress the "usually"), a bad ground results in things not working at all or working intermittently, not blowing fuses. Fuses blow because more amps are going through them than they are rated for, which *usually* means something is shorting to ground on the circuit somewhere. I'm doing some digging to see if I have a wiring diagram.
    SR-71A and the.sight.picture[OP] like this.
  7. Jun 11, 2021 at 9:39 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    I didnt replace the rear brake lights. I did visually inspect them and they appeared to be fine. Filaments intact, no burning or anything.
  8. Jun 11, 2021 at 10:04 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    I had a reverse light that went out, got a replacement and the original one looked perfect, but no workie. I haven't found the 3rd gen docs, but I have 2nd gen docs and a lot of the chassis wiring is similar. Here are the ground points for the 2nd gen:
  9. Jun 11, 2021 at 10:16 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Stop Light circuits for 2nd gen. Based on your codes, I would think 3rd gen is similar since the Skid Control ECU is mixed in here.
  10. Jun 11, 2021 at 10:22 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Is the triangle surrounding "BD" listed as grounds? If so, maybe checking under the front seat cross member left hand (assuming driver side) would make sense, as its not a normally visual ground location
  11. Jun 11, 2021 at 10:26 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Yes, those are grounds and correspond to the locations listed in the previous post (and conveniently printed on the diagram as well). BA looks like it serves the center stop lamp.
  12. Jun 12, 2021 at 6:48 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    You get it sorted out yet?
  13. Jun 12, 2021 at 7:07 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Hell no, I'm not gonna have time to get to it till next week.
    I did visually check the ground on the rear frame, and the front driver side kick panel. Those seem fine (like arent loose in any way)
    I just inspected the passenger side kick panel ground. Appears normal, isnt loose. I cant seem to locate the one under the passenger side seat. Will check further.
  14. Jun 15, 2021 at 5:52 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I can't think of a situation where a factory ground would have anything to do with a short blowing a fuse.
    If you answer the questions asked in this thread there will probably be more helpful suggestions.
  15. Apr 17, 2024 at 1:57 PM
    Lil'John
    Lil'John Active Member
    2002 Tacoma TRD 4wd
    Bringing this thread up from the grave as it seems like I'm fighting the "BD" ground for my tail light assemblies. I've seen claims of the ground being near the rear diff along with being near the rear shock mount. But when I walk the wiring bundle from the rear toward the front, I don't see anything that appears to come out of the looming to the frame.
    In my case, I'm dealing with a 2002 extra cab Tacoma TRD.
    I'm getting ready to just use a circuit 'tap' fitting and creating my own ground.
  16. May 2, 2024 at 6:03 AM
    mattybouges
    mattybouges Well-Known Member
    Boston
    2022 Lunar Rock TRD OR Short Bed
    Is the passenger side kick panel factory ground a robust enough ground connection for a house battery that is pumping 25 amps?
