Gooseneck towing capacity 2012 4x4 Sport quad cab
Discussion in 'Towing' started by 4Gallo, Jan 1, 2014.
  1. Jan 1, 2014 at 10:09 PM
    4Gallo
    4Gallo [OP] New Member
    Utah
    4 X 4 Sport
    KFN AIR SYSTEM
    I'm wondering if I can increase the towing capacity of my Tacoma if I get a gooseneck hitch. Highways, dirt roads, mountains and long pulls if desired. Anybody with experience or knowledge would be greatly appreciated. i'm looking at a 25' camping trailer.
  2. Jan 1, 2014 at 10:16 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    That would be a lot more than what would be considered safe......just my $0.02. Just think about how much weight would be in the bed and you still have the towing weight to consider.
  3. Jan 1, 2014 at 10:26 PM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    It may actually tow a little better but it will definitely not increase capacity. Usually if you need a gooseneck its better to upgrade to a bigger truck.
  4. Jan 2, 2014 at 7:59 PM
    SSG665
    SSG665 Well-Known Member
    Georgia
    18 Tacoma
    Gooseneck in a composite bed?No good!!
  5. Jan 2, 2014 at 8:13 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Someone here did it and documented the hitch install, but I wouldn't ever recommend it.
  6. Jan 2, 2014 at 8:18 PM
    Nick82
    Nick82 Well-Known Member
    Nick
    Richmond ky
    2012 DCLB MGM 4x4 sport tow nav
    ARB winch bumper
    Funny you asked, I just saw this truck and trailer today. He was pulling out of a gas station which sucks because I really wanted to ask him how it pulled and get a picture of his hitch. I tried to attach a picture we will see if it works or not. If not I will try again.
  7. Jan 4, 2014 at 2:46 PM
    SSG665
    Georgia
    18 Tacoma
    I can promise you he is over max weight with that older 5th wheel.Problem is if u have an accident and someone gets injured or killed you can be in big time legal trouble being over weight..
  8. Jan 4, 2014 at 2:58 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    That's insane... No one in their right mind would do this.
    That should go in the goofiest pic thread, and WTF thread.
  9. Jan 4, 2014 at 3:19 PM
    PattonT
    PattonT Well-Known Member
    2013 2.7l prerunner
    Unless that 5th wheel has been gutted I guarantee that is 8klbs plus.
  10. Jan 4, 2014 at 9:38 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    ^8k is probably a good estimate. The gooseneck usually carries 25% of the weight. So 2k lbs on the bed. Eff that!
  11. Jan 5, 2014 at 2:56 AM
    PattonT
    2013 2.7l prerunner
    To make matters worse it is a 5ft bed so the hitch is probably slightly behind the axle instead of slightly in front or directly over it. Who takes a lawnmower camping anyway?
    Edit: The trailer may be lighter than I thought, most 25-27' 5th wheels are around 6500lbs. How long is that one?
  12. Jan 5, 2014 at 4:34 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
  13. Jan 5, 2014 at 5:22 AM
    Nick82
    Nick
    Richmond ky
    ARB winch bumper
    It was a long bed, but that doesn't make it any safer.
  14. Jan 5, 2014 at 5:47 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You got to be &^*$() me! That's nuts guess he climbs most hills in low gear and stays 97 car lengths behind other cars. He was pulling out of a gas station for good reason hope there is another one in about 100 miles.
  15. Jan 5, 2014 at 5:47 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Properly installed fifth wheels don't mount to the bed, doesn't matter if it's composite or not. :rolleyes:
    Regardless, the pic a few posts up is most likely overweight, which I'm not condoning.
  16. Jan 5, 2014 at 6:17 AM
    Delmarva
    Tucson, AZ
    There have been successful installs and pulls of a Scamp 5th wheel (not a true 5th wheel hitch) with Tacomas
  17. Jan 5, 2014 at 6:27 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Toyota doesn't either read the owners manual.
  18. Jan 8, 2014 at 5:07 PM
    4Gallo
    Utah
    4 X 4 Sport
    KFN AIR SYSTEM
    Thanks everybody. That is what I was looking for. Good discussion. Thanks for the Picture. I wish you could have talked to him too. It looks a lot bigger than what I'm planning. I'm looking at a 22.5' which is under the 6500 lb limit giving room for gear and water. I've had a goose-neck horse trailer before and they pull like a dream, but I had a full size truck then. Now I have my dream truck tacoma and would still like to go camping with the wife.
  19. Jan 8, 2014 at 5:29 PM
    Nick82
    Nick
    Richmond ky
    ARB winch bumper
    In my opinion I would have no hesitation install a gooseneck hitch in my tacoma as long as the trailer when loaded did not exceed any of the trucks stock limitations, having to facto in gross trailer weight and bed weight. Overall they are safer trailers to pull however very easy to overload without it being obvious by looking at it!
  20. Jan 8, 2014 at 9:49 PM
    4Gallo
    Utah
    4 X 4 Sport
    KFN AIR SYSTEM
    Do you know if it can actually be installed and where you could get it done or buy the parts? I can't find anything specific for the Tacoma.
