Goodyear Duratrac Weight? 265/70/17 Load Range C
Discussion in 'Wheels & Tires' started by evan, Jan 7, 2016.
  1. Jan 7, 2016 at 6:35 PM
    evan
    evan [OP] Well-Known Member
    SK, Canada
    Does anybody know the weight of the Goodyear Duratrac in load range C, size 265/70/17 (part number 312019027)? I'm trying to decide between those and the BFG KO2 in the same size and load range. The KO2, part number 66255, weighs 45.4 lbs (20.6 kg) according to the BFG website.
  2. Jan 7, 2016 at 6:44 PM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    They are almost identical in wieght. I went with the ko2's for less road noise.
    evan[OP] likes this.
  3. Jan 7, 2016 at 7:53 PM
    evan
    SK, Canada
    Thanks. I should have thought to look there.
  4. Jan 7, 2016 at 8:02 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Treaddepot is really good about listing tire weights as well their actually doing free shipping on Goodyear tires till the end of the month
  5. Jan 7, 2016 at 8:10 PM
    evan
    SK, Canada
    Thanks. They list the KO2's as 46.5 lbs (Performance Rating: S) and 45.2 lbs (Performance Rating: R) and the Duratrac's as 44.4 lbs.
  6. Jan 10, 2016 at 7:25 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    KO2s are just slightly heavier but light years ahead in tire design. I looked at both and went with KO2s. No regrets, far superior tire in almost every single respect. I've run both and won't run Duratracs again after KO2s.
    https://www.youtube.com/watch?v=Kp5dVUol778
