Good air mattress for tenting?
Discussion in 'Outdoors' started by infantry317, Nov 10, 2020.
  1. Nov 10, 2020 at 8:02 AM
    infantry317
    infantry317 [OP] Well-Known Member
    Minnesota
    2019 Tacoma TRD OR
    None yet
    So we had a cheap self-inflating one the lasted 5 nights until I think something sharp got it, never did find the leak. Any recommendations?
  2. Nov 10, 2020 at 12:03 PM
    huachuca
    huachuca Well-Known Member
    Al
    Tarboro, NC
    2012 4WD DC w/TRD offroad
    Self inflating pads would be my recommendation, especially if you camp in cooler weather. I've had two of the Therm-a-Rest Trail Comfort series (no longer available) for several years. One had to be patched in the field when my wife leaned back on a cactus when we were hiking the South Rim in Big Bend several years ago. Both still hold air with no problems.
    infantry317[OP] likes this.
  3. Nov 10, 2020 at 12:05 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    depends how much you want to spend. There are a bunch out there now. $50 - $5-500. When I have the fam I just grab a Aerobed brand (brand is key) and blow it up off the truck as it has a built in pump. Never had issues. If you want a more compact one then there are a bunch of camping ones that are solid. Depends I would say if its leisure or backcountry
  4. Nov 10, 2020 at 12:10 PM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Skada, Chris(NJ) and infantry317[OP] like this.
  5. Nov 10, 2020 at 3:44 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    Get a pad that is insulated! the ground sucks up body heat!
  6. Nov 17, 2020 at 7:14 AM
    mstudt
    mstudt Well-Known Member
    Eugene, Oregon
    My $.02 on this.
    Get a Big Agnes or Term-o-Rest pad for backpacking. You're going to pay a lot more for them, but they come with a lifetime warranty. I've been using Big Agnes for the last 6-7 years for backpacking, and they stand behind the warranty. If I get a leak I'll send it back, and have a brand new one in about 2 weeks.
  7. Nov 17, 2020 at 7:18 AM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    SE MI
    LT, triple locked, 35s, custom aluminum utility bed with FWC
    some welding required
    for backpacking, thermarest neoair xlite, for glamping, exped megamat.
    both worth the money.
    VE7OSR likes this.
  8. Nov 17, 2020 at 7:22 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    For cold weather, you want to avoid using your breath to inflate, rather use their optional pump method. You want to avoid adding moisture that can degrade the thermal properties of the insulation.
    crackils likes this.
  9. Nov 17, 2020 at 7:27 AM
    tahoeskitaco
    tahoeskitaco Well-Known Member
    KLH
    North Tahoe
    2002 SR5 Xtra Cab + 2019 TRD OR Dbl Cab
    Stock. Custom hettich bed slide
    This. Also get a couple of Z rests to throw on top for winter camping.
  10. Nov 17, 2020 at 7:38 AM
    texas angler
    texas angler Well-Known Member
    Texas Hill Country
    20 OR
    Been reading here and elsewhere on air mattresses. Never been a fan myself due to leaks and they have always seemed cold to me. And no never tried the REI gear. But decided on this one for a little more $ and no air to mess with. A bit on the heavy side but rolls up nice.
    https://www.amazon.com/gp/product/B072BJF9FW/ref=ox_sc_saved_title_2?smid=A15B93V0MWD21G&psc=1
  11. Nov 17, 2020 at 7:41 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    On the inflatable with air type, adjust the amount of air for comfort. Fully inflated will be uncomfortably hard. I find just enough air until pad is in its proper shape, and not much more.
  12. Nov 17, 2020 at 8:21 AM
    Blueberry.Taco
    Ryo
    SE MI
    gotta look at the R values.
    Thermarest has a newer extra-R value but slightly heavier neoair for colder camping.
    I personally use the women's neoair xlite for the extra R values (I don't mind that my feet fall off the end of the pad, I can insulate/raise that with jackets/clothing)
    texas angler[QUOTED] likes this.
  13. Nov 17, 2020 at 8:48 AM
    texas angler
    Texas Hill Country
    20 OR
    Right on. But I also have to look at comfort values for my back. Love me some memory foam for that very reason. I may try air again someday.
    Edit: And that someday I reference above will be warm weather camping. I could see using an air mattress then. Seems the memory foam holds heat.
  14. Nov 17, 2020 at 8:53 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Backpacking or trunk camping?
    My cheap air mattresses started lasting a lot longer when I added a leaf rake to my camp kit...
  15. Nov 17, 2020 at 9:03 AM
    amansker
    amansker Ramen!
    Andy
    San Diego, CA
    2010 AC 4x4 6cyl Auto TRD Sport
    One of these came with my truck. Great for weekend car / tent campers. Very comfy. Chambered. The battery will inflate/deflate ~5X before it needs charging. Once the pump sucks the air out, this becomes very easy to fold tightly. The vertical height is 11" or so which could become a problem in some situations.
    https://truckairbedz.com/Airbedz
  16. Nov 17, 2020 at 11:06 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
  17. Nov 19, 2020 at 6:09 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Recommend storing the self inflating type in the inflated position, only compressing it for portable transport. It will inflate easier when needed and last longer. Same goes for sleeping bags.
  18. Dec 1, 2020 at 6:13 PM
    kywoodsrider
    kywoodsrider Well-Known Member
    2017 Grey Tacoma Access Cab Off Road Package
  19. Dec 1, 2020 at 6:20 PM
    EvilElvis
    EvilElvis Well-Known Member
    PNW
    2012 3wd
    Same here, I used to use air mattresses, but they develop leaks and were a pain to insulate. I now use a bouldering pad as my mattress.
  20. Dec 2, 2020 at 3:33 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Memory foam tends to stiffen/harden in cold weather, found that out the hard way when I had a memory foam topper in my Westy.
