Grill swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by charliecook2003, Mar 28, 2023.
  1. Mar 28, 2023 at 9:30 PM
    charliecook2003
    charliecook2003 [OP] Member
    Charles
    1999 white Tacoma TRD off-road
    A Few
    Hey everyone,
    I wanted to share my experience with the surprisingly easy swap of swapping a 2001-04 grill style onto my 1999 Toyota Tacoma. Although it might sound like a daunting task, the entire project was actually quite straightforward and didn't require a lot of technical expertise.
    The first step was building a retrofit headlight with a custom wiring harness. The process was relatively simple and only required basic electrical skills. This involved cutting and splicing wires, and then wrapping them in a cushioned wiring harness to protect them from wear and tear. Once the harness was complete, I was able to install the new headlights without any issues.
    Next, I swapped out the hood to fit the new grill style. The shape of the new grill was slightly different than the old one, so I needed to use a hood from a 2001-2004 model to get it to fit properly. I was able to find a used hood at a salvage yard and it fit perfectly.
    I also installed a new hood latch to work with the new hood. This involved removing the old latch and installing the new one, but the process was straightforward and didn't require any major modifications.
    Finally, I had to drill out some old headlight brackets and cut the new ones to fit properly. This was a bit more time-consuming, but it wasn't difficult and didn't require any special tools.
    Overall, I was surprised by how easy this swap was and I'm thrilled with the end result. I'm really happy with the results. The new grill looks fantastic on my truck and gives it a much more modern, aggressive look. If you're considering a similar swap, I would definitely recommend it!
    CF61F58E-284A-4CFB-972E-A14463A599A2.jpg 594D1D9B-DB38-4677-A0CB-10BA34DCD5F1.jpg
  2. Mar 28, 2023 at 9:47 PM
    hamsmash
    hamsmash Well-Known Member
    Sacramento, CA
    00 Tacoma 3.4 4x4 5spd
    Looking good!
  3. Jan 1, 2024 at 8:06 PM
    TacoBaco19
    TacoBaco19 New Member
    Aedan
    1999 4x4 Tacoma
    Hey what headlights did you use? I’m super interested in this swap and your post motivates me to do it!
    If you have any more extra info on it let me know!
  4. Jan 2, 2024 at 6:39 PM
    charliecook2003
    Charles
    A Few
    I got the headlights and corner lights off eBay here is the link: https://www.ebay.com/itm/185795056139
    Here are the other items I had to buy
    hood Latch :https://www.ebay.com/itm/350735969053
    Hood: junk yard
    Filler panels: junk yard
    2 Headlight brackets:
    53804-35020 Fender Bracket
    53803-35010 Fender Bracket
    Grill: offer up
    ffpbenson likes this.
  5. Jan 2, 2024 at 6:42 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    That looks great. The 99 turn signals and bumpers really looks good with that style of grille. Any plans to paint or wrap the hood?
  6. Jan 2, 2024 at 7:11 PM
    charliecook2003
    Charles
    A Few
    Here is a updated picture as of Nov 2023
    Hood is painted, color is a little off unfortunately
    Red_03Taco[QUOTED] likes this.
  7. Jan 2, 2024 at 7:11 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Looks Awesome!!!
    if I may, how much did hood set u back?
    just the part…..not paint costs
  8. Jan 2, 2024 at 7:17 PM
    charliecook2003
    Charles
    A Few
    $300
    ControlCar[QUOTED] likes this.
  9. Jan 3, 2024 at 1:42 AM
    DemApples
    DemApples Kainoa HI
    Kainoa
    Kailua-Kona, HI
    1995.5 Tacoma
    Supercharged w/ 7th injector 97 ECU swap 2001 front end swap TRD e-locker rear end swap 6 inch crossmember lift stretched to 11.5” 3 inch body lift 14.5” total lift
    93137DCF-A641-4F56-B89A-1A71BBE25CF6.jpg Crap I wish it cost me $300 for the front clip swap… $500 for the hood, $100 per fender, dozens of hours of body work, $1,900 paint… and now I want to splice in a 2020 grill after seeing someone else with one
    eortxz likes this.
  10. Jan 3, 2024 at 2:26 AM
    Aubrey
    Aubrey Member
    That looks awesome! Very COOL!!!
  11. Jan 3, 2024 at 10:18 AM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Don't. 3rd or 2nd gen anything on a 1st gen is a disgrace to the best gen.
    toastola, tacoma_ca, Nessal and 3 others like this.
  12. Jan 18, 2024 at 11:59 AM
    eortxz
    eortxz Active Member
    Erick
    2004 Tacoma 3.4L 4x4
    That looks really nice!
  13. Jan 18, 2024 at 10:34 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    99-00 front ends are the best front ends....you know you regret it! lol
  14. Aug 30, 2024 at 7:44 PM
    Carson_SR54x4
    Carson_SR54x4 Active Member
    Carson
    Silver 2000 Tacoma SR5
    2 inch leveling kit
    Hello. Your truck looks great and I had a question about your process. I currently have my front end taken apart and I’m confused on what you had to do regarding the “drilling old headlight brackets out” that you mentioned. Later on you send the link to some fender brackets. Can you elaborate what you had to do on this step? thanks you
  15. Aug 31, 2024 at 6:08 AM
    GuavaRoad
    GuavaRoad Well-Known Member
    Agreed, this combo looks great.
    Anybody know anything about replacing a 01-04 bumper with a 99-00 one? I'm tempted to make my 2004 look like this..
    tacoma_ca likes this.
  16. Aug 31, 2024 at 1:40 PM
    AW11
    AW11 Well-Known Member
    Frank
    2002 Dbl Cab 4x4 3.4l
    It does look really good the the 99-00 bumper.
  17. Sep 8, 2024 at 5:53 PM
    charliecook2003
    Charles
    A Few
    From what I remember, I had to drill out the spot welds that held that bracket for the headlights in place. The new headlight mount is designed differently, so you don’t need the old bracket. The new fender brackets needed a little trimming at the ends to fit the front end properly and are now used to mount the new style headlights.
  18. Sep 8, 2024 at 11:01 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Maybe I’m biased, but the 99’ front end looks better :rofl:
  19. Sep 8, 2024 at 11:29 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    To each their own, but doesn’t seem worth it to me to dump money into something that isn’t an actual upgrade other than subjective opinion of what looks better. That money is better spent elsewhere
    ChargedSHOTaco likes this.
