Good way to clean sand out of window trim?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trackdaybro, Dec 18, 2018.
  1. Dec 18, 2018 at 10:27 AM
    trackdaybro
    trackdaybro [OP] Well-Known Member
    Went wheeling and some sand got in between the glass and outer window trim. Whenever I roll the windows I can hear sand scratching the glass. I’ve rolled them all the way down to vacuum as much as I can wherever the window contacts the trim but I’m still hearing scratching. Any ideas?
  2. Dec 18, 2018 at 10:33 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Do it yourself carwash with the high pressure wand. Just blast that shit out. And i wouldnt roll down the windows anymore until you have done this. You will permanently scratch the glass.
  3. Dec 18, 2018 at 10:58 AM
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
    I would roll the windows down and take a damp microfiber cloth in between the molding and rub it back and forth. Try to get in as far down as you can and at a minimum it should knock the sand loose.
    I just got back from the beach a few weeks ago and I still have sand accumulating around the truck, thankfully not in the window molding and trim. The issue I had was the dry air when I got home was causing static and the sand was sticking to the plastic interior. The vacuum did nothing for this, only a damp cloth worked against the static and either knocked the sand down or it accumulated on the cloth. It was all over the speaker holes in the doors.
  4. Dec 18, 2018 at 10:59 AM
    MontysTruck
    MontysTruck Well-Known Member
    2017 Tacoma TRD Pro
    compressed air.
  5. Dec 18, 2018 at 11:26 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do what i do when i roll up to the sand dunes. Blue painters tape on the bottom door to window seal to keep the sand out in the frist place.
    trackdaybro[OP] likes this.
