Google maps stuck on dark/night mode
Discussion in '3rd Gen. Tacomas (2016-2023)' started by spanktacular, Jun 15, 2022.
  1. Jun 15, 2022 at 9:29 AM
    spanktacular
    spanktacular [OP] Member
    Jake
    2020 Black Tacoma SR
    I have no idea what could cause this. I even went into developer tools and told it to always use day. My maps are dark all the time now and I can't change it.
    I've changed the settings, rebooted the phone, checked for updates, enabled options in developer tools, I just can't get it to leave this dark mode.
    Any ideas?
  2. Jun 15, 2022 at 9:32 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Are we talking phone screen or truck screen?
  3. Jun 15, 2022 at 9:33 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Not a truck issue. Will be in your phone settings somewhere. Must have missed a configuration step. Can try clearing cache for the maps app and see if it defaults back to the correct mode. Once it displays correctly on your phone it should be fixed on the infotainment screen as well.
    GillyLink likes this.
  4. Jun 15, 2022 at 9:39 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    You've got to provide context to get proper assistance. Are you using Android? If so a recent bug caused this same issue in Google Maps version 11.33.1
  5. Jun 15, 2022 at 9:53 AM
    adrew
    adrew Well-Known Member
    '21 SR 2.7L 4x4 Old Man Truck
    Leer 100XR
    Mine recently started doing this - couldn't fix it until I switched my phone to light mode. AA seemed to be respecting the phone's dark theme.
    Key-Rei likes this.
  6. Jun 15, 2022 at 9:54 AM
    spanktacular
    Jake
    Sorry, here are the missing details:
    Tacoma 3rd gen
    Android 9
    Maps displays correctly on the phone
    Maps is dark on the head unit
    Google maps received an update four days ago, which pretty much matches for when I noticed this come to think of it...
    Key-Rei likes this.
  7. Jun 15, 2022 at 9:57 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    It sounds like your phone is stuck in "High Contrast" mode.
  8. Jun 15, 2022 at 10:42 AM
    spanktacular
    Jake
    Negative. No high contrast setting is enabled.
  9. Jun 15, 2022 at 10:46 AM
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
    Try the settings in the Android Auto app on your phone. There is a "Day/Night mode for maps setting".
  10. Jun 15, 2022 at 11:10 AM
    spanktacular
    Jake
    I figured it out.
    I'm kinda mad about it.
    My phone is set to dark mode. Google maps on my phone is not, and does not have the option to be viewed in dark mode and does not default to the phone's setting.
    My phone is set to dark mode. Android auto sets the map to dark mode and only dark mode.
    I turned off dark mode on my phone and the map is displaying day mode correctly...
    This is so painfully stupid. I got a fancy new USB3 cable and I still get skips and disconnects, now this?
