Grill Bezel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ghetto, Apr 22, 2024.
  1. Apr 22, 2024 at 10:21 AM
    Ghetto
    Ghetto [OP] living vicariously through myself
    Hey folks, hope all is well.
    After a recent scare of almost trading my taco in, I've been doing a lot of cosmetic modifications to my truck. One of the things I've wanted to do for a LONG time was change out the chrome grill bezel to one that is black.
    Not sure the formatting of messages here so I'll post the link to the part below. My question(s) are
    1. Any chance someone has come across an "overlay" type piece that attaches via 3M tape or anything?
    2. If not, I've watched many vids on how to actually replace this out the correct way. I'm mechanically inclined and handy with tools, but hoping for some alternative than taking the grill off to do a replacement - so does anyone have any actual experience with alternatives to swapping out the piece?
    https://www.amazon.com/JMTAAT-Grill...37------------&vehicleName=2018+Toyota+Tacoma
  2. Apr 22, 2024 at 1:17 PM
    Ejctt
    Ejctt Well-Known Member
    2023 White Tacoma Off-road
    You could take it to a wrap shop and have them wrap it in whatever color you want, don’t know how much that would be. If you really want to do it right take the grille off, it’s not that hard and not that time consuming for a great result.
  3. Apr 22, 2024 at 1:25 PM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    Threre aren't any overlays that I am aware of. Some guys have plasti dipped theirs but I chose to replace mine. There's really no way to change that surround without removing the grill. Removing it though is very simple, remove two screws and two plastic pins, unplug the TSS sensor harness then give it a firm tug and it pops right out.
  4. Apr 22, 2024 at 1:25 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    You're over thinking it. Pull the grille (2 screws, 2 tabs), push the clips, paint the trim, and replace.
    Give yourself 30 minutes.
    TS4x4 and roboturner like this.
  5. Apr 22, 2024 at 5:37 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Buy a trd grill and no more trim pieces. Pulling the bumper is pretty easy. Give yourself something to lay it front side down on. You'll want something soft so you don't scratch it, I use a moving blanket. Other than that it's just a bunch of screws.
  6. Apr 23, 2024 at 6:56 AM
    Ghetto
    So this is something I was also looking in to. Love the look of the TRD grills, but I had concerns with relocating the sensor. I've found a few that look simple with the tutorial videos, but I dont want to be one of those guys that try to do it, fail, and then have to say "but the guy on YouTube said..."
    Any links to decent swap vids?
  7. Apr 23, 2024 at 7:56 AM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    You don't need to remove the bumper to get to the grille, you can access the tabs from the top, that being said, it takes only a few minutes, really not a hard task. Sensor problems with the Pro grille are pretty rare, if you need to you can add a washer to tilt the sensor a bit, but I didn't need to anything. If you do swap to the Pro grille, the sensor just unscrews from the back (2 screws IIRC) and you just screw it into the new area on the Pro grille. I'd suggest buying an aftermarket plastic honeycomb protector, Toyota's are way over priced and it doesn't really effect the sensor or do anything.
    If you're in CO I have a black surround you can have for free if you want to keep the OG grille
    https://www.youtube.com/watch?v=ipD48yDQuMc&ab_channel=CluEngineer
  8. Apr 23, 2024 at 2:22 PM
    czukie
    czukie Well-Known Member
    Colorado
    ‘23 Tacoma Access Cab
    What do you mean by “honeycomb protector”?
  9. Apr 23, 2024 at 8:10 PM
    roboturner
    Colorado
  10. Apr 25, 2024 at 7:00 AM
    Ghetto
    Thanks for all the replies! I think I'm just going to tough it out despite my lack of self confidence and replace it myself. All for the sake of cosmetics... HAH
    Wish me luck!
  11. Apr 25, 2024 at 7:04 AM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Super easy! Just take your time pulling all of the little tabs off. I put a folded towel where the garnish is to give an area for the trim piece to fall down to. If it’s fully flat against the ground sometimes they don’t free as easily
