Good and bad: 2004 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by jdmbooger, Jun 28, 2009.
  1. Jun 28, 2009 at 2:46 PM
    jdmbooger
    jdmbooger [OP] Well-Known Member
    Justin
    SD
    2017 TRD Double Cab
    Method wheels Falken tires TRD Pro grill Yakima gatekeeper pad Lots of stickers
    I am new to this forum but not entirely new to Toyotas.
    I am looking at buying a 2004 Tacoma V6 4 door 4wd TRD SR5, and was I wondering if there is anything in particular that I should know about this specific model before purchasing it. Example: I currently own a 2002 Nissan Frontier SC crew cab, I did not learn until after I bought it that these trucks have a tendency to burn up knock sensors (900 dollar repair) and usually have a cracked exhaust manifold, and the supercharger sucks!
    I have looked over the Tacoma very well, checking all the normal things, no leaks, 4wd works great, 70,000 miles, body is in pretty good shape, carfax checks out clean, I can maybe pick it up for $16,000.
    Any input would greatly be appreciated!
    Thanks for your time!
  2. Jun 28, 2009 at 2:57 PM
    tablesalt
    tablesalt Tacoma Lover
    Riverside, CA
    04 PreRunner, Double Cab TRD V6
    Good ole' Stock. Black.
    I have the 04 V6 2wd TRD off road package. pretty much stock. and its been running great. I have put 30K miles since I got it back in 06. hmm, I don't know what to tell you just that has been a great truck for me. good luck on the purchase. and welcome aboard.
    tablesalt
  3. Jun 28, 2009 at 4:38 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I say go for it! they are a great truck and you will love it. There is a frame rust recall on 01-04's. But only if you live were it snow's alot and they salt the roads. But other then that, there a great truck!
  4. Jun 28, 2009 at 6:15 PM
    brettmc
    brettmc Well-Known Member
    St Louis, Mo area
    2004 2wd tacoma
    Got a link for that rust recall on an 04? i cant find anything on it...even dr. google knows nothing...
    Brett
  5. Jun 28, 2009 at 7:30 PM
    ETaco23
    Evan
    PNW
    ^^^^ Exactly what I tried to say! :)
  6. Jun 28, 2009 at 7:33 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    I dont think there will be an surprises. They are great trucks.
    One thing to know is the timing belt will have to done at 90,000 miles.
  7. Jun 28, 2009 at 7:59 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    90K ISH
    somewhere in that neighborhood...plus theres a good chance the water pump will leak by then
    easiest thing is to replace them both at the same time...because they have to disassemble the same things to get to both
    the rust issue is not a recall...its an extended warranty with unlimited mileage etc...
    just take the truck to a dealer...have them inspect it...
    you wont be able to see the rust...it rots from the inside out...and its only on a select group of 01-04s...typically from heavy road salt use areas
    if the truck fails...they'll replace the frame at no cost to you
  8. Jun 28, 2009 at 9:39 PM
    jdmbooger
    Justin
    SD
    2017 TRD Double Cab
    Thanks for the help!
    Timing belt and water pump are no big deal, however I will check into the rust issue because the truck originally came from Wyoming where they get plenty of snow and we get plenty of snow here in South Dakota!
    Any more info would be great!
  9. Jun 28, 2009 at 9:43 PM
    JimBeam
    JB
    2015 Tundra
    not sure where but theres a LONG thread about the rust issue on here
  10. Jun 29, 2009 at 9:44 AM
    JimBeam
    JB
    2015 Tundra
    Steering rack bushings should only be $40 or $50...contact tacomaman06 (a mod here) he's replaced his before
  11. Jun 29, 2009 at 9:53 AM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    Once you go Toyota you'll never go back!!:thumbsup:
  12. Jun 29, 2009 at 6:45 PM
    Mootsman
    Mootsman Active Member
    Gunnison, Colorado
    02 Tacoma SR5
    3" Fabtech Lift
    I have always liked Toyotas, but ended up having three Nissan trucks, all of which treated me very well. But I looked at an 02 Frontier, found out about the insane knock sensor problems, and then that almost all have the cracked exhaust manifold. I couldn't believe it. The owners act like that's OK. We got an 02 Tacoma with 58,000 on it and absolutely love it. There are a couple of things to get used to, but over all the whole truck just seems more solid. You won't regret it.
  13. Jul 8, 2009 at 9:54 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    frame rust, rack and pinion, sagging springs are probably the most common
  14. Jul 9, 2009 at 8:52 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    I have the same model as the one your looking at except mines an ext cab. I've had no problems with mine. plenty of power, ok gas mileage. as for the price its going to be high because of the trd and sr5 packages. They are worth it I think. I paid about 15,500 for mine a year ago. it had 100,000 miles on it instead of 70,000. I have since put 40,000 on it and not had a single problem. When my truck dies in 250,000 miles I will be flying to southern california and buying the exact same truck.
  15. Jul 9, 2009 at 2:44 PM
    Rattler
    Rattler Wandering But Not Lost
    Bay City MI
    '04 DoubleCab "3 Lift on 285/75/16s
    All Pro rear bumper with an Ironman Offroad swing-out spare carrier, Bajarack on top, blacked-out grill, Lightforce 140s Mombasa Rooftop Tent
    My '04 D-cab is my 3rd Toy. Its got around 53k on it with the only problem being a self-inflicted alternator kill. Other than that, replace the steering rack bushings if you plan on offroading. Otherwise, go for it and enjoy it.
  16. Jul 9, 2009 at 5:27 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    exactly!! do it!
  17. Jul 9, 2009 at 5:28 PM
    RattleTractor
    Harry
    VT
    the rust recall on the 01-04 is a free frame swap i believe. they do not buy back the truck like the 95.5-00 tacos.
    my neighbors truck is an 02 dc and he got a free frame swap from the local dealer.
  18. Jul 12, 2009 at 12:05 AM
    jdmbooger
    Justin
    SD
    2017 TRD Double Cab
    Thanks for all the info! I wish I had asked about my Nissan Frontier before I bought it, if I had known about all the problems those trucks commonly have I wouldn't have made the mistake of buying a Nissan instead of a Toyota!
    However, that mistake has been corrected! Due to the positive responce from Tacoma owners, my wife and I traded off the Frontier for the 2004 Tacoma that I have been looking at!
  19. Jul 12, 2009 at 11:32 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Good news, that! Let's see some photos when you get a chance.
    I got my '02 x-cab SR5 TRD auto 4x4 back in '05 with 19k+ miles, has been problem free ever since.
  20. Jul 12, 2009 at 3:15 PM
    jdmbooger
    Justin
    SD
    2017 TRD Double Cab
    The new truck in the Black Hills:
