GFI keeps tripping
Discussion in 'Garage / Workshop' started by coffeesnob, Nov 23, 2010.
  1. Nov 23, 2010 at 1:58 PM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    The GFI in my garage keeps tripping. When it trips a red light on it comes on. Sometimes it trips right away other times it takes a few seconds. I know nothing about electricity but if you think this is a bad GFI I can replace it myself... Thanks:confused:
  2. Nov 23, 2010 at 2:01 PM
    DaCapt
    DaCapt Mad Fisherman
    Phil
    Reno, Nevada
    2013 Tacoma 4X4 SR5 DC
    is it a wall gfi or a gfi in the electrical box?
  3. Nov 23, 2010 at 2:10 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Start with unplugging anything down line of the GFI, the problem item doesn't need to be plugged directly into that outlet, it just needs to be on that line and triggering the GFI into seeing a ground fault.
  4. Nov 23, 2010 at 2:29 PM
    Hugebergen
    Hugebergen Crash and burn live and learn
    Saskatoon Sask
    3"Toytec ULK, box mat, angle brackets in box corners for tie downs, anytime fog lights, bhlm, black grill and lip, trimed front flaps, 7089 procomp rims with 285/75/16 Toyo M/T tires, black badges with trd badges added,anytime foglights, lamin-x yellow fogs, illuminated 4x4 switch, colour match satoshi, Camburg ball joint UCAS.
    If the GFI is on the same circuit as the lights it can cause it to trip. Theres nothing plugged into it when it trips?
  5. Nov 23, 2010 at 3:22 PM
    coffeesnob
    VA
    all
    the gfi is in a wall. It trips on its own.. the only thing plugged into down stream ( I think) is an extension cord with a multi strip deal on it that is turned off. I've only had a battery charger plugged into the multi outlet strip so I don't think it is causing an overload. One other thing may be a coincidence. I had my house pressure washed today and the circuit breaked box is outside on the house. I am wondering if mositure got in it. It should have dried by now though
  6. Nov 23, 2010 at 3:32 PM
    DaCapt
    Phil
    Reno, Nevada
    yep, that would be a good reason it tripped. If this is the first time it has given you problems, then yes it was the power wash. Let it dry out on its own, or give it a blow dry, either using a compressor , or when its dry outside, you can use a hair dryer. Take the faceplate off before you try either method. Also might help to turn off that circuit, before you attempt to dry the outlet.
  7. Nov 23, 2010 at 3:35 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Sounds like ur equip has an issue
  8. Nov 23, 2010 at 3:37 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    A lot of times, the garage interior wall will reset the exterior outlets on the same circuit, so it could be related...
    I would give it a chance to 'dry out' and see it that takes care of it. In the future, you might want to tape over / seal the exterior outlets prior to another power wash.
  9. Nov 23, 2010 at 3:37 PM
    coffeesnob
    VA
    The gfi is in my garage and dry as a bone. I menat that the breaker box was outside.
  10. Nov 23, 2010 at 3:47 PM
    davidsdad
    davidsdad Well-Known Member
    Dave
    Grove City, Ohio
    Reg. Cab 4X4
    "Under Cover" Bed cover, 3" Suspension Lift, Sony stereo, 600w amp, Rockford Fosgate 12" sub, wheels, tires, (window tint coming soon).
    Unplug the poower strip and all other equipment on this circuit and then attempt to re-set the G.F.C.I. If then it resets you know one of the items plugged into this circuit is causing the ground fault!! Let us know how it turns out!!!
  11. Nov 23, 2010 at 3:49 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    the gfci outlet may be in your garage but it could control outlets on the outside. mine does in my house.
  12. Nov 24, 2010 at 5:17 AM
    coffeesnob
    VA
    Its still is tripping. If I get a chance I am going to the hardware store and buy a new outlet and go from there...thx
  13. Nov 24, 2010 at 5:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    I think you are wasting your time buying a new outlet. A GFI monitors the load on both sides (hot and common/neutral). A wet neutral line (or even ground since they are typically bonded at the box) could cause it to trip. And as others have said, an exterior outlet or the main box itself could have moisture in it which could take a few days to dry out. I'd say give it a week and see what happens. Pressure washing can force water into unwanted places.
  14. Nov 24, 2010 at 6:10 AM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    It's likely that the GFI is working correctly, and as someone else pointed out, one of the other exterior receptacles has faulted due to the power wash. Shack electricians will typically use one GFI to power several receptacles downline to save money. Check your exterior recepts before you buy a new GFI.
  15. Nov 24, 2010 at 6:22 AM
    WNYTACOMA
    Clarence, New York
    Yep.
    If you have a circuit fed by your service equipment ('main panel') on a grounded circuit, the GFCI outlet closer to the source (panel) will (or should) provide GFCI protection for the outlets farther away or 'downstream'.
    In other words, you don't have to see the little buttons on the outlet for them to be GFCI protected, and in your case, it sounds like the GFCI outlet closer to the panel is the one in the garage interior wall, whether it be on the garage / house common wall or possibly the rear wall. That one would 'reset' the exteriors, in all likelihood, in your case.
    Let it 'dry out' for some days and see if that takes care of it, otherwise, you might have to target the effected outlet.
  16. Nov 24, 2010 at 6:23 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I've had a similar issue. My GFCI in my garage was randomly tripping itself. It's connected to the 3 exterior outlets on my house also. The seals around the ext. outlets (between the plate and brick) weren't very good so I figured that maybe water was getting behind them when it rained. Two of the outlets are uncovered. Caulked a nice silicone seal around them and also around my back patio light fixture. Haven't had a problem since. (knock on wood)
  17. Nov 24, 2010 at 6:25 AM
    coffeesnob
    VA
    I'll take that advice. I'll Give it a week and see what happens and thanks all. and happy thanksgiving
  18. Nov 24, 2010 at 6:26 AM
    macgyver
    Brad
    Canton, GA
    There's actually nothing wrong with using one GFCI to power multiple downline receptacles as long as you don't exceed the maximum wattage and amperage the breaker allows which by standard practice is around 80% of the breakers rating. Show me where in the NEC that says this is unacceptable?
  19. Nov 24, 2010 at 6:29 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    I had this problem when I bought my house a few years ago. Anytime it rained, my GFI tripped. Looked everywhere for an answer. Turned out the caulk around the lights on my back porch had a small hole in it and was letting water in. My house was built in '42 so all the GFI and exterior sockets are on one circuit. I never thought to look at the lights because they're not plugged in (hardwired).
  20. Nov 24, 2010 at 6:40 AM
    macgyver
    Brad
    Canton, GA
    Mine did their job last year. I had the christmas lights on the bushes plugged in and everytime my dog would pee on the bushes it will trip the circuit. A little bit of "liquid" on the circuit can trip it.
