Grilling filet mignon
Discussion in 'Food Talk' started by coffeesnob, Nov 20, 2016.
  1. Nov 20, 2016 at 5:24 AM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    What are your basic grilling techniques for a filet mignon? I have grilled hundreds of ribeyes, chuckeyes, strips etc but never one of these. I bought a chunk and the butcher cut them into about 1.5 inch peices. I will be using a gas grill.
  2. Nov 20, 2016 at 5:36 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Sorry, I couldn't help myself.......
    phx13 likes this.
  3. Nov 20, 2016 at 5:53 AM
    cgrhyne
    cgrhyne Well-Known Member
    Cameron
    Lincolnton, NC
    2002 4Runner (the best 3rd gen)
    Bilstein/OME Lift, 5th Gen Wheels, BFGs, fun stuff... Had a 3rd Gen, twin turbo'ed it (traded in on a F150 Gen 2 3.5 Ecoboost)
    Rub with olive oil, few dashes of liquid smoke (cause you have gas) and pepper blend seasoning and refridgerate for 4 hours. Cook at 450 ish for 6 minutes each side and then rotate for the more minutes on each side. Pull when the internals hit 130-135, little butter on top, and let rest for 5 minutes.
    A filet is to good of a cut to put a lot of flavoring to it.
  4. Nov 20, 2016 at 5:55 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  5. Nov 20, 2016 at 6:05 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    subbed for food
  6. Nov 20, 2016 at 3:16 PM
    coffeesnob
    VA
    Glad to say they came out fantastic......
    medic2230, phx13 and wilcam47 like this.
  7. Jan 25, 2017 at 4:25 PM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Lightly coat with olive oil, a little sea salt is how I prep them.
    Then here is where I do mine differently: old some lump charcoal into a chimney, get it going good and hot.
    Place the filet on the grill, and then the chimney over it (filet should be where paper goes to start it). Cook 3 mins or so, then flip. Cool 3-4 more.
    Pull filet and set off to the side of the grill, cook another for your lady.
    Bring both inside and top with garlic butter while they rest.
  8. Jan 25, 2017 at 4:29 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Put them on grill. Crack beer. Add seasoning. Pour beer on meat just a sip or so. Flip. Repeat. Pull off. Finish beer. Eat. BOMB
  9. Jan 25, 2017 at 4:30 PM
    02YotaGuy
    02YotaGuy Guy With A Red 80 Series
    Matthew
    Springfield, VA
    94 FZJ80
    Bumper, Winch, 315s, Sliders, OME HD lift, Custom rear swingout, roof rack, drawers, way too much to list.
    You gots to pronounce it Fill-it Ming-Non or you're doin' it wrong
  10. Mar 15, 2017 at 1:56 PM
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    Lots of good advice, but.... I always let any steak sit out and reach room temperature before I grill it. I mix butter and olive oil 50/50. melt it down and rub it on the filet. I use peppered thick slice bacon to wrap it and stick a tooth pick in it. Salt and pepper only on a high end piece of beef. Get the grill as hot as you can. I keep a therma-pen on me and sear it off. I stop at 135 degrees, and let it rest for 10 mins.
    Now that we covered that, do the same thing with center cut pork tenderloins. I use teriyaki marinades and cut the loin into chunks the width of the bacon. Marinade it for 6 hours, wrap it in bacon. No butter, salt or pepper needed. Same grill setting but run them up to 165. My wife actually prefers it to filet. (not me! but it is a damn close second!!!!)
    Woundedyak and medic2230 like this.
  11. Mar 15, 2017 at 2:02 PM
    medic2230
    Murph
    Bama! Roll Tide
  12. Mar 15, 2017 at 2:09 PM
    Capt Jrod
    Jarrod
    Northern Ohio
    This is what I cook this for my wife every year for our anniversary. We used to go out, but the restaurants kept coming up short.
    wilcam47 and medic2230 like this.
  13. Mar 31, 2017 at 10:26 PM
    hoser1
    hoser1 Well-Known Member
    If your cooking space allows for it, next time keep it as a whole piece. Or try to keep the piece as big as possible and slice when ready to eat. I like cooking that way especially when you have a lean piece of meat like that.
  14. Apr 2, 2017 at 8:42 AM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    Gas grill? It's been a while since I used one of those, but I would set one side to low heat and put a little foil pouch filled with wood chips over it so that it creates a little smoke inside the grill, then place the steaks off to the other side. If you can swing it so that the temp stays around 250* or so (a little higher is fine, probably not too much lower, though), then leave them there until the internal temperature gets to around 105-110*. Take them off and crank one side as high as you can. Close the lid and get as much heat in there as you can, then pop them back on the direct high heat and sear them until internal creeps up to about 125*. Pull them off and tent with a piece of foil. Carryover should bring them up to about 130-132* internal and give a nice medium rare.
    Similar results can be had on a charcoal grill if you set them up right. I use a chimney starter to have more coals ready when it comes time to sear.
  15. Apr 19, 2017 at 5:38 PM
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    sous vide and then sear on the grill or cast iron grill pan.
  16. Apr 19, 2017 at 5:41 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    Cast iron is hard to beat :hungry:
