GL-4 vs. GL-5 rear differential oil
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JMag, Oct 2, 2022.
  1. Oct 2, 2022 at 8:46 PM
    JMag
    JMag [OP] Well-Known Member
    Jonathan
    Baton Rouge
    2017 TRD Sport Blazing Blue Pearl
  2. Oct 2, 2022 at 8:51 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Stick with the Toyota specifications, they have the engineers.
    The GL-4 doesn't offer the wear protection of the GL-5.
    The GL-4 is recommended for manual transmissions, specifically the Tacoma manual.
    cryptolime and eurowner like this.
  3. Oct 2, 2022 at 8:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Unless there’s something special about the Gen 3 diff that I don’t know about, I don’t see what GL4 would Hurt?
    AFAIK, It’s GL5 that can eat away at bronze bushings, not GL4.
    And even then, there isn’t any bronze in the differential that I know of?
    SR-71A likes this.
  4. Oct 2, 2022 at 9:11 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Well, it might not hurt, that still doesn't mean it is a good idea. In an axle application the GL-5 offers the best available wear protection, going backwards is like replacing modern semi metallic brake pads with the cheapest organic pads, the truck will still stop but not as well.
    Specifications are determined by engineers, generally it is good practice to follow them.
  5. Oct 2, 2022 at 9:20 PM
    TnShooter
    Deogee
    STOCK
    I’m quite sure GL5 is better.
    And it’s always better to follow manufacturers recommendations.
    Eventually, if you keep the truck long enough, you’ll likely have an axle seal leak.
    And when it does, if you’re like me, you’ll go with “any type” over “none at all”
    And for those that haven’t had the pleasure of replacing the seal, it sucks.
  6. Oct 3, 2022 at 4:22 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    i understand your desire to use what you have but my logic and recommendation is simple. use what the manufacturer recommends. it's not much money to protect a large investment and for peace of mind. to me, it simply is not worth the risk.
    RustyGreen likes this.
  7. Oct 3, 2022 at 5:13 AM
    LunarTeal
    LunarTeal Rarely interested....
    New diffs cost more than the appropriate fluid.
    AxisCab and RustyGreen like this.
  8. Oct 3, 2022 at 7:09 AM
    eurowner
    eurowner Duke Sky
    Scoty
  9. Oct 3, 2022 at 7:30 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    GL5 has sulphur in it, which bonds to the surface of iron creating a powerful anti-friction layer on the gears. Sulphur is the same component that chemically attacks the bronze syncros, so is left out in GL4 for transmissions. In a high pressure application like a diff, I’d want to stick with GL5.
    RustyGreen and AxisCab like this.
  10. Oct 3, 2022 at 7:31 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    GL4 does not have the extreme pressure additives that GL5 does. So GL4 will not protect the diff properly. GL5 physically damaged transmissions with synchros but that isn’t relevant to this discussion since it’s the opposite situation being asked about.
    TnShooter[QUOTED] likes this.
  11. Oct 3, 2022 at 7:34 AM
    JMag
    Jonathan
    Baton Rouge
    Cool. Appreciate the help. Looks like I’m headed to pick up some lube
  12. Oct 3, 2022 at 10:09 AM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    GL4 in rear diff:
    GL5 in rear diff:
    should clear things up
