Getting Google maps to work on the truck from cellphone?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tractorfarmer123, Mar 9, 2021.
  1. Mar 9, 2021 at 2:16 PM
    tractorfarmer123
    tractorfarmer123 [OP] Well-Known Member
    2020 Tacoma
    Does the phone need to be plugged into the USB to make Google maps show up on the screen? When I start the truck my phone vibrates and it says its connected with bluetooth. And my contact list shows up, but I can't get the map to work.
    Ngneer likes this.
  2. Mar 9, 2021 at 2:23 PM
    branden21
    branden21 Active Member
    2021 Barcelona Red Tacoma TRD Off-road
    If it says it's connected through Bluetooth then it isn't connected via Android Auto. You can try selecting Android Auto as the source and then you just click the map button on the dash and it should work. A few things I had to try were having a good quality USB cord (first one I tried to use didn't work, second and newer one was much better) and I had to plug it into the USB right below the instrument panel and not the one in the center console.
  3. Mar 9, 2021 at 2:24 PM
    tractorfarmer123
    2020 Tacoma
    Ok. So it has to be plugged into the USB to get the maps to work from the phone? Or if I go into Android Auto can I get it to work without the plug?
    Ngneer likes this.
  4. Mar 9, 2021 at 2:25 PM
    branden21
    It has to be plugged in to use the maps unfortunately. I wish so much that it could connect maps through Bluetooth.
  5. Mar 9, 2021 at 2:28 PM
    Vo0Do0
    Vo0Do0 Well-Known Member
    2020 VooDoo Blue Tacoma TRD Off-Road
    Yes, you either need to use Carplay or Android Auto.. both of which needs to have a physical connection to the head unit via the front USB port (Only port that has data).
    While BOTH iPhone and Android had the ability to do Wireless connection at the time (2020 model year) Toyota decided NOT to support that feature.
    tractorfarmer123[OP] likes this.
  6. Mar 9, 2021 at 2:44 PM
    tractorfarmer123
    2020 Tacoma
    Ok. Thanks. That saves me from having to read the book. I am trying to keep it shrink wrapped so if I sell the truck the books will look nice.
    Ngneer likes this.
  7. Mar 9, 2021 at 2:44 PM
    tractorfarmer123
    2020 Tacoma
    Thank you for responding.
    Ngneer likes this.
  8. Mar 9, 2021 at 2:45 PM
    Vo0Do0
    This also assumes you have a 2020+ Tacoma, 2019 and older did not have this ability.
  9. Mar 9, 2021 at 4:49 PM
    TacoSRSX
    TacoSRSX Well-Known Member
    Martin
    Ventura County / San Fernando Valley - CA
    2021 MGM SR 2.7 2WD SX
    Ionic Pro 4" tube steps Desert Does-it Seat Jackers ECT PWR always on Kicker Tweeters replacement Tyger roll-up vinyl cover Bed mat
    If you login to the Toyota app. It has a pdf version of the owners manual there so no need to open your physical copy.
  10. Mar 9, 2021 at 7:29 PM
    tractorfarmer123
    2020 Tacoma
    Ok. Thanks.
  11. Mar 9, 2021 at 8:10 PM
    MilkDud
    MilkDud Well-Known Member
    2021 MT DCSB Off-Road
    apparently, there is a mod/USB plug-in that can have your phone connect via Bluetooth and carplay, no cord. I run android, so it doesn't apply for me. If you have Apple, you may want to look into it.
  12. Mar 10, 2021 at 1:47 AM
    tractorfarmer123
    2020 Tacoma
    https://www.androidpolice.com/2020/...ring-android-auto-wireless-to-almost-any-car/ If that works then you could keep the phone in the center console pulled into the USB there. That is what I want.
    MilkDud[QUOTED] likes this.
  13. Mar 10, 2021 at 5:09 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    They make wireless adapters for Apple Carplay. I'm running CPLAY2Air in my 2020.
  14. Mar 10, 2021 at 5:43 AM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    A few of us purchased the AAWireless device from the IndieGoGo campaign. I don't believe anyone has received theirs yet, but the first batch of orders are finally starting to ship. There was some info in this thread, but it hasn't been updated in a few months.
    https://www.tacomaworld.com/threads/plug-n-play-wireless-androidauto.683867/
  15. Mar 10, 2021 at 6:09 PM
    tractorfarmer123
    2020 Tacoma
