Getting Motivx Oil wrench off filter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rasfetch, Apr 30, 2023.
  1. Apr 30, 2023 at 5:05 PM
    Rasfetch
    Rasfetch [OP] Member
    The dealer must've tighten the oil filter to at 70+ ft lbs of torque. I was able to use a breaker bar along with the Motivx wrench to finally get it free (barely). Now the Motivx wrench is completely stuck to the oil filter. I've reinstalled, hammered, jiggled, tightened, untightened, hammered, etc... and it is not coming off.
    Anyone have ideas?
    Could I just leave the wrench on and drive around until my next oil change and then take it in somewhere and have them deal with it? Or would oil leak out?
    I feel up a creek without a car until I can figure this out.
    Wondering if I just need to buy a whole new wrench and oil filter housing or whatever the part is called....
  2. Apr 30, 2023 at 5:17 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    Did you try using a long extension and wiggle the extension side to side and back and forth while the housing is installed? A long extension should give some leverage to gain a little bit of movement. Just a thought.
  3. Apr 30, 2023 at 5:21 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    Acetylene torch it.
  4. Apr 30, 2023 at 5:26 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    You could apply some careful heat with a heat gun. The aluminum filter wrench will expand quicker than the plastic.
  5. Apr 30, 2023 at 5:28 PM
    Foushee
    Foushee Well-Known Member
    Sean
    Texas
    2018 Inferno TRD OR DCSB MT
    Just getting started.
    Take a box wrench and use it to bang the side of the Motivx to loosen the filter housing. Works like a charm on stuck router collets, and I've done it before with the Motivx before switching to a metal housing.
  6. Apr 30, 2023 at 5:33 PM
    eurowner
    eurowner Duke Sky
    Scoty
    The plastic filter housings have a ton of seal drag. Use a 1/2” breaker bar and slowly with even pressure unthread. 3/8” ratchets are not stiff enough.
    I torque my plastic filter housing and it’s a bitch you thread with my 24” long 1/2” breaker bar.
    3JOH22A likes this.
  7. Apr 30, 2023 at 5:40 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i used an impact gun.
  8. Apr 30, 2023 at 5:57 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Try just dropping it so the wrench hits the ground first. Try from a few heights.
  9. Apr 30, 2023 at 6:14 PM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I had this problem on a Hazet 2169 filter wrench cup that I used for German cars. I tightened the filter back onto the housing and was able to gently rock it back and fourth. Eventually it would pop off.
    I have the older version of the Motivx Toyota tool and between the old Camry and current 3rd gens haven't seemed to have gotten it stuck. Watch, next time I will... :laugh:
  10. Apr 30, 2023 at 6:15 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Oil/lubercate the housing.
    Rasfetch[OP] likes this.
  11. Apr 30, 2023 at 6:18 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Spray the wrench with WD 40 then wait a little and try to wiggle it off
  12. Apr 30, 2023 at 7:07 PM
    Rasfetch
    I had tried this a few times and it didn't work, but I poured some oil around the filter wrench and then let it sit for an hour in hopes that gravity would help it seep in. Put the oil filter back on, wiggled quite a bit with the breaker bar again and it loosened up that time and was able to get the wrench off.
    Not sure if the oil helped or not, but it couldn't have hurt...
    Thanks everyone for the help!
    DTaco18[QUOTED] and 3JOH22A like this.
  13. Apr 30, 2023 at 7:09 PM
    Rasfetch
    This worked. Oiled it and let it sit for an hour. Put it back on and wiggled with the breaker bar and it came off
  14. Apr 30, 2023 at 7:11 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    My next suggestion was to offer chicken innards as a sacrifice to the gods on your exhaust manifold.
    Rasfetch[QUOTED][OP] likes this.
  15. Apr 30, 2023 at 7:12 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Most of life's problems can be solved with a little lubricant!
    willtill likes this.
  16. May 1, 2023 at 3:48 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    or...
