Grille removal on 2016,..??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VinTaco, Nov 11, 2015.
  1. Nov 11, 2015 at 6:50 AM
    VinTaco
    VinTaco [OP] Well-Known Member
    Burnaby bc
    2016 Black Tacoma TRD OR
    I want to take my grille off but not sure where all the tabs and screws are, can anyone help me out..? Thanks
  2. Nov 11, 2015 at 6:58 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Sub'd - got some cans of paints on the way.....
  3. Nov 11, 2015 at 7:03 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    dsoulds and VinTaco[OP] like this.
  4. Nov 11, 2015 at 7:25 AM
    VinTaco
    Burnaby bc
    Moose4x4 likes this.
  5. Nov 11, 2015 at 7:33 AM
    splitbolt
    NW Arkansas
    Supereasy.
    See diagram in the link I posted; the top two screws and two trim buttons.
    That releases it. Wiggles out after that. Mine pulled off easier puling one side and angling it out rather than trying to pull the whole thing off at once.
    over60 and VinTaco[QUOTED][OP] like this.
  6. Nov 11, 2015 at 7:39 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Hey split, did you do this mod? How ez is it to get JUST the chrome bezel off?
  7. Nov 11, 2015 at 7:48 AM
    splitbolt
    NW Arkansas
    I went from OR to SR, but my shroud came in chipped so I had to swap over parts.
    But, not hard at all; I think I only broke two tabs. I wasn't really concerned about it's well-being either, since I wasn't re-using it. I stuffed socks as I released them to keep them from re-engaging.
    When I reassembled the leftover parts for storage the chrome bezel was as solid as before. It has a lot of tabs and screws...
  8. Nov 11, 2015 at 10:33 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    After removing the two screws and two push pins, just pull out on it. Mine was "stuck" and then released all at once nearly flying out of my hands.
    ExtraExtra likes this.
  9. Nov 11, 2015 at 10:44 AM
    VinTaco
    Burnaby bc
    Ok, Thanks for the heads up..
  10. Nov 11, 2015 at 10:46 AM
    BlkTaco47
    BlkTaco47 Unhinged
    did just the chrome bezel pop off or all of it?
  11. Nov 11, 2015 at 10:47 AM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Yep, keep a good grip on it and move it up/down side/side as you pull out and it will pop out from the bottom. Don't worry, nothing on the bottom is holding it in except tabs. It's a bit nerve racking the first time you yank it off.
    over60 likes this.
  12. Nov 11, 2015 at 10:50 AM
    VinTaco
    Burnaby bc
    So you don't have to release the tabs at all..?
  13. Nov 11, 2015 at 10:53 AM
    Dean724
    Upland, CA
    I didn't and honestly it would be hard to get your hand in there to move the tabs. Once you take the top 2 bolts off and the 2 plastic side tabs, get a good grip and start pulling out carefully.
  14. Nov 11, 2015 at 12:07 PM
    splitbolt
    NW Arkansas
    Oops. Forgot about the two release tabs. You'll see it on the new shroud and know where to stick your hand. I don't think they're release tabs, so much as locating tabs. They did help to get it started.
  15. Nov 11, 2015 at 12:33 PM
    splitbolt
    NW Arkansas
    dsoulds likes this.
  16. Nov 11, 2015 at 12:37 PM
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    Thanks for the pics! I'm planning to take mine off and plasti dip, just trying to gain some confidence before I do.
  17. Nov 11, 2015 at 12:43 PM
    BlkTaco47
    BlkTaco47 Unhinged
    same here but I'm only removing & doing the bezel.
  18. Nov 11, 2015 at 12:46 PM
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    I might go the line x route after I just read the other thread with the sand colored tacoma. That looks sweet, I wonder if the Empire Line X shop will remove the grill for me or if they even have experience doing it.
  19. Nov 11, 2015 at 12:48 PM
    BlkTaco47
    BlkTaco47 Unhinged
    I plan on using something like that, I'm not going the plasti-derp route.
  20. Nov 11, 2015 at 12:51 PM
    Tacoma2GR
    Hesperia, CA
    2020 TRD Sport 4x4
    I did on my emblems and my ocd bothered me after seeing some of the edges.
