Grounding a CB antenna in composite bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by paintpimp, Jun 29, 2017.
  1. Jun 29, 2017 at 7:37 PM
    paintpimp
    paintpimp [OP] Well-Known Member
    Loveland CO
    2016 Tacoma Dbl Cab Long Bed TRD Off Road
    ARB front bumper with 10,000 lb winch ARB rear bumper RSI bed rack 2.5 adjustable lift TRD rims Leather seats
    im looking to install a fire stick on the bed rail but was wondering if anyone new if it was grounded or if anything on the composite bed is grounded at all or if I would have to run a ground strap.
  2. Jun 29, 2017 at 9:07 PM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    People have taken the ground strap to the inside of the rear tail light as a ground. Depending how close u r installing.
    paintpimp[OP] likes this.
  3. Jun 30, 2017 at 3:46 AM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    I was told to get a NGP (no ground plane) antenna, firestick makes them also. What's anyone's thoughts on this?
  4. Jun 30, 2017 at 4:19 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    In a conventional antenna setup the metal surface the antenna is attached to serves as the ground plane.
    Since plastic rail toppers and composite beds are non-conductive, they can't serve as the ground plane.
    So... yes to using a NGP type antenna and yes to running a ground strap. Go to the frame or substantial metal component that is well connected to the frame. There may be a good connection point inside the metal bodywork the tail light attaches to, but don't just connect to a taillight ground wire.
    Sandman614 likes this.
  5. Jun 30, 2017 at 4:22 AM
    seanislegend
    seanislegend Well-Known Member
    Sean
    Port Richey, FL
    2008 Tacoma TRD Sport 4x4
    3" Icon coilover lift with resi. 17x10 pro comp wheels 255/75/17 bfg km1 mud terrains
    I have a 2008, in the fire stick is mounted in the bed near the window. I will post a picture in a bit, but how do you run a ground strap? I am new to CB radios and my truck came with one I want to beef up the system.
  6. Jun 30, 2017 at 4:42 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I just mounted my to the cleat rail in the bed.
    Braves95 likes this.
  7. Jun 30, 2017 at 4:46 AM
    jowybyo
    Joe
    Baltimore, MD
    I used this mount with a Firestick (I think it's NGP, but I'm not sure)
    https://www.rightchannelradios.com/...ounts/products/firestik-3-way-cb-mirror-mount
    I just used t-nuts to mount it to the metal clear rail in the bed. No ground strap. CB works really well actually.
  8. Jun 30, 2017 at 10:12 AM
    seanislegend
    Sean
    Port Richey, FL
    Is this setup good?
  9. Jun 30, 2017 at 10:16 AM
    TacoFister
    TacoFister Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    Chassis Ground...
  10. Jun 30, 2017 at 6:18 PM
    paintpimp
    Loveland CO
    That's exactly how I'm mounting mine
  11. Jun 30, 2017 at 6:33 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    This is not a sufficient ground.
    m603holden likes this.
  12. Jun 30, 2017 at 8:18 PM
    seanislegend
    Sean
    Port Richey, FL
    I posted pics of my setup, do i need a ground strap to the frame? It's mounted to the composite part
  13. Jun 30, 2017 at 8:24 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    :notsure: is it an NGP antenna, how is your SWR?
  14. Jun 30, 2017 at 8:25 PM
    Sandman614
    Tim
    '06 SR5 Off Road
  15. Jun 30, 2017 at 8:47 PM
    seanislegend
    Sean
    Port Richey, FL
    How can i tell if it is ngp? Here is my antenna
    And here is my swr with mic held down
  16. Jun 30, 2017 at 9:48 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    I don't think there is anything you can tell by looking at the antenna. What antenna did you buy? You're not measuring SWR in that pic.
    WileECoyote and jmaack like this.
  17. Jul 1, 2017 at 4:40 AM
    jowybyo
    Joe
    Baltimore, MD
    I did. It was good.
  18. Jul 5, 2017 at 4:36 PM
    seanislegend
    Sean
    Port Richey, FL
    20170705_192731.jpg I added this and grounded it to the frame, i checked ground first it was a good ground
    20170705_192656.jpg this is with the truck idling. CAL turned all the way up. Is this good?
  19. Jul 5, 2017 at 4:54 PM
    Braves95
    David
    Central PA
    It needs to come down more. 1.5 or lower.
  20. Jul 5, 2017 at 4:55 PM
    Braves95
    David
    Central PA
