Google maps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dilly, Feb 19, 2020.
  1. Feb 19, 2020 at 5:13 AM
    Dilly
    Dilly [OP] Well-Known Member
    LOUISIANA
    2019 MGM SR
    Can I not have my phone connected via bluetooth and have my radio playing while google maps audio plays through? The only way I can hear the audio for google maps is if the head unit is set to bluetooth which means no radio :/ Is there a setting on the head unit to change that or am I just trying to live in the year 2030 here. I have a 2019 SR if that helps.
  2. Feb 19, 2020 at 5:15 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Think about it, how is it going to play the Bluetooth audio when the radio is set to FM/AM not Bluetooth.
  3. Feb 19, 2020 at 5:23 AM
    Dilly
    LOUISIANA
    2019 MGM SR
    Well if that is the case that's a bummer. So in order to hear google maps and have the radio playing, I have to turn off phone BT or disconnect my phone from the truck just so the audio plays through my phone. Which doing that I won't get the notifications/phone calls through my truck.
    El Duderino likes this.
  4. Feb 19, 2020 at 5:24 AM
    GreyBaldTaco
    2019 F150 5.0
    Could always buy a non base model stereo and get GPS in the head unit, or an aftermarket head unit.
    Mikeincal likes this.
  5. Feb 19, 2020 at 5:30 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Could just stream music through your phone and use google maps that way. You can adjust volume for instructions. Really only way you can do it and have both running at same time
    Grindstone and Jojee117 like this.
  6. Feb 19, 2020 at 5:30 AM
    Dilly
    LOUISIANA
    2019 MGM SR
    This was my initial thought but figured I ask here to see if I was missing something before dishing out unnecessary $$$. I know a radio upgrade with speakers would vastly improve what the stock has to offer audio wise, but it doesn't bother me to the point where i HAD to have it. This google maps problem will likely speed up that process now lol. Thanks for the advice on this :cheers:
  7. Feb 19, 2020 at 5:32 AM
    baddy
    baddy Member
    This is easy to do, a setting on the Google Maps app. Open the Maps app and go to Settings (on iPhone under your Avatar). Go to the Navigation setting, and under Sound and Voice there are settings for:
    "Play voice over Bluetooth"
    "Play as Bluetooth phone call"
    Be sure both are enabled (the second one is the key). Once you do this, when you have a navigation going on the phone, when the voice prompt comes up, the HU will show like a phone call is coming in and play the prompt over the car speakers. It will do this regardless of input (FM/Satellite/etc). Hope this helps!
  8. Feb 19, 2020 at 5:33 AM
    trackdaybro
    trackdaybro Well-Known Member
    There’s a setting that allows google maps to play it’s audio as a phone call. When google maps needs to tell you to turn, it’ll cut your radio (or whatever you’re listing to) and play the notification as a phone call before transitioning back to the radio. It is a smoother fade-in/fade-out when you’re streaming music from your phone, but it works.
    edit: @baddy beat me to it haha. Great helpful first post!
    Dilly[OP], GreyBaldTaco and baddy like this.
  9. Feb 19, 2020 at 5:35 AM
    Dilly
    LOUISIANA
    2019 MGM SR
    Thanks for the reply. I'll either do that or just upgrade the headunit. I figured I'll check here before doing anything.
  10. Feb 19, 2020 at 5:40 AM
    GreyBaldTaco
    2019 F150 5.0
    That's pretty cool, had no idea.
  11. Feb 19, 2020 at 5:51 AM
    Dilly
    LOUISIANA
    2019 MGM SR
    Thank you for this. I have a galaxy phone but I would imagine it would be the same. TW community never disappoints. Cheers :cheers:
  12. Feb 19, 2020 at 8:21 AM
    RhinoSoul
    RhinoSoul Well-Known Member
    Thats really neat. I had no clue that existed.
  13. Feb 19, 2020 at 10:16 AM
    Dilly
    LOUISIANA
    2019 MGM SR
    OK now since i had time to try while on lunch. It's still a no go, those options where already turned on. So i turned them off and back on again, went through ever setting possible. Still no dice. Idn wtf is going on but something that is so simple would seem just to work :frusty:
  14. Feb 19, 2020 at 1:24 PM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    It would seem to me that for the radio + bluetooth nav case, you'd want only the second option turned on.
    Also verify that when you receive a call it rings on the head unit.
