Green bottle propane vs 5lb tabk
Discussion in 'Off-Roading & Trails' started by Mr. Excitement, Jan 24, 2024.
  1. Jan 24, 2024 at 5:44 PM
    Mr. Excitement
    Mr. Excitement [OP] Well-Known Member
    J
    Custom floormats, fuzzy dice
    So I have a buddy heater and a blackstone griddle I run camping. I’ve noticed that they run way better off the green bottles than my 5 lb or 10 lb propane tank. Anyone else experience that? My griddle runs but never gets that hot and the buddy heater kept flaming out. Might buy one of those in line filters but wasn’t sure if it might be related to more pressure in the 5lb tanks? I didn’t think the small blackstone or buddy had built in regulators, but maybe. Curious if anyone else experiences this. My normal stove runs fine.
  2. Jan 24, 2024 at 5:45 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I hace a 5 pounder and never had an issue with it and it lasts forever ever
  3. Jan 24, 2024 at 11:04 PM
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
    I've run my buddy heater with my 5lb, no problems. The buddy heater flaming out or sputtering I've found that is due to the heater not being level.
  4. Jan 25, 2024 at 3:54 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Try a different 5lb tank. I've never had an issue with mine.
    boston23 and Mr. Excitement[OP] like this.
  5. Jan 25, 2024 at 7:16 AM
    Mr. Excitement
    J
    That’s weird, it’s a new 5 lb tank, but I refill it at my local propane place. I have another 10 lb tank I’ll try. Wonder if i need a filter for it or something
  6. Jan 25, 2024 at 9:00 AM
    slowpoke16taco
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stupid question, but I'll ask...is your tank full? Should weigh ~13 lbs full, 8 lbs empty.
  7. Jan 25, 2024 at 9:07 AM
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    It might be the safety regulator on the 5lb tank. Try this: close the regulator, remove and reattach the heater (make sure the valve on it is closed), then crack open the valve on the tank so slowly it seems ridiculous. Do this at every use. That should fix the problem.
    I’ve got the same tank and experienced low gas flow until someone clued me in on this process. Hope it helps.
  8. Jan 29, 2024 at 12:47 PM
    timclark82
    timclark82 Active Member
    I had this issue with the hose I was using that adapted the 5lb to the 1lb fitting. The Weber ones I was using would eventually fail and not seat fully which would cause reduced flow until the plastic spacer would finally crack and fall out which would end up causing no flow.
    You can see others have had this issue with the Weber hose from the reviews on Ace Hardware
    https://www.acehardware.com/departm...s-and-smokers/grill-replacement-parts/8212599
    The ones I use now are from Amazon and have not given me any issues so far for over a year of hard use.
    https://www.amazon.com/gp/product/B07Q7MXZR5?ie=UTF8&th=1
    TyBud850 and Mr. Excitement[OP] like this.
  9. Jan 30, 2024 at 12:44 PM
    Mr. Excitement
    J
    Thanks. So I hooked up my 10 lb tank and the buddy heater worked fine. The 5 lb tank has a built in gauge. Wonder if that’s some how messing with it. I have a spare hose though. I’ll try that as well. Thanks
    timclark82[QUOTED] likes this.
  10. Jan 30, 2024 at 12:50 PM
    IEsurfer
    Socal
    Did you get the 5 pound one from Costco? My 5 pound one came from Costco with the built in gauge i never had an issue in fact I have 2 of them but things do get faulty
  11. Jan 30, 2024 at 1:00 PM
    Springsboy
    Springsboy Well-Known Member
    Colorado
    2013 4x4 DCSB SR5
    Full RCI skids RCI bolt on sliders with extra two bolts/side ADS reservoir coil-overs front Bilstein 5100 shocks rear Icon RXT leaf springs, set on option 3 Rear Eaton E-locker, built by ECGS CBI Moab 2.0 classic bumper Diode Dynamics SS3 Pro white fog lights Leer Cap
  12. Jan 30, 2024 at 1:14 PM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    I've had two different propane "gauges" on my 5lb tanks that gave me issues always at the worst times. Thankfully you can just unthread them and carry on.
    Gauge is just one more leak point...
    Mr. Excitement[OP] likes this.
  13. Jan 30, 2024 at 2:32 PM
    Mr. Excitement
    J
    Yup, it’s the 5 lb one from Costco. I have another hose I’ll try. Just was annoying when it was cold out and needed the heater and it wasn’t working. I think the gauge is built in so not many options. I guess just use it for something else. Or maybe get it refilled somewhere else
  14. Jan 30, 2024 at 3:27 PM
    IEsurfer
    Socal
    You can always return or exchange it I know it’s a pain but at least you know my 5 pound Costco one works fine with my heater buddy maybe it’s your coupler hose?
  15. Jan 30, 2024 at 8:46 PM
    Mr. Excitement
    J
    I suppose. I bought the tank like 2 years ago so not sure they would still take it. I’ll try another hose and see if that’s it. Just kinda sucks since that tank is the most portable.
  16. Jan 30, 2024 at 8:57 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    I had this same issue with my blackstone 22 when switching from 1 pound bottles to a tank that requires the 1 pound propane tank adapter line. I had one weber line and one off brand line and they wouldn't flow as much as the 1 pound bottle. Kind of odd I thought, but then I decided to pick up an actual blackstone branded adapter line that happened to be in stock locally. Low and behold that seemed to do the trick.
  17. Feb 18, 2024 at 8:32 PM
    Mr. Excitement
    J
    So turned out it was the hose. Pressed the schrader valve thing in and gas barely came out. Popped another hose I have in there, and the gas came out really solid. Hope that solves it. Still like the green bottle for some stuff but this will be way better for longer trips. Thanks
    BC Hunter and timclark82 like this.
  18. Feb 18, 2024 at 8:33 PM
    Mr. Excitement
    J
  19. Sep 25, 2024 at 6:29 PM
    TyBud850
    TyBud850 Well-Known Member
    Tyler
    Defuniak Springs, Florida (NWFL)
    2012 Black Tacoma DC TRD-OR
    3” lift Icon 2.5 shocks king 650 coils, ALCAN LP W/Sumo springs & FOX 2.0, CBI MOAB 2.0 Front Bumper w/Smittybilt X20 10K winch, CBI Rock Sliders, Mobtown Reinforced Steel Skids & Bed Bars, CBI rear bumper,
    sounds like a bad hose or regulator?
  20. Oct 14, 2024 at 9:49 PM
    Mr. Excitement
    J
    Yeah, new hose solved everything. Now everything is awesome….
    photodoc, essjay, boston23 and 7 others like this.
