Grille Shutter Delete
Discussion in '4th Gen. Tacomas (2024+)' started by Mt133677, Apr 10, 2025.
  1. Apr 15, 2025 at 9:13 AM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can
    I meant the temp gauge :anonymous:
  2. Apr 15, 2025 at 9:15 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Right, but that isn't why they installed shutters. They installed them to be more fuel efficient and aerodynamic when cooling is not needed...not to help the engine warm up faster. Modern engines, turbo or not, don't warm up well on their own at low speed or idle conditions. You need to be moving and using the engine to generate heat.
    The shutters may have a very slightly warm up effect, but that isn't why they are there or needed. It is just yet another device to chase after the almighty mpg.
    BearWithMe likes this.
  3. Apr 15, 2025 at 9:16 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    all this talk of thermostat on 4th gen.. are you sure it even has one? it may only have coolant control valve..
  4. Apr 15, 2025 at 9:16 AM
    BLtheP
    Plano, TX
    In my experience, that happens even not in super cold climates. The heater core is ultimately a second smaller radiator, so depending on the routing of the coolant and how that coolant returns to the system, the temps can absolutely drop a bit. Ultimately though, the bottom line and my point is that if you are driving and the thermostat is closed, you are building heat and will warm up.
  5. Apr 15, 2025 at 9:17 AM
    BLtheP
    Plano, TX
    It has a water control valve, which is ultimately executing the same function.
  6. Apr 15, 2025 at 9:18 AM
    Squirt
    Ben
    The temp gauge never reached the midway point that day and the HVAC never put out that much heat. When temps get that low it does affect engine temps. At -20F the IATs are really not helping the engine warm up.
    t0p_d0g and SH10151 like this.
  7. Apr 15, 2025 at 9:19 AM
    Mt133677
    Mt133677 [OP] Well-Known Member
    SoCal
    2020 DCSB TRD OR
    All the things
  8. Apr 15, 2025 at 9:28 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    With the shutters, when it’s negative temperatures, my Macan would struggle to stay above 200°F unless I was moving.
    Squirt[QUOTED] likes this.
  9. Apr 15, 2025 at 11:01 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    yeah.....
    cheap, not need to be an engineer, re-invent the wheel, etc...
    but, if thats your thing....
    Mt133677[QUOTED][OP] likes this.
  10. Apr 15, 2025 at 11:31 AM
    Mt133677
    SoCal
    2020 DCSB TRD OR
    All the things
    Well I’ve already got a prototype I was fine tuning. It’s a little more compact and self contained but does the same thing. I dm’d them to see if they’d sell it individually, tbd
    LN13 likes this.
  11. Apr 15, 2025 at 6:53 PM
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    Running a direct injection engine cold will dilute the oil with fuel. The shutters help regulate the temperature of the engine.
  12. Apr 15, 2025 at 7:44 PM
    Squirt
    Ben
    I forgot but not only does it do that but on the F150 it also helps with condensation build up in the intercooler.
    t0p_d0g[QUOTED] likes this.
  13. Apr 15, 2025 at 8:26 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You guys should discuss temperature regulation in a new thread and let this guy have a place to talk about the product he's designing
    dneal likes this.
  14. Apr 15, 2025 at 8:31 PM
    LN13
    LN13 Well-Known Member
    Dave
    Cave Creek AZ
    2024 TRD OR Hybrid
    So you are fabricating your own for self or to sell?
  15. Apr 16, 2025 at 10:00 AM
    #35
    Mt133677
    SoCal
    2020 DCSB TRD OR
    All the things
    It was for myself but if someone else wants one it’ll definitely be reprintable once I nail down the design. It’ll be more compact than the current wing type designs out there. I’ll post a final pic once I get it all together but this is so you get the idea.
    I’m trying to have it mount to the original two bolts and have the actuator tuck as closely as possible to those mounting points. The idea with the inlayed gear cog was to reduce the chances of debris causing malfunctions since I’ve heard that’s a thing.
    LN13, oldgreg and Squirt like this.
  16. Apr 16, 2025 at 11:56 PM
    #36
    LN13
    Dave
    Cave Creek AZ
    2024 TRD OR Hybrid
    Appreciate the response. I already purchased the SDHQ kit and trying to decide on the logic for the install. Been busy and have to look deeper at overall process for this and what I want to do.---thanks
  17. Apr 17, 2025 at 3:45 AM
    #37
    Iqudayo
    Iqudayo Well-Known Member
    Antonio
    Toyota Tacoma
    I’m seeing a lot of back-and-forth here. Bottom line. What do the shoulders do on the 2024 Toyota Tacoma, what is their purpose and if they are removed what would get damaged, i’m seeing this is something that would possibly void the warranty. Another question would be what about just removing them totally Off the vehicle and leaving it at that
  18. Apr 23, 2025 at 3:18 PM
    #38
    Mt133677
    SoCal
    2020 DCSB TRD OR
    All the things
    If you take off the shutters and actuator it throws a CEL
  19. Apr 23, 2025 at 4:13 PM
    #39
    slater
    San Diego
    yes, we all know this...
    nobody is doing that...
    Point to the statement?
  20. Apr 23, 2025 at 4:21 PM
    #40
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    He was answering a question in the post above his. Cut him a little slack.
    roalddahl and Mt133677[OP] like this.
