gen 3 tacoma iPad Dash install
Discussion in 'Audio & Video' started by pjason23, Jan 16, 2023.
  1. Jan 16, 2023 at 3:35 PM
    pjason23
    pjason23 [OP] Active Member
    Phillip
    Alhambra
    2020 Taco TRD-Off Road 4x4 DBL Long Bed
    TRD Pro Grill TRD Raptor Lights Cali Raised LED Combo Spot/Flood LED bar & dual 27W Ditch Lights Black Rims Control Arm Lift 6’ Full Interior LED Light Upgrade Xeon Headlamp Bulbs Bakflip X4S2 Bed Cover Pedal Commander Fullly Upgraded 3 way active sounds system Arc Audio PS8 Pro & PSC controller Arc Audio X2450.4 amps x 2 Chanel 3/4 control mid and tweeter, Channel 1 &2 Bridged to Door speakers AudioFrog GS60 Door Mount, GS25 & GS10 in Custom Aluminum Pods Sound Deadining in doors by SOUND SKINZ Noico 80 mil & Noico loses Cell foam in the rest of the vehicle JL Audio 10 TW3-D4 x 2 wired to 1 oHm Audison S500.1 Amplifier Custom behind seat subwoOfer Boxes/ amp rack Custom Amp rack under rear seats Custom switches Performance Mods
    Has anyone done this mod?
    If so was it with an 11" iPad or 12.9" or the mini
    I wanted to do my 12.9" M1 iPad Pro with 5G as my head unit.
  2. Jan 16, 2023 at 3:56 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    That seems like such a waste of such an expensive and powerful piece of tech
    what’s your plan with it? I’ve seen people try and struggle to make iPads work well for all the functions they want
  3. Jan 16, 2023 at 5:29 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    imo, an ipad is a terrible choice for a 'head unit'. almost zero integration options, all one really does is just get a headphone out to the amps and charger input. but everything else needs to be bluetooth, like for obd2, which can be flakey at times.
  4. Jan 16, 2023 at 5:57 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Yeah unless you know something I don’t know, you’ll lose things like
    backup cam
    Steering wheel controls
    All of the settings the factory unit controls (door locks, lights, etc)
    Fade/balance
    Factory mic
    probably more I’m forgetting
  5. Jan 16, 2023 at 6:04 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Look into Android HU’s.
  6. Jan 16, 2023 at 7:27 PM
    soundman98
    NW Indiana
    fade/balance could be easily added back in with a DSP, which is usually needed anyways for the eq, as tablets don't normally have much of one.
    oh, and steering wheel controls got me curious.
    circa 2014, carstereochick.com has an article about a $500 module to add that in on top of a idata maestro controller
    https://carstereochick.com/2014/10/09/ipad-car-stereo-steering-wheel-control-solution-is-here/
    i want to say there's also a way to get reverse camera integrated as well, but just like adding steering wheel controls for the cost of a head unit, it wouldn't be cheap either!
  7. Jan 19, 2023 at 6:40 AM
    HookItUp7
    HookItUp7 Active Member
    Omaha NE
    I installed an Ipad mini in my 2nd gen. I recommend installing a head unit hidden somewhere that you can connect the ipad to through usb. I used a mechless single din kenwood. this way you easily keep steering wheel controls and bt. Hooking up amps is easier and cleaner too. Plus the system sounds great using kenwoods dac.
  8. Jan 20, 2023 at 9:41 AM
    ExplorHer
    ExplorHer Question Authority
    Near Pittsburgh
    2016 4cyl, 5MT, 4x4, 2 seats, dents, & rust
    Have you heard of this guy? He make iPad dash kits and has videos on youtube.
    https://soundman.co/
  9. Jan 22, 2023 at 7:14 AM
    soundman98
    NW Indiana
    i can't believe he's still doing it. he popped up in search results a number of times in carpc stuff back when an ipad in the dash was a more revolutionary concept back in 2009-ish--used to know a few guy's running those dash kits, and then into an audison bitone when they were one of the few dsp's on the market. been doing it a long time, his stuff is quality built.
    *note, i'm not affiliated with him in any regard. but i'm about to buy a t-shirt for the novelty.
