Grounding CB antenna
Discussion in 'Technical Chat' started by cameronlane, Feb 13, 2010.
  1. Feb 13, 2010 at 5:43 PM
    cameronlane
    cameronlane [OP] Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    Hey all
    Im trying to install a cb radio and I'd like to mount the antenna into the side of the bed right behind the driver side of the cab. How do I ground the antenna so I can tune it? :confused:
  2. Feb 13, 2010 at 8:40 PM
    cameronlane
    cameron
    Anywhere but there
    Bump. Help me please :(
  3. Feb 13, 2010 at 8:42 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    You want to run a wire from the mount down to the frame
  4. Feb 13, 2010 at 8:43 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    the easiest way would be to run a wire to chassis somewhere...like an existing bolt/nut or make a hole and install a bolt/nut, then run that back up to the antenna to ground it. hopefully someone else should chime in
  5. Feb 13, 2010 at 8:43 PM
    cameronlane
    cameron
    Anywhere but there
    does the type of wire make a difference?
  6. Feb 13, 2010 at 8:44 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    I dont think so, I used 12 or 14 gauge, cant remember. I found a bolt on a cross member.
  7. Feb 13, 2010 at 8:45 PM
    cameronlane
    cameron
    Anywhere but there
    awesome thank you!
  8. Feb 13, 2010 at 8:46 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    No problem, good luck. Its pretty easy. The hardest part was finding the right connectors.
  9. Feb 13, 2010 at 8:48 PM
    cameronlane
    cameron
    Anywhere but there
    Yeah im sure it isnt difficult. Im just not very technologically inclined.... yet
  10. Feb 13, 2010 at 8:53 PM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    I was the same way, well still pretty much am :D
  11. Mar 23, 2010 at 9:06 PM
    blackwidow2009
    blackwidow2009 Well-Known Member
    Brian
    Cleveland
    09 Access Cab 4X4 TRD w/ SR5
    2.5" front lift Daystar coilover spacer. 2.5" rear lift add-a-leaf N-Fab wheel to wheel nerf/step bar Polished Stainless Leer cap from my 2000 Tacoma --- It does fit; don't let them lie to you
    If you are mounting the antenna on the outside of the truck (on metal), the antenna will be grounded already by default...the bed metal is connected to the frame at some point.
    If you are mounting the antenna on the inside of the bed on the plastic, you need to run a grounging cable to the frame. Also, and MOST IMPORTANT I recommend using a "no-ground-antenna". This is NOT the same as grounging the cable. A "no-ground-antenna" is an antenna that does not need to be mounted on metal, or at least alot of it, like boats or RV's. CB antenna's need metal around them (think of a candel standing on a plate) inorder to transmit (TX), and is needed inorder to tune your antenna so it has a low SWR.
    If you get the "no-ground antenna", it will come with a cable that attaches to the base of it and you just run it out of site. It acts like a large surface of metal, much like the truck of a car does for a truck mount antenna.
    Make sure you have a SWR meter, and tune your antenna...the antenna will come with directions on how to tune that specific one.
    DONT NOT ever key you mic unless your radio is attached to an antenna...you'll fry it up in less then a second!!! Seriously, you'll burn it up inside just that quick. At the same time, talking with a un-tunes radio, will do the same, just takes longer. But dont let that scare you. You will not fry the radio in the short time that you keying it up while your tuning the antenna.
  12. Jul 3, 2012 at 9:13 PM
    Vegas Tacoma
    Vegas Tacoma Well-Known Member
    Brian
    Las Vegas
    06 prerunner sr5(RIP) 2018 Focus Hatchback
    i have an 06 tacoma, i baught a 5' firestik 2, stanless mount and 18' of wilson coax, i ran a ground to the frame and when i try to tune the antenna it pegs the nedle on the swr meter, i used 12 gage wire, was told to try ten guage and make the ground as short as possabe, any sugestions would be appreciated
  13. Jul 3, 2012 at 9:21 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    +1 on his post-the "wire" he's talking about is called a "counterpoise" or "something for the antenna to work against" like it would off the truck body.
    I personally would do a hard ground to the metal body-and just keep the ground strap short as possible-if it gets long enough to be a quarter wave of 27 mHz it will try to be part of the antenna instead of ground.
    Bottom line-get a proper ground strap (braid) or at least #12AWG thick copper wire and drill a spot IN THE METAL BODY within 2' of the antenna and ground there:)
  14. Jul 3, 2012 at 9:23 PM
    RattleSnake44
    RattleSnake44 Well-Known Member
    SoCal
    06 DCSB PreRunner TRD Offroad
    OME 3" Lift, Dakar Leaf Packs, ARB Front Bumper, Warn M8000 winch
    Sub'd. Adding a CB is gonna be my next project. Collecting all the info I can.
  15. Jul 4, 2012 at 11:37 AM
    Vegas Tacoma
    Brian
    Las Vegas
    do i attach the ground strap to the anttena or to the mount,sory if this is a stupid question, i've never had a cb or had to install one
  16. Jul 4, 2012 at 12:53 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    To the mount.
