GForce Performance Chip???
Discussion in 'Performance and Tuning' started by timebak, Aug 3, 2012.
  1. Aug 3, 2012 at 11:20 PM
    timebak
    timebak [OP] Member
    Tim
    Northeast Missouri
    05 DCSB 4x4 TRD Sport
    ICON Progressive AAL's, Bilstein 5100's, Hunter Side Steps, AFE Pro Dry S filter, Carbon Filter removed, Undercover bed cover, Seat Saver camo seat covers, Weathertech mats F&R, Console organizer, heavy duty mud flaps.
    Has anybody tried one of the GForce Performance Chips? The claims sound about too good to be true.
    Here's a link to their website: http://www.gfchips.com/toyotatacoma.aspx
    My '05 Taco is bone stock, enginewise, but I'd like to increase it's performance some, without breaking the bank. My previous truck was a 2000 F-250 Super Duty Crew Cab with the the 7.3L Power Stroke diesel. It was easy to hop up with a chip.
  2. Aug 4, 2012 at 8:16 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler . Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    60hp, 4-7 mpg, $69? If it sounds too good to be true, It probably is.
  3. Aug 4, 2012 at 8:19 AM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    MSRP is $399.99 and they're selling it for $69? Too good to be true. It screams run. I wouldn't get it.
  4. Aug 4, 2012 at 8:21 AM
    bigcuzauto
    bigcuzauto Active Member
    Louisiana
    2006 tacoma trd
    3 in coil spacer lift 285/75/16 buckshots dent in the rear
    smells like BS to me
  5. Aug 4, 2012 at 8:28 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    there is no such thing as cheap performance. buy the supercharger kit.
  6. Aug 4, 2012 at 8:37 AM
    JaimeDawg
    JaimeDawg make me a sammich
    Jaime
    Las Cruces, NM
    2011 trd off-road prerunner custom paint
    black saphire metalic paint with TRD off-road chameleon, 8000k hids on headlights and fogs, led map lights, led corner lights, saftey first baby seat mod in backseat, white/amber drls, devil horn emblems, trd seat covers, trd cai (old version)
    Its prolly just a 99¢ ohm resister
  7. Aug 4, 2012 at 10:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Won't work on our vehicle. They are well known to be junk across many various car forums.
  8. Aug 5, 2012 at 6:11 PM
    timebak
    timebak [OP] Member
    Tim
    Northeast Missouri
    Thanks Torspd! That's exactly the info I wanted.
    Best Regards,
    Tim
