GRINDING NOISE COMING FROM DRIVER SD FRONT WHEEL!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by knee2belly, Mar 20, 2011.
  1. Mar 20, 2011 at 8:46 PM
    knee2belly
    knee2belly [OP] Member
    Oahu
    tacoma 4x4
    hey everybody i was hoping someone could help me out, i got a loud grinding, metal on metal sounding noise coming from my driver side front wheel on my 03 tacoma. this has been going on for a couple months now but starting getting really bad the last couple of weeks ago, every time i would jack the truck up to see what it is i couldnt find anything nothing loose no marks or scratches so i started thinking it could be the wheel bearing. jacked it up again shook wheel left to right there was a small amount of play but looked like it was just the steering, spun the tire and now i could here a little bit of noise so i figured thats gotta be it. changed both side wheel bearings.....still have the problem. if anyone here could give me some advice on what else it could be i would really appreciate it! oh and something i notice, i only hear it in between 5-20 miles and hour and it seems like it might make more noise when i turn right. also i have a manual locking hub conversion. thanks guys.
  2. Mar 20, 2011 at 8:55 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    your brake pads worn down? chexh to see if that tin dust sheild behind the rotors isnt bent and hitting the rotors...this happened to me and it only happened between those speeds to and real bad on right turns. i just took the wheel off and bent it back alittle with my hand. i think i bet it while putting my tires on
  3. Mar 20, 2011 at 11:38 PM
    knee2belly
    Oahu
    tacoma 4x4
    ya i checked the brakes and everything is good, i cant find anything that is bent or scratched or rubbing. i was thinking maybe my manual locking hub is no good but im not sure how exactly to tell.
  4. Mar 21, 2011 at 6:05 AM
    Brad H
    Brad H Well-Known Member
    Lisbon Falls, ME
    01 4x4 SR5
    Deck Plate, Marlin Crawler Rear Bumper, All-Pro APEX Front Bumper and Skids, Bilstein 5100s w/ Eibach Springs front, Wheelers 5Pak w/ OME, '01 Tundra Front Brakes, CBI Bolt-on Sliders, More to come
    Try bending your dust shields back as Sir said. Mine was doing the same thing when I first bought the truck. Even though it didn't look like they touched I did it anyways and poof no more noise.
  5. Mar 21, 2011 at 8:02 AM
    ywen
    ywen Well-Known Member
    does it go away when you engage 4wd?
  6. Mar 21, 2011 at 12:45 PM
    knee2belly
    Oahu
    tacoma 4x4
    yesterday i took the cap of my driver side hub and there was no grease in there so i packed a bunch in then put the cap on put it in 4 wheel drive drove it for a couple of minutes (no noise) then got out unlocked the hubs, disengaged 4 wheel drive and so far i don't hear any noise! so i don't know if its fixed but its not making the noise anymore. what do you guys think?
  7. Mar 21, 2011 at 10:17 PM
    knee2belly
    Oahu
    tacoma 4x4
    well truck started making the same noise again so im guessing its the locking hub, anyway to tell how its bad aside from this noise?
  8. Jul 5, 2011 at 6:13 PM
    NSP
    NSP New Member
    knee2belly
    I think I have the same noise, I took it to a local repair shop, as I thought is could be the passenger bearing. It gets bad as I drive at about 20 or so mph at a gradual turn to the right. It appears to be getting worse as I now hear it even when going straight. It will stop when I apply the brake slightly. Could this possibly be a hung up brake caliper?
    What was wrong this your truck?
  9. Jul 6, 2011 at 6:07 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I have a wheel grinding too... I found it to be the noisemaker thing on the brake pad to tell you when it's getting thin. Mine goes away as soon as I hit the brakes though, which is weird but in order to understand it you just have to see it. I'm assuming you've eliminated the brakes as a culprit already?
  10. Jul 6, 2011 at 7:22 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    When you did the manual hub conversion did you re-pack the bearings with grease ?? I ask this because you said you threw some grease into dust cap which could temporarily stop your noise but unless the bearings are packed correctly (by forcing grease into the bearing/bearing race)
    They're still going to be dry, this assuming you KNOW its not thin pads wearing against the rotor....;)
  11. Jul 7, 2011 at 9:26 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Jack the tire off the ground spin the wheel. If its a bearing you should be able to grab the tire at 12 and 6 and there might be a bit of wobble. Spin the tire if you hear a grinding (not the cv binding) probably a wheel bearing. If it is the brakes there is a possibility you have a frozen caliper that wont retract causing the brake pad to be permanantly applied to the rotor.
    Edit: if it is a frozen caliper one of your pads could be completley worn and the other pad still in perfect shape.
