Getting front skid plate only makes sense? Or do I need to get all?
Discussion in 'Armor' started by takoashihaisen, Nov 10, 2017.
  1. Nov 10, 2017 at 10:22 PM
    takoashihaisen
    takoashihaisen [OP] Well-Known Member
    island, WA
    2015 AC 4X4 4cyl M/T SR MGM
    successfully installed 3 windshield cracks
    When I go off-roading, I mostly explore forest service roads, nothing too serious. Having said that, I have had several occasions I could hear scraping sound from the underneath of my Tacoma. Since Black Friday is coming soon, I am considering to invest some $ for the skid plate(s).
    1. Is the front skid plate most critical element among three (front, middle, read) skid plates? I guess it is best to have all three, but since my budget is tight, I would like to know if getting the front skid plate only makes sense.
    2. Since I do not do serious off-roading and my Tacoma is 2.7L, I am thinking of getting aluminum (front) skid plate. Any vender recommendations?
    Thanks
  2. Nov 10, 2017 at 10:45 PM
    openspace4x4
    openspace4x4 Well-Known Member
    SF Bay Area
    2017 TRD OR DCSB
    OV Tune
    Hey man, I am not a big off roader either, sounds like we are about the same level.
    I agree that the front skid makes the most sense. If you hit something hard that is where it will be.You could always back off if needed.
    I went 1/4" aluminum form RCI since it is lighter than steel. Apparently steel lets you slide easier over rocks but I don't plan to do that. I got mine from them powder coated and am very happy with it. Installation was very easy.
  3. Nov 11, 2017 at 12:12 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    You definitley need a front skid, yes. Most critical. If you could only get one out of the two others, get the t-case skid
    Ideally, get the big 3 (IFS, transmission and t-case). Or go all out and get the gas tank and rear diff skids, too.
    For minor/moderate offroading the stock skid is fine. I beat the hell out of mine before I finally upgraded it. It looked like a crushed tin can but it served its purpose. The tcase skid though was aftermarket and it saved my ass more than a few times....no tcase, no getting home (if you're deep into a remote 4x4 trail).
    takoashihaisen[OP] likes this.
  4. Nov 11, 2017 at 12:15 AM
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    Imo sliders then front skid.
    But if you're up for smashing into stuff, front skid first.
    Go aluminum and get them bare to save money. If you want to paint it, rattle can it. Powder coat is way overated. Again, my opinion but it's going to scrape off on armor then moisture gets under it and rust grows without you seeing it.
    Leonel and takoashihaisen[OP] like this.
  5. Nov 11, 2017 at 12:18 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Unless you're going hardcore, which it doesn't sound like you are, get an aluminum front and be happy! The front and aluminum is more than enough for the average off roader.
    I like my MobTown set, granted they're steel, all three and I've bashed them a good amount sliding over things I couldn't clear. :rolleyes:
    Honestly though the only reason I went for all three and steel is I got a screaming deal on a set 2nd hand.
  6. Nov 11, 2017 at 7:27 AM
    takoashihaisen
    island, WA
    Guys,
    Thank you so much for your suggestions. Now I have to justify and convince my wife the purchase of a front skid plate. I got my sliders last year and that was easy to convince her. I said they would work as your steps. Not sure about the skid plate. Maybe improves the aerodynamics and better milaege?:D
    I will get a front skid first and see if I need a mid/rear skid later. If I recall correctly, MobTown only makes an aluminum front skid for my Tacoma 2015, SR, AC. I believe SOS, where I got my sliders, makes only steel skids. I do not know much about RCI, but I will check them out after off-roading today.
    I still have left over primer/paint that I used for my sliders. If I decide to paint, I will use them.
    :burnrubber:
    Stig likes this.
  7. Nov 11, 2017 at 7:48 AM
    Stig
    Brandon
    Ta no mo
    RCI ftw, great quality products and my sliders and skids are from them.
    I left the front aluminum one bare and it looks great.
    Thunder Fist likes this.
  8. Nov 11, 2017 at 7:55 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  9. Nov 11, 2017 at 7:55 AM
    takoashihaisen
    island, WA
    Thanks aero3685. Just found out RCI is located in CO, not too far from WA. I maybe able to save some shipping charge.
  10. Nov 13, 2017 at 6:45 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I like Pelfreybilt aluminum skids. I do a good bit of off roading. Still went aluminum and have not regretted that. I have aluminum plate bumper and full 3 piece skids. Better safe than sorry....
  11. Jan 3, 2018 at 7:37 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Anyone know of any sales going on? I need a front skid too.
  12. Jan 3, 2018 at 7:40 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    @Mobtown Offroad was doing a 15% off christmas sale. Not sure if it ended.
    Thunder Fist[QUOTED] likes this.
  13. Jan 3, 2018 at 8:16 AM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    It's ova
    EatSleepTacos[QUOTED] likes this.
  14. Jan 3, 2018 at 2:17 PM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    I think I saw where Pelfreybilt has a 20% off sale going on. You might ask them.
