Goodyear Wrangler All-Terrain - Question about age, etc.
Discussion in '1st Gen. Tacomas (1995-2004)' started by jammer, Mar 11, 2021.
  1. Mar 11, 2021 at 10:21 AM
    jammer
    jammer [OP] 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Hey guys - Due to Covid, I don't drive my truck nearly as much as I use to. When not in use, she's in the garage.
    I've noticed that when I drive the truck after sitting for about a week their is a reverberating/pulsing sensation when first getting on the highway, that eventually goes away.
    Is it possible in that amount of time for a flat spot in the tire to form or is another issue??
    I also just noticed today that the manufacturing date is 2015! As you can see from the pictures below the tires are in excellent shape and lots of tread left.
    Ride and Tires -
    '03 Toyota Tacoma DBL Cab PreRunner (3.4)
    Approximately 151,000 miles
    No Lift
    Driveshaft is greased at every oil/filter change (no play in the u-joints...testing on the truck).
    Lower ball joints replaced with oem ball joints last year.
    Goodyear Wrangler All-Terrain w/Kevlar 265/70R/16
    Last 4 digits on tire (DOT): 3715 (damn, didn't realize they were this old)
    Load Index 112 (2,469 lbs)
    https://www.goodyear.com/en-US/tires/wrangler-all-terrain-adventure
    Taco critter likes this.
  2. Mar 11, 2021 at 11:04 AM
    jammer
    Ben
    Bentonville, AR
    Thank you sir.
  3. Mar 11, 2021 at 11:05 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    "They" say that tires last about 6 years before they should be changed, but I think there are a lot of variables that go into that. If you keep it in the garage when not in use I think you can get a lot more life out of them. I highly doubt that sitting for a week would cause a flat spot unless it was a crappy tire to begin with.
    Best bet would be to take it into a tire shop, have them do a rotation and balance and see if they think anything is off
  4. Mar 11, 2021 at 12:11 PM
    jammer
    Ben
    Bentonville, AR
    Good advice eon blue. Thank you!
  5. Mar 11, 2021 at 12:15 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    OP Goodyear tires suck. When they are new no problem once they start to wear that’s when they start to have issues with the compounds in the tires.
  6. Mar 11, 2021 at 12:18 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I have heard this as well and if was the case there would be a shitload of used tires in the dump. I think you are right though. Tires that sit in a warehouse, never on a vehicle that are 6 years old or older - should be discounted but I don't see why they can't be used.
    Do they get moldy like bread? lol j/k
    jammer[OP] likes this.
  7. Mar 11, 2021 at 12:19 PM
    eon_blue
    Azusa, CA
    I think it's just that rubber degrades over time and with the kind of stress tires are subjected to, it's in the manufacturer's best interest to put a lifespan on them. Particularly if they aren't stored well or subjected to a lot of heat/direct sunlight. Tires stored properly shouldn't be an issue though
    jammer[OP] and Xbeaus[QUOTED] like this.
  8. Mar 11, 2021 at 12:20 PM
    Xbeaus
    Beau
    motorcycle helmets are like that and I see what you are saying. Supplier has to cover their ass too I suppose.
    eon_blue[QUOTED] likes this.
  9. Mar 11, 2021 at 12:23 PM
    Brianz1001
    Brian
    too much to type
    No matter the tread depth, if a tire is more than six years old, you should start thinking about replacement. That’s because the rubber compounds in a tire deteriorate over time, resulting in dry rot. Dry rot makes your tires more susceptible to blowouts and tread separation.
    Vehicle and tire manufacturers usually recommend replacing your tires if they are 6-10 years old, regardless of tread depth. But for most drivers their tire tread will wear out before the tires get that old.
  10. Mar 11, 2021 at 12:25 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Ok....Hold on a moment.
    The number in the pic is the tire size and speed rating, not the date code.
    The date code is a 4 digit number.
    General recommendations are to replace tires around the 5-6 year mark, regardless of remaining tread.
  11. Mar 11, 2021 at 12:27 PM
    eon_blue
    Azusa, CA
    Unfortunately they just bought out Cooper too so, might have to add Cooper to that list as well
  12. Mar 11, 2021 at 12:29 PM
    Brianz1001
    Brian
    too much to type
    Cooper was a great tire. Goodyear is going to wreck there good name.
  13. Mar 11, 2021 at 12:31 PM
    eon_blue
    Azusa, CA
    I had to like this just so I could unlike it
  14. Mar 11, 2021 at 12:33 PM
    kite_325
    kite_325 A simple human, being
    North Carolina
    2017 TRDOR
    I used to travel a lot for work. I would be gone a week to three weeks at a time. When I got back, I felt like my truck ran a little funny too. I have since upgraded my tires from the stock Goodyear Wranglers and I now have no issues after the truck has sat for a while. I am not saying it's the tires, but I am not saying its not. Probably just a placebo affect. I didn't really like the goodyears.
    Not exactly an answer to your question I know, but best of luck! The tires still look in good shape, so I'd say you're probably fine. I also doubt its flat spots as much as potentially the smallest amount of surface rust on your rotors or brakes or something like that. It does get quite humid in AR
  15. Mar 11, 2021 at 1:33 PM
    L78
    L78 Well-Known Member
    Tony
    Nor Cal
    1995 Tacoma DLX, 2.7/Manual, 4x4, 1 family ownership
    Mostly stock, added custom wood bed rails and a Sony/Infinity stereo system
    True, tires fo age-out, but IMO 6 years is ridiculous... even more so if stored indoors.
    I recently bought tires and checked at several major retailers. They were all around 10 years for tire age, and after that, it’s a liability for their shop to work on them.
    If you are stored indoors and don’t see any cracking, you should be fine.
    I laughed when the OP said “2015”...
    maybe I have been lucky, but I have had numerous tires that were over 13 years old, and never a problem. The two most recent were stored outdoors 100% of those 13 years... this included Goodyear Wranglers on my Tacoma that I just replaced in January...
    I even asked the tire shop if I could get tires made within the past 3 months, because I didn’t want the expense of replacement when they are too old to repair...
  16. Mar 11, 2021 at 1:37 PM
    jammer
    Ben
    Bentonville, AR
