Grommets and spark plug tube seals that come with valve cover gaskets
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Dec 17, 2021.
  1. Dec 17, 2021 at 6:32 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    I was browsing valve cover gaskets to RockAuto and noticed that some come with grommets and spark plug tube seals.
    Are the "spark plug tube seals" the rubber washers that go with the bolts that go near the spark plug tubes?
    What are the grommets? Do they go around each hole on the valve cover next to the gasket?
  2. Dec 17, 2021 at 6:38 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Jimmyh likes this.
  3. Dec 17, 2021 at 6:40 PM
    foampile
    Mid-Atlantic
    So what do you call the rubber washers that go on the three long bolts in the middle of each valve cover?
  4. Dec 17, 2021 at 6:42 PM
    TnShooter
    Deogee
    STOCK
    Seal washers.
  5. Dec 17, 2021 at 6:43 PM
    foampile
    Mid-Atlantic
    Are they sold separately?
  6. Dec 17, 2021 at 6:55 PM
    TnShooter
    Deogee
    STOCK
    foampile[QUOTED][OP] likes this.
  7. Dec 17, 2021 at 9:17 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You'll find v/c gasket sets with and without sealing washers
    But you usually won't find sealing washers by themselves
  8. Dec 18, 2021 at 8:33 AM
    foampile
    Mid-Atlantic
    Yeah, I might take the risk and reuse the old ones, which do look like they've seen better days. Simply because replacing them after the fact is easy (accessible), just remove the air intake to reach.
  9. Dec 18, 2021 at 8:49 AM
    TnShooter
    Deogee
    STOCK
    The important part is that you get the RTV in the correct spots.
    It’s in one of the link I posted on one of your post.
  10. Dec 18, 2021 at 9:02 AM
    foampile
    Mid-Atlantic
    Do you use the RTV to hold the gasket in place so it doesn't fall out upon the installation (as it goes on the underside of the valve cover)?
  11. Dec 18, 2021 at 9:06 AM
    TnShooter
    Deogee
    STOCK
    No, you use it where the valve cover, the the block, and timing cover come together.
    Other wise there is a good chance you will have a leak.
    foampile[OP] likes this.
  12. Dec 18, 2021 at 9:08 AM
    foampile
    Mid-Atlantic
    If you are referring to all the 3 coming together, I am pretty sure the valve covers do not mate against the block anywhere. The timing cover does mate both of the other 2 but not in the same place.
    I am guessing you meant where the timing cover mates against the valve cover and where the former again mates the block.
    But isn't the seal between the valve cover, the timing cover and the cylinder heads done by the valve cover gasket ?
  13. Dec 18, 2021 at 9:11 AM
    TnShooter
    Deogee
    STOCK
    Yeah, I meant head.
    Anyways, post #2 above. Step 9(b).
    First picture.
  14. Dec 18, 2021 at 9:12 AM
    foampile
    Mid-Atlantic
    OK, that makes sense. In my frame of reference, the heads are not part of the block.
  15. Dec 18, 2021 at 9:14 AM
    TnShooter
    Deogee
    STOCK
    They are not part of the block.
    I said the wrong thing.
    Here is an example
  16. Dec 18, 2021 at 9:16 AM
    foampile
    Mid-Atlantic
    Good idea to cover the air intake shafts with a rag so that shit doesn't fall into the cylinders.
