Ground wire behind head unit?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BBQtaco74, Jan 11, 2020.
  1. Jan 11, 2020 at 5:25 PM
    BBQtaco74
    BBQtaco74 [OP] Member
    Caylor
    TRD Off-road
    I am installing a USB behind my dash using an Add A Fuse and Im not quite sure where to ground it. There are 2 screws directly behind the head unit, but I’m not sure if that’s sufficient or not. Any help would be appreciated! Thanks!
  2. Jan 11, 2020 at 5:32 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Use a multimeter and test for ground at the screws. Check continuity between them and a known ground point under the dash.
  3. Jan 11, 2020 at 5:48 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    There is a grounded bolt right there at the fuse panel under the dash. If you are running your positive wire with add a fuse there, just run a ground from that point.
    pic from google, but that is where I grounded my dash cam and it works just fine.
  4. Jan 11, 2020 at 6:13 PM
    BBQtaco74
    Caylor
    TRD Off-road
    I saw that today when I was looking. Didn’t know if it was a ground or not. I’ll use that unless someone has one directly behind the head unit. Thanks!
    daddy_o[QUOTED] likes this.
  5. Jan 11, 2020 at 6:25 PM
    caribe makaira
    Caribbean, Puerto Rico
  6. Feb 10, 2022 at 2:23 PM
    tshop11
    tshop11 Well-Known Member
    Tyler
    Truckee, CA
    22 Tacoma SR5
    I know I'm reviving an old thread but I am wiring up my heated seats today and came across this. It was my understanding that it was a no-no to ground on something like this as there is plastic in the middle. Is this an okay grounding location? The other one I've seen recommended is a total pain to get to and I'm worried I may damage some wiring unthreading the bolt.
  7. Feb 10, 2022 at 3:00 PM
    mwrood
    mwrood Well-Known Member
    2021 Voodoo Blue TRD Premium Sport
    Perfect grounding point in the drivers side kick panel.
    ORtoCOTaco likes this.
  8. Feb 11, 2022 at 10:10 AM
    tshop11
    Tyler
    Truckee, CA
    22 Tacoma SR5
    Are you referring to the easily accessible ground bolt or the one circled in red?
  9. Feb 11, 2022 at 10:41 AM
    mwrood
    The one circled in red. It’s super easy to remove with a 10mm deep socket. That’s what I use for grounding in the cab other than my amp.
  10. Feb 11, 2022 at 10:45 AM
    tshop11
    Tyler
    Truckee, CA
    22 Tacoma SR5
    Gotcha. Only problem I have now is my ground wire isn't long enough to reach there and everything is tucked nice and neatly under the center console which I don't want to remove again. What would you recommend to extend the ground wiring?
  11. Feb 11, 2022 at 10:49 AM
    mwrood
    Best solution would be to remove the console again. Personally I’m not a fan of extending wires. With that said, you can use a butt connector and extend it but you need to make sure the connection secure. I’d also wrap some electrical tape around the bottom connector and the wire on both sides of the butt connector to protect it.
    Another option would be to use the ground i point under the drivers seat. There might be one under the passenger seat as well, but I don’t know for sure. I’ll see if I can find a picture. It’s a 10mm bolt as well just like the one you had circled in red.
  12. Feb 11, 2022 at 10:54 AM
    mwrood
    Couldn’t find a picture of the actual bolt but it’s under the carpet in the area i circled in red. There’s one under each seat. You don’t have to take the seat all the way out of the truck tho. Just remove the bolts and tilt the seat back so you have some working room underneath it. Kick panel and scuff panel need to be removed and then you can just lift the carpet up from the side and you should see the bolt. It’s grey and about halfway between the door frame and the center console.
  13. Feb 11, 2022 at 12:19 PM
    tshop11
    Tyler
    Truckee, CA
    22 Tacoma SR5
    Thanks a bunch. I'll try to get to this today and let you know how it goes.
    mwrood[QUOTED] likes this.
  14. Feb 11, 2022 at 12:22 PM
    mwrood
    Sure thing! Good luck!
    tshop11[QUOTED] likes this.
  15. Feb 11, 2022 at 5:34 PM
    tshop11
    Tyler
    Truckee, CA
    22 Tacoma SR5
    I ended up being able to pull a little bit of more slack out and got it grounded to the correct bolt. Thanks again
  16. Feb 11, 2022 at 6:31 PM
    mwrood
    No problem! Glad you got it worked out.
