Good lift installer in Tampa?
Discussion in 'Florida' started by TampaTac, Apr 26, 2022.
  1. Apr 26, 2022 at 7:40 PM
    TampaTac
    TampaTac [OP] Member
    2014 2wd Prerunner
    Looking to get a 1.5 to 2" lift on my Tacoma and I am in Tampa, Fla.
    Any recs?
    Thanks in advance!
  2. Apr 26, 2022 at 7:42 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I can recommend me but my shop is a little more north than Tampa PM me. :thumbsup:
  3. Apr 27, 2022 at 10:20 AM
    GuyHuey
    GuyHuey Up is difficult. Down is dangerous.
    Guy
    Holiday, Florida
    89 4Runner, 2020 MGM TRDOR 4X4
    Ball joint spacers and lift blocks, am I doing it right?
    You should give some thought to how you're going to use your truck. Is the lift for looks or functionality. Will it be mild off-roading or bombing down forest roads at 80?
    Depending on what you need it could be a very inexpensive and an easy install or big bucks with fabrication involved.
  4. Apr 27, 2022 at 11:04 AM
    TampaTac
    2014 2wd Prerunner
    Mostly just for looks. I tow a small skiff that weighs less than 2K Lbs boat and trailer. I fish and dont do much off-roading.
  5. Apr 27, 2022 at 11:15 AM
    radclerk1
    radclerk1 Well-Known Member
    Vic
    2017 Access Cab 2.7L Manual 4x4
    None
    What’s the name of your shop? I’m in Sarasota and may be looking into a small lift shortly.
    Key-Rei[QUOTED] likes this.
  6. May 1, 2022 at 2:32 PM
    AJ4mPR
    AJ4mPR Well-Known Member
    AJ
    2019 Tacoma TRD OffRoad DCLB Quicksand
    Search for Matt Berfield owner of Mathias Offroad he is in that area, he does installations and can get you parts too. Look him up on Florida Tacoma facebook page
    CoalTrainTaco likes this.
  7. May 15, 2022 at 7:23 PM
    CoalTrainTaco
    CoalTrainTaco Welker
    Aiden
    Nashville, TN
    2017 Super White SR5
    Fox 2.0 Coilovers MaxTrac Spindles TC Lighting Headlights Red Rock Roof Rack
    Look up Mathias Off-Road. Second vouch here for them. They were extremely helpful and knowledgeable. 100% recommend.
