Grease fittings 2021 4x4 extended cab
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Partschanger 2, Mar 6, 2022.
  1. Mar 6, 2022 at 11:47 AM
    Partschanger 2
    Partschanger 2 [OP] Member
    Wisconsin
    2021 Tacoma SR extendedcab 4 wheel drive.
    None
    Does the 2021 extended cab have grease fittings on the drive shafts, front and rear?
    My 2007 had grease fittings.
    I have trouble laying under the truck, I get dizzy and nauseated. Took my 2007 to Pennzoil for driveshaft lubrication
  2. Mar 6, 2022 at 12:46 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    2017’s like mine had only 1 zirk, it is on the rear of the front driveshaft.
    Not sure when they got rid of the last zirk, but I have to argue with the dealer service whenever it’s a new person because every time I ask them to do it they insist that my truck doesn’t have them. If you’re worried about it you can change out the joints and get some with zerks on them, but it might not be worth it.
  3. Mar 6, 2022 at 12:48 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Nothing on rear shaft on 3rd gen, front did but pretty they got rid of that in 20, or 21. My 18 has one on front drive shaft. Someone may correct me on 20 and up.
  4. Mar 6, 2022 at 1:10 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    2019 was the last year. My old 2019 TRD had zerks on the front half of the driveshaft before the transfer case. There were two - one in each joint. I believe Toyota completely sealed the drivelines in 2020.
  5. Mar 6, 2022 at 1:13 PM
    OnHartung'sRoad
    Well that’s weird, my 2017 OR only has one Zirk , Wonder why the discrepancy?
  6. May 28, 2024 at 8:42 PM
    rastaban
    rastaban Well-Known Member
    Bay Area, CA
    2021 TRD Off-Road DCLB
    TRD Pro Skid Alucab Explorer canopy Utility winch in the bed Dimmable lights in the bed
    My 2021 OR has no zirks.
  7. May 29, 2024 at 4:27 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    No driveline zerks on my ‘20 TRD Sport 4wd. :annoyed:
