Grind Noise, Front end
Discussion in '1st Gen. Tacomas (1995-2004)' started by IEatPieLeftHanded, Apr 20, 2019.
  1. Apr 20, 2019 at 3:18 AM
    IEatPieLeftHanded
    IEatPieLeftHanded [OP] IEatPieLeftHanded
    Michael
    SoCal
    2000 Tacoma 3.4L 4x4 Manual
    2000 tacoma, sr5, v6, manual 4x4 (automatic disconnecting hubs)
    Long story short, I just replaced the front bearings (koyo) on my rig since one of them went bad. Took the spindles off and brought them to a machine shop to have them pressed out and in. I put eveetevery back together and i hear a grind noise at low speed (could be happening at high speed but it's much more noticeable at low speed). The grinding noise stops whenever I make a right hand turn and I feel is little louder when I make a left hand turn. I checked to make sure the dust sheish isn't rubbing. It also seems like the grinding noise only happens when the wheel is in a specific part of it's rotation, not constant like a break pad wear indicator would be. Also, the noise does not go away when I put in in 4wd. The front end is basically new as and I'm running rebuild cvj axles.
    Any ideas? I want to say something is up with the wheel bearing. Maybe the shop pressed it in incorrectly somehow? I don't want to call them out unless I'm pretty sure that Is the csse.
    Thank you
