Gopro mount for other things
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JerseyMark, Nov 9, 2017.
  1. Nov 9, 2017 at 6:56 AM
    JerseyMark
    JerseyMark [OP] Member
    2017 Red Tacoma TRD Offroad DCSB Manual Trans
    I don’t own a gopro and I was wondering if anyone has used the built in gopro mount for other things? And if so, how did you attach it?
    I would like to use it for my ezpass, but I cant seem to find something to attach my ezpass to the gopro bracket. I was hopping there would be an adapter to stick to my ezpass, but the ones i see all have a hinge type thing on them.
  2. Nov 9, 2017 at 6:59 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Buy a gopro mount and some zip ties.
  3. Nov 9, 2017 at 7:11 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    There are dozens of different GoPro mounts. Go online and see what's available. I'm sure you can find something you can use for a number of purposes.
    G.
  4. Nov 9, 2017 at 9:06 AM
    dynamicweight
    dynamicweight Well-Known Member
  5. Nov 9, 2017 at 9:14 AM
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    OK, you win. You got me to ask: why not install your ezpass behind the mirror with the provided velcro tabs? What pros are there to installing via the gopro mount? Just to use the mount?
    beergeek and Garyji like this.
  6. Nov 9, 2017 at 9:21 AM
    Jakester
    Jakester Well-Known Member
    Jacob
    PA
    02 TRD
    N/A
    This.
    I have mine mounted just like that and it is so out of sight that I usually forget I even have it.
  7. Nov 10, 2017 at 3:39 AM
    JerseyMark
    On my last vehicle, the glue on the velcro tabs has weakened with temperature changes and causes the ezpass to fall off the mirror. I have also used the suction cup mounts in the past and had the same problems. Also, I figured since the mount is already there and blocks some visibility in that spot.
  8. Nov 10, 2017 at 4:24 AM
    Rackness
    Rackness Well-Known Member
    Maryland
    17' Tacoma
    Working on it.
    I bought the extreme clear Velcro to attach my ezpass to the windshield. It works very well and has never fallen off over the years. The only warning is cut it and only use no larger than 1 inch squares in the corners of the ezpass or it will be a fight to remove it, I learned that the hard way. I used a strip along the top and bottom and thought I was going to break my windshield trying to remove it.
  9. Nov 10, 2017 at 8:07 AM
    Hextall
    NH
    17 Inferno OR DCSB
    Got it... that happened to me too, but only when I tried to transfer the tabs to to a different car. I think you can go into an EZpass center and get new tabs (free?) rather than try to reuse the old ones.
    when you say "fall off the mirror", do you mean behind the mirror on the windshield, or literally on the back side of the rear view mirror? I think these tabs are supposed to work on glass.
  10. Nov 10, 2017 at 8:15 AM
    phsycle
    phsycle Well-Known Member
    CA
    That dashcam mount is pretty slick. I will probably end up doing that. To hopefully capture moments like this.
    monteredondo and PNWTacoma like this.
  11. Nov 11, 2017 at 12:57 PM
    Grumpysedc
    Grumpysedc Well-Known Member
    Tony
    Miami, Florida
    2017 Silver Tacoma TRD Sport
