Grinding noise when starting uphill?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dtown223, Jun 5, 2020.
  1. Jun 5, 2020 at 8:39 AM
    dtown223
    dtown223 [OP] New Member
    Dave
    2020 Black TRD off road premium
  2. Jun 5, 2020 at 9:10 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    It is all in the owners manual.
    I'll throw you a hand here it is called hill assist. Keeps from messing up your transmission.
    When this happens look at your gauges it should have a light flashing letting you know this is happening. Look inside the manual to confirm the symbol
  3. Jun 5, 2020 at 9:11 AM
    cabotsteward
    cabotsteward Member
    Cabot
    2020 Cement TRD Off-Road
    That's the traction control/abs pump firing... It's not a grinding noise and more of the sound just the pump firing, it is either caused because the car thinks it's tires are slipping or because the pump/tc is malfunctioning (had this happen on my 2020 OR.). The few questions I would ask is if you go really slow onto the power does it happen? Do you have a lot of weight in the bed (500+ pounds), and how steep the grade is. The reason it makes these noises in crawl mode is because that relies on the ABS pump to work, the first time I used crawl mode in the snow I thought mine was broken and just did it manually.
    Edit: I would say it is probably okay, but if it is happening excessively, go ask your dealer to go on a drive with you for like 5 minutes. It's a 2020, they can tell you if it's normal or not, even the sales representative who sold you it would be able to tell you more.
    dtown223[OP] likes this.
  4. Jun 5, 2020 at 10:02 AM
    dtown223
    Dave
    Thanks for the replies all!
  5. Oct 23, 2020 at 10:50 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Good. It's working well then.
    Junkhead likes this.
  6. Oct 23, 2020 at 11:09 AM
    AgTaco98
    AgTaco98 Well-Known Member
    Edmond, OK
    2020 DCSB 4x4 TRD OR
    My 20 does the same in the driveway with the addition of the Traction Control light illuminating on the dash when it does.
    69008 likes this.
  7. Oct 23, 2020 at 11:18 AM
    mchertel
    mchertel Well-Known Member
    Mark
    Colorado Springs CO
    2020 Tacoma Off-road
    Toytec 2 inch boss lift
  8. Oct 23, 2020 at 11:18 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I didn't realize hill-start assist used the ABS brakes (I have a 6MT which does not have hill-start assist). I've never had a problem starting on a hill with an automatic transmission. They seem to hold their position on a hill at idle without any help needed. When does ABS hill-start assist come into play?
  9. Oct 23, 2020 at 11:25 AM
    mchertel
    Mark
    Colorado Springs CO
    On a hill that is too steep for the truck to “hold its own” and begins to move backwards. Which BTW is not good for a vehicle to do this on a hill anyhow. But for those not quick enough to hit the gas on a hill it’s there as a safety feature I guess.
  10. Oct 23, 2020 at 11:41 AM
    gudujarlson
    Minnesota
    I experience that all the time with a manual transmission but not with an automatic. Thus I am curious why the AT has hill-start assist and the manual does not. Originally I thought it was it because it was easy to implement in the auto transmission, but it sounds like that's not the case. Could the ABS-based hill-start assist not just as easily be implemented with the manual transmission where it seems more needed?
    Ditto for multi-terrain select and crawl control. Why are those deleted with the MT? I can understand crawl control could present challenges because of the clutch vs torque converter, but I can think of no extra challenges for MT-select. My only guess is that Toyota thinks that a buyer who selects a MT is not going to miss those features because that buyer is more DIY-oriented.
    I enjoy my manual transmission for the most part, but starting on a steep grade with a cliff behind me is a time when I wish I had an AT. lol
  11. Oct 23, 2020 at 12:12 PM
    mchertel
    Mark
    Colorado Springs CO
    I don’t have a good answer for that. I had a 2010 Rubicon that was a MT and I am pretty sure that had it. I know the 2012 Wranger Sahara did but that was an automatic. I don’t like the way Toyota works though using ABS. The Jeep you just took you foot off the brake and it held for up to I think 3 seconds or until you put on the gas.
  12. Oct 23, 2020 at 12:18 PM
    gudujarlson
    Minnesota
    Why do you find it “god awful”? Rolling backwards off a cliff seems less desirable to me. To each his own! :)
  13. Oct 23, 2020 at 12:20 PM
    Anton338
    Anton338 Ill-Known Member
    Anton
    New Jersey
    2018 TRD Off-Road DCSB
    Mostly electrical shit that nobody cares about.
    You mean hold the brake while applying the accelerator and then releasing the brake to prevent it from rolling back on a hill? Yeap, I do it all the time. Works just fine, just be gentle with it.
    You can also use the hand brake similar to the way you'd start an old manual uphill.
    69008 likes this.
  14. Oct 23, 2020 at 12:20 PM
    mchertel
    Mark
    Colorado Springs CO
    I hear you, I hate it. And I rarely use crawl control foe the same reason. Only if I am going down a very steep grade while 4-wheeling. It must be new to 20+ maybe? This is my first Tacoma so dunno. I can make it happen though so I know it’s just the Hill Assist. The FJ never did it that’s for sure.
    69008 likes this.
  15. Oct 23, 2020 at 12:25 PM
    mchertel
    Mark
    Colorado Springs CO
    I know, also so many “features” use the ABS system in these new trucks that it will probably be one of the first things that goes out......I just tend to drive more and worry less!!
    69008 likes this.
  16. Oct 23, 2020 at 12:25 PM
    Anton338
    Anton
    New Jersey
    I agree, I think it's a dumb feature. Plenty of manufacturers do "hill assist" correctly. Honda, Chevrolet... by engaging the normal brake for X seconds until it senses an application of the accelerator.
    EDIT: Also a shame since we know that the Tacoma CAN perform a brake application on it's own (evidenced by brake assist and adaptive cruise braking). That's a bit of speculation on my end though.
    mchertel and 69008 like this.
  17. Oct 23, 2020 at 12:34 PM
    gudujarlson
    Minnesota
    If it’s the same noise I hear on my 2020 TRD OR 6MT when traction control is operating, I don’t find it god awful but it was certainly disconcerting the first time I heard it. The ABS system on the OR/Pro is louder than the one on the other trims presumably because it’s beefier.
    Anton338 and 69008 like this.
  18. Oct 23, 2020 at 12:36 PM
    Anton338
    Anton
    New Jersey
    The first time I ever attempted to use crawl control, I thought my transmission ate itself.
  19. Oct 23, 2020 at 12:39 PM
    gudujarlson
    Minnesota
    I was about to ask that question. Most of the traction control stuff can be disabled via a button push. I disable TRAC/VSC on a regular basis, but I’ve never found a need to disable ATRAC. If ATRAC is making a racket it means I’m having fun.
  20. Oct 23, 2020 at 12:45 PM
    gudujarlson
    Minnesota
    My eyes are always glued to the inclinometer, thus the other lights don’t bother me.
    69008 likes this.