  12. Jul 11, 2011 at 1:29 AM
    knee2belly
    Oahu
    tacoma 4x4
    had the hub conversion done by a well known shop in hawaii almost 3 years ago so i dont know if it was re-packed but i would assume they were just by there good reputation. i also changed both side wheel bearings cause it seemed that there was a little bit of play and slight grinding when i jacked the truck off the ground but at the end of the day i got new wheel bearings and still have the same problem. i still havent changed the hubs but that might be my next try.i dont know i might just drive till something really breaks then ill know exactly what its is........i hope.
  13. Sep 20, 2011 at 2:40 PM
    03TRDtacotrucker
    03TRDtacotrucker No Road. No Problem.
    Alex
    North Richland Hills, TX
    03 SC double cab TRD SR5 4X4
    TRD supercharger, URD 7th injector, Map 3 ECU, 2.2 URD pulley, Doug Thorley headers, Bear River tru performance hi flow cat, 18" Magnaflow muffler, 6" fabtech lift, 33" Goodyear wrangler tires, the old all pro tube rear bumper, ARB front bumper with smitty built 8k winch, pro comp krawlers 87 series wheels, roof rack, 60" hi-lift jack, K&N intake, grey wire mod, front and rear diff breather mod, G2-performance 4.56 gears w/ royal purple oil, red top optima battery, PreRunner Tiregate with full size spare, Radflo front coilovers, Custom home made front skid plate, rear bilstein 5150 series shocks, Elite sliders w/o kick, Camburg UCA, mech grill with old school TOYOTA logo, ash tray removal Cobra CB radio w/ Firestik - List as of 1-17-18
    there is one thing you dont want to wait and take a chance on and its wheel bearings, waiting to see what happends is just asking for trouble. If you have a bad wheel bearing and hub your running the risk of you driving down the highway and seeing your tire pass you down the road (which is a common thing to happen with wheel bearings that dont get taken care of) Normally when you replace the bearings you would replace the hubs with it since its the same labor to do either or besides needing a bearing press. if you havent replaced the hubs that would be my first plan of action, having the exact same issue with mine just come up the other day so im getting it checked out this weekend. have the same noise at low speed right turns normally (cant hear on highway due to loud ass x terrain tires) so dont know the extent of the wear, but also have a small amount of play on the drivers side where the passenger side has zero play. if you have found an exact fix let me know.
  14. Dec 12, 2012 at 7:08 AM
    mikeal91
    mikeal91 New Member
    I have a 91 Toyota Sr5 v6 5 speed manual. And it is making q rubbing nose it wounds like from the. Right front end wheel well sounds like the breaks are sticking but I just replaced the callipers and pads I don't know what to do can someone give me advice pls I am not sure it quits when I put it in 4x4 wheel drive
  15. Jan 23, 2013 at 3:57 AM
    AZarchitect
    AZarchitect Well-Known Member
    Mesa
    01 PreRunner TRD SR5 2x4
    Stock
    Having same issue on front end. Had the brakes replaced yesterday. Checked both tires for play and only had a slight amount of lay on driver side like many others here. Passenger side had no play at all,,, very tight. I will have the guy swing by again to check for the frozen caliper and the metal thingy that holds the brakes in place. That's a lot cheaper then the wheel bearing quote ($600/wheel, parts and labor) quote I got from dealership.
    What was your ballpark replacement cost for those wheel bearings out in hawaii?
  16. Jan 24, 2013 at 3:11 PM
    knee2belly
    Oahu
    tacoma 4x4
    Cost me about 500 bucks over here. Problem was still there though.
  17. Feb 22, 2016 at 1:06 PM
    Annettematson
    Annettematson New Member
    02 Tacoma
  18. Feb 22, 2016 at 1:07 PM
    Annettematson
    02 Tacoma
    I have an 02 Tacoma doing the same thing but when I got speeds of 50 to 60
  19. Feb 22, 2016 at 6:31 PM
    SPOTSONTROUT
    SPOTSONTROUT Well-Known Member
    ROB
    SOUTHERN ONTARIO CANADA
    03 TRD Stolen
    OME 882,DAKAR LEAF PAC WITH ADDA LEAF,285 TOYO OPEN COUNTRY MT,RACELINE RENAGADES,DECK PLATE MOD, MANUAL HUB CONVERSION
    Op, I had the same issue. It turned out to be my Manual hubs. They just need to be serviced .
  20. Jan 15, 2019 at 7:18 AM
    Jpat14
    Jpat14 New Member
    Jack
    Tacoma
    Anybody ever figure out what the issue is?
