gps says 55mph speedometer says 60mph?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scrapedface, Jan 1, 2009.
  1. Jan 2, 2009 at 1:05 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    my head hurts....
  2. Jan 2, 2009 at 3:45 PM
    zuter
    zuter Well-Known Member
    Calgary, AB
    09 SR5 4x4 4 cyl
    2nd filter, undercover, debaged, bug deflector, more to follow!
    Well sure when you say it like that it makes sense! :cool: Thanks for the correction! :D
  3. Jan 3, 2009 at 2:34 PM
    scrapedface
    scrapedface [OP] Well-Known Member
    vacaville, ca
    2008 2.7 liter 4wd tacoma
    ipod charger and aux cable, scanguage 2, wet okole seat covers, 35% tint, toytec ultimate set at 2.5"
    those stealership mofo''s. since my speedo says im going 5mph faster then that means im racking up miles faster. im gonna have to get them to fix that.
  4. Jan 3, 2009 at 5:42 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    They may and probably will tell you it's within Toyota's specs so there is no need for them to fix it.
  5. Feb 8, 2009 at 11:05 AM
    Soundwave
    Soundwave Well-Known Member
    B.C. Canada
    2013 TRD sport Double Cab 4x4
    OEM Roof rack
    I just noticed my GPS reads about 5 kms/hour (3mph) slower than my speedometer too. Im sure that there is some degree of difference with all car makes out there. My Girl friends VW Golf is almost dead on though when I checked it with the GPS. Anyone ever try comparing the accuracy of other vehicles?
  6. Feb 8, 2009 at 11:43 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I don't want to admit it, but my GMC Sierra was dead on (+-.5mph) with the stock tires. When I had 34 inch tires installed, i simply changed the tire size setting with my hypertec controller. After this the truck was still every bit as accurate.
  7. Feb 8, 2009 at 12:00 PM
    Dilsky
    Dilsky There go my nipples again!
    Shawn
    Edmonton AB
    07 TRD Sport
    2.5" Fox Extendable Coilovers, LR UCAs, Agri-Cover Larado soft top, Pop'n Lock, 48" Hi-Lift Jack, 20" Incubus Offroad rims
    Either way you gotta hit 88 mph before the flux capacitor kicks in?
  8. Feb 9, 2009 at 11:01 AM
    WTXTaco
    WTXTaco Member
    West Texas
    08 Silver DCab PreRunner TRD Sport
    Aries SS Bullbar, KC 50 Series OffRoad Lights, Aries SS 4" oval step bars, TrailFX bug shield, WeatherTech floor liners
    My speedometer is app 3 mph faster than GPS in the 65-80 mph range.
  9. Feb 9, 2009 at 12:40 PM
    DMZX
    DMZX Active Member
    E. Oregon
    2x4 Tacoma
    My 2007 read 4mph over actual (GPS) speed @ 60mph.
    Swapped out the worn OEM 215R70's for 235R70's and it corrected to just right (GPS=speedo) at 60mph.:D
  10. Feb 9, 2009 at 8:01 PM
    stb
    stb Member
    San Diego
    4X4
    I got the same 55/60 reading on my 09. The dealer confirmed that the speedo was off by about 10%, but he also said the computer indicated fewer miles than the odometer reading, meaning the sensor was correct, but the speedo was not. (I guess the computer keeps track of miles nowadays?) They said, "never seen that before." I've been waiting three weeks for them to contact me because they said the Toyota service rep. had to look at it, and they would probably have to send the truck out to a speedo shop to have it calibrated. My 99 Taco's speedo was right on with the stock tires. I guess that's progress, Toyota style.
  11. Feb 10, 2009 at 4:36 PM
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    my gps says 100 km and the speedometer says 97 km with lt265 70 r17 tires. put new tires on lt265 75 r17 and it is dead on now
  12. Apr 22, 2009 at 7:09 AM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    This has been a fun thread. Forget the math and just think a minute. A larger tire travels farther every time it makes one complete rotation, right? If you don't agree, then try this: Take a wheelbarrow tire and a tractor tire. Stand them side-by-side and push each of them one complete rotation. Which one traveled the farthest (the tractor tire)?
    So, if you have great big 38" tires on your Tacoma and no gadget to correct your speedometer (your odometer is run by the same mechanism as your speedo) and your speedometer is set at the factory for a 29" tall tire, then you can reasonably determine that your pickup will have traveled farther every time the tire makes a complete revolution than the odometer thinks it has. Ergo, GPS says 100 miles, odo says 92 miles (just so we all understand, GPS doesn't care what size your tires are).
    Also, some manufacturers' speedos are factory set to read a little fast, so people don't complain about getting stopped for speeding all the time. Incidentally, many states also set their radar equipment to allow a couple miles per hour fudge factor to the benefit of the citizen (ie, actual speed is 65 and the radar reads 63. Again, GPS doesn't care. It only reads the relationship between the satellites and the GPS unit. It doesn't care whether it is in a car, airplane, or bicycle, or in the hand of a hiker. No fudge factor built in.
    Additionally, if you have the above 38" tires on your vehicle, and you start figuring out your gas mileage according to your odometer mileage, you are going to get very depressed. Your mileage will appear to have dropped off the scale on the low side, while in reality it is not so bad. Try figuring your mileage by using GPS distance traveled rather than your odometer. You'll be much happier.
    Now about the warranty thing. I had never thought of that! Getting bigger tires is looking better all the time!
