Got Spare Fuses?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Dec 6, 2011.
  1. Dec 6, 2011 at 12:36 PM
    OffroadToy
    OffroadToy [OP] old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I tried doing a search. Does anyone have a list of spare fuses they carry for the 2nd gen Offroad Taco incase of emergencies? I've got a couple standard packs but alot of the fuses on the truck look like you'd have to go through the dealer to get (and might be a bit expensive.) What spare fuses would you recommend carrying incase of a problem out wheeling? My 07 has vsc,trac,dac,hac,alsd,etc,etc.
  2. Dec 6, 2011 at 1:09 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Just go to an auto parts store or WalMart or anyplace that has an automotive dept. and get a box of mixed amp fuses... Look in the two fuse box places on your truck to see what size to get... There are fuses under the hood and behind the little storage pop out compartment to the left and lower from the steering wheel.
  3. Dec 6, 2011 at 1:14 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    I got some pepboys for 10 bucks and it has most of the fuses I need
  4. Dec 6, 2011 at 1:17 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You don't need to go to the dealer for any of the fuses on your truck. Just pop open the fuse box, make a note of the fuses you have and get a set of replacements at any auto parts store. If you're really stranded, you can swap fuses around to run more critical items and, worst case scenerio, jump across the fuse (I'm not recommending anyone do this, just simply stating it as an option if you're sure it's only a fuse problem, you're stranded and it's a last resort) :)
  5. Dec 6, 2011 at 2:49 PM
    OffroadToy
    The fuses I'm most concerned with are the larger one's (approximately 3/4" x 3/4" square.) They're 30,50,100,& 140 amp. Anyone carry spares of them or ever had to replace one?
  6. Dec 6, 2011 at 4:42 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    I need the 7.5amp mini fuses. They seem hard to come by. Walmart does not carry them. I have not checked Pep Boys or Advance. I want the mini fuses to replace the ones I used.
  7. Dec 6, 2011 at 5:06 PM
    OffroadToy
    Google Cooper Bussmann KM-9 Emergency fuse kit. They have assortment packs of the mini that include 2,5,7 1/2,10,15,20,25,and 30 amp.
  8. Dec 6, 2011 at 8:47 PM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Check out RadioShack. They had some last time I was there.
  9. Dec 7, 2011 at 4:31 PM
    OffroadToy
  10. Dec 7, 2011 at 6:53 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I went to a salvage yard a year or so ago and stripped a truck of its fuse boxes:)
