Good lube for leaf's
Discussion in 'Suspension' started by icallhertaco11, Feb 20, 2013.
  1. Feb 20, 2013 at 7:04 AM
    icallhertaco11
    icallhertaco11 [OP] Well-Known Member
    Jamie
    Texas
    2008 Tacoma Prerunner v6
    Engage Long Travel 6 over with race spindles. 2.5x8 sway a ways wrapped in King Coils.
    Hey guys my leafs are squeaking like a mother and while i'm on the investigation for a new set of leafs to get me off the blocks, i'd like to stop te squeaking.
    Does any know of good grease or lube that I can use for the leafs besides WD-40??
    Thannks.
  2. Feb 20, 2013 at 7:13 AM
    Large
    Large Red
  3. Feb 20, 2013 at 7:16 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Dry lubricants work best, teflon spray or graphite. Grease and oils attract dirt and will only cure the noises for a short period of time.
  4. Feb 20, 2013 at 7:32 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    I tried a graphite based spray lube, cleaned them real well, separated each leaf and coated each contact point with the lube. Next day, without any wheeling, squeak was back and worse than ever. Being pissed, I hosed them down with wd40, squeak was gone for like a month, even with some dusty trips in between. I've got some thin rubber strips I'm going to try this spring.
  5. Feb 20, 2013 at 12:14 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Where did you spray between the leafs?
  6. Feb 20, 2013 at 12:17 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    There are graphite paints for sale at most farm stores like Coastal and Wilco. I bought some and it has come in handy for things that cannot attract dust or dirt. It stays in place.
  7. Feb 20, 2013 at 12:23 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    go to a spray and wash and pressure wash the crap out of your leafs. Its temporary fix but it always works for me.
  8. Feb 20, 2013 at 5:18 PM
    northern cal
    northern cal Active Member
    bay area
    tacoma TRD
    tire lube. The stuff used for mounting tires. put it in a spray bottle. not permanent but lasts a good while, works like a charm. no oil, no grease.
  9. Feb 20, 2013 at 5:26 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    This stuff. Lasts about 3 or 4 months depending on weather and driving conditions. Power wash your leaf springs and let them dry completely, apply some of the Teflon DRY lube, flex a little, spray some more, done
  10. Feb 20, 2013 at 5:32 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Pressure wash then dry moly
