Grill guard / bumper guard Tacoma 1st gen.
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacotaco01, Apr 28, 2018.
  1. Apr 28, 2018 at 1:54 PM
    tacotaco01
    tacotaco01 [OP] Active Member
    2001 Tacoma prerunner 3.4 double cab 2wd
    what will be a good grill guard or more a bumper for my 2001 4 door Tacoma prerunner that is not 4x4 I really like the ones for fwd but I think there are to heavy for my rwd. Any suggestions?
  2. Apr 28, 2018 at 2:53 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I wouldn’t get a pull bar or grill guard if you plan on any kind of off roading, if all you do is take your truck to the mall then go ahead and get one, not that in accident they tend to be damage multipliers to your car. You can get a plate or tube bumper for your truck. They tend to be on the really heavy side, but some ome 881 or 883 would help with that depending on how heavy of a bumper you went with. Do you plan on lifting your truck as well?
    Hamer95USA likes this.
  3. Apr 28, 2018 at 3:16 PM
    tacotaco01
    Not planning on doing a lift since it’s not really for off-roading just my daily driver, although I put some rancho quick lift shocks and it did lift my truck about 2” more, just looking for protection against bad drivers and a few deers
  4. Apr 28, 2018 at 4:12 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Then a grill guard or bull bar wont help. It will just cause more damage
  5. Apr 28, 2018 at 4:47 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Plate bumpers can weigh 100-200 pounds depending on configuration and require heavier coils. The quick lifts may help a little bit but its still gonna sag and hit bumpstops hard. If i were you i would go with a strong tube bumper to save some weight. When i say tube i dont mean a crappy bull bar or grille guard either, like good dom tubing.
  6. Apr 28, 2018 at 5:09 PM
    tacotaco01
    @MurderedTacoV2 thanks 4 the advise
  7. Apr 28, 2018 at 7:01 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    MurderedTacoV2 likes this.
  8. May 23, 2018 at 9:50 AM
    BrandonF
    BrandonF Member
    boostedka and Sperrunner like this.
  9. May 27, 2018 at 2:42 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
  10. May 27, 2018 at 3:17 PM
    BrandonF
    BrandonF Member
    I don't know the number of pieces off the top of my head but with everything perfectly CNC cut, it fits together really easily. No need to even touch the angle grinder besides beveling a couple edges before welding.
    This is from the website FAQ page:
    All of our bumpers are very simple to weld together and come with detailed instructions containing step by step guides and clear and concise diagrams. With all of the pieces precision cut by CNC and all mounting and accessory holes already cut, everything fits together like a puzzle. Simply remove the stock bumper, bolt the provided mounting plates to your frame, and start assembling the bumper piece by piece, starting from the vehicle frame and working outwards. The vehicle and the pieces themselves act as guides so there is no need for specialty welding jigs or tools.
    In fact, long before I started Coastal Offroad, I designed and welded together the original prototype front bumper as my very first welding project (I am a mechanical engineer by trade). The welds were far from pretty but nearly 3 years later, that bumper is still installed on my personal vehicle as a testament to how robust and user-friendly these weld-together kits are. After countless winch pulls and direct impacts with rock faces, the bumper continues to perform.
    UtahTacoma02 likes this.
  11. Jul 14, 2019 at 9:43 PM
    03dbprerunner
    03dbprerunner Well-Known Member
    Erik
    2003 dc taco
    King coilovers and 10" 2.5 smoothies in rear
    Willrox1 likes this.
  12. Jul 15, 2019 at 7:57 AM
    Willrox1
    Willrox1 Well-Known Member
    Will
    NC
    2002 Tacoma TRD Off-road - manual
    BFG AT KO2 31 Bilstein 5100 OME 883
  13. Jul 15, 2019 at 9:16 AM
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    do aftermarket bumper affect airbag deployment ?
  14. Jul 15, 2019 at 9:49 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    no
    There are no sensors or anything in the bumpers. The airbags are deployed using inertial sensors, and are independent of the bumper.
  15. Jul 15, 2019 at 9:51 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    ARB claims that their bumper "works with the stock airbag sensors" but more than anything I think that just means that ARB is the only company that's paid to have the official testing done so that they can make that claim. I bet most if not all aftermarket bumpers still "work" with the airbag sensors, but to claim that they do you'd have to go through the proper channels and tests that ARB did. Most fab shops and small businesses aren't gonna do that.
  16. Jul 15, 2019 at 9:53 AM
    jbrandt
    Justin
    DIY bumpers are totally doable. Good for a novice (like me). I would have preferred a bigger welder than my 125, but it (eventually) got the job done.
    Keep in mind that when you go the low profile bumper route there is more than just bolting it on (after it's assembled). I relocated my washer fluid reservoir, and did a bunch of trimming to the body panels and fender liners.
    Here's a link to my build thread of the CBI DIY kit, this should give you an idea of the work involved:
    https://www.tacomaworld.com/threads/diy-1st-gen-tacoma-front-bumper.584372/
  17. Jul 15, 2019 at 9:54 AM
    jbrandt
    Justin
  18. Jul 16, 2019 at 12:12 AM
    BrandonF
    BrandonF Member
    It is the Grote #45823 Signal light with the #92120 Grommet and #67050 Pigtail. The Triden EP35 Electronic Flasher can be swapped into the fuse panel to return the flashing speed back to stock (The LED's have a lower resistance value and will hyper flash as if there is a burnt out bulb).
  19. Jul 16, 2019 at 11:31 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    They're required to test for airbags in Australia in order to sell them.
    eon_blue[QUOTED] likes this.
