Groaning noise when steering at slow speeds
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fletcher37, May 10, 2021.
  1. May 10, 2021 at 9:33 PM
    Fletcher37
    Fletcher37 [OP] Well-Known Member
    PNW
    Hi guys, I’ve got a new groaning noise when steering at low speeds.
    Truck is 2019TRD OR with 2-3” lift up front installed last summer. 28k miles on truck. Has ecgs and diff drop too. Power steering fluid level looks good.
    Any guesses where to start?
    Will post up a video soon...
  2. May 10, 2021 at 9:50 PM
    Fletcher37
    PNW
  3. May 10, 2021 at 10:01 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Ball joints? Jounce bearing? :oops:
  4. May 10, 2021 at 10:05 PM
    Fletcher37
    PNW
    Had a buddy come over and turn the wheel while I listened under the truck. Does seem to come from the R side lower ball joint. But hard to say. Maybe I'll start there.
  5. May 11, 2021 at 4:52 PM
    Fletcher37
    PNW
    So the ball joint test of checking for play in the 12&6 o’clock position is negative. I get play at 3&9 o’clock Both front wheels. Tie rods?
  6. May 11, 2021 at 4:56 PM
    boston23
    boston23 Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    Hopefully its a simple fix
    My parents Durango groaned when it was low on power steering fluid
  7. May 11, 2021 at 5:23 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Does it do it when you drive ? If it’s just on your driveway it’s the tires rubbing against the concrete . Try different surface area to see if it does it .
  8. May 11, 2021 at 5:31 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Does you lift kit expect periodic grease? Look for Zerk fittings and hit them with grease. Drive it and try again.
  9. May 11, 2021 at 5:49 PM
    Fletcher37
    PNW
    Power steering level is good. No zerks on suspension.
    Guess I’ll take in to the shop. Doubt warranty covers anything after lifting the truck.
  10. May 11, 2021 at 6:29 PM
    Fletcher37
    PNW
    It groans on any surface.
  11. May 11, 2021 at 6:39 PM
    GOTSAND?18
    stock
    Sounds like u might have a power steering issue . A bad pump ..possibly .
  12. May 11, 2021 at 9:21 PM
    Fletcher37
    PNW
    Checked the tie rods. Seem solid with no play in themselves. I realized that the 3-9 o'clock play on one wheel also moves the opposite wheel. So something up with my steering rack or bushings?
  13. May 22, 2022 at 3:11 PM
    Lurod
    Lurod Active Member
    Luis
    2016 White Tacoma
    I have the same issue, groaning coming from the power steering rack and there is evidence of oil/grease leak on the rack dust boot on the driver's side. The noise has been getting louder in the past week. Still not clue what it is. Were you able to decipher what's causing the noise?
  14. May 22, 2022 at 3:38 PM
    Fletcher37
    PNW
    I think it turned out to be a bad upper control arm ball joint. My drivers side UCA ball joint had a small tear in the boot. New ball joints fixed the noises.
  15. May 22, 2022 at 4:35 PM
    Lurod
    Lurod Active Member
    Luis
    2016 White Tacoma
    Did you replace the ball joint yourself?
  16. May 22, 2022 at 5:14 PM
    Fletcher37
    PNW
    Yes, I got a loaner ball joint tool kit from O-Reillys and bought new ball joints. I have Ironman UCAs and they use OEM style ball joints.
    Check your UCA ball joints first. Mine was cooked. Super loose, floppy and grinding.
    https://youtu.be/zlVd01r7AOc
  17. May 23, 2022 at 6:22 AM
    FloridaFree
    FloridaFree Well-Known Member
    TRD OffRoad 4x4 mgm
    OME 887 with nitro chargers, icon add a leaf ECGS bearing former 886
  18. May 23, 2022 at 8:01 AM
    Lurod
    Lurod Active Member
    Luis
    2016 White Tacoma
    I do not have a sway bar.
  19. May 23, 2022 at 8:07 AM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Mine does it too, I have uniball UCAs and a 2” lift.
    I saw on a thread here race car parts make race car sounds and have stuck to that when I hear the groans or squeaks
    reallifedog likes this.
  20. May 23, 2022 at 8:10 AM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2018 TRD Sport 4X4 DCSB
    how does the ball joint cause PS groan?
