Gen 3 - gear ratios in the manual tranny look better for towing.
Discussion in 'Towing' started by n1as, May 5, 2018.
  1. May 5, 2018 at 9:16 AM
    n1as
    n1as [OP] Well-Known Member
    2016 Tacoma DCSB TRD OR
    Comparing some specs 4x4 AT vs MT, the AT has bigger jumps from 3 through 6, and a taller final drive ratio. Unless there is some torque converter slip magic happening, the MT would give you closer spacing in the top gears and higher overall RPMs for more gear choices and overall better towing heading down the road.
    Here are the final ratios for gears 1-6 given 4.30 rear end in the manual and 3.909 in the auto.
    MT AT
    1st: 17.114 14.04
    2nd: 8.686 8.151
    3rd: 5.676 5.811
    4th: 4.3 3.9
    5th: 3.655 2.691
    6th: 3.053 2.262
    Thoughts?
  2. May 25, 2018 at 7:54 PM
    n1as
    Don't all weigh in at once, now! :)
  3. May 25, 2018 at 8:19 PM
    Bowers86
    Bowers86 Well-Known Member
    Vancouver, WA
    2013 RC 2WD 5-speed
    Access Cab Buckets, OE backup cam, AFE Air Filter/Secondary filter removed/Fender Elbow removed, Magnaflow 11225, XII springs/4x4 leafs/XR Bilsteins, Prodigy P3 brake controller, 3.73 Third, Undercover Tonneau, Koomus CD slot iPhone mount, Paint matched rear bumper, Drag 18x9 et20 wheels, 3rd Gen Airdam.
    I think the takeaway is 4.3 swap the auto! :p
    1st: 17.114 14.04 15.48
    2nd: 8.686 8.151 8.987
    3rd: 5.676 5.811 6.407
    4th: 4.3 3.9 4.3
    5th: 3.655 2.691 2.967
    6th: 3.053 2.262 2.494
  4. May 26, 2018 at 7:42 AM
    n1as
    4.3 swap the auto? Sorry I don't follow. Is that 3rd column of numbers for a different auto tranny?
  5. May 26, 2018 at 7:53 AM
    Bowers86
    Vancouver, WA
    2013 RC 2WD 5-speed
    No, swap a 4.3 third member into the auto.
  6. May 26, 2018 at 8:05 AM
    n1as
    Ah re-gear the diffs. Got it. That still leaves you with a larger jump gear splits from 3rd through 6th for the AT. The MT is closer ratio and will give you finer control.
    And we're saying that a stock truck with MT will give higher highway RPMs than AT that has been re-geared? I'm feeling better about towing with my MT all the time :)
    02Duck likes this.
  7. May 26, 2018 at 9:46 AM
    Bowers86
    Vancouver, WA
    2013 RC 2WD 5-speed
    Well depending on weight or grade you won’t be past 4th gear so may not be too bad of an issue anyways. Plus autos always have the advantage of hillstarts, which feels terrible on your clutch. But for everything else or lighter loads, yeah I’ll stick with my manual.
  8. May 26, 2018 at 10:24 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    I've been happy with the gear ratio in my 2nd gen manual transmission for the same reason, better ratios for towing. Also no worries about overheating transmission fluid in a manual.
    For hill starts if you're worried about that, use the handbrake.
  9. May 27, 2018 at 7:32 AM
    n1as
    I finally got a chance to do a quick shake-down tow with the manual transmission. Pulled my 4000 lb travel trailer on the freeway through the hills south of town. The freeway on-ramp is a long uphill grade (city street that turns into an on-ramp). On the steepest part of the hill, I ran WOT in 3rd turning around 3000 RPMS. I hit the bottom of the hill doing about 45 and was doing 60 by the time I merged into light traffic at the top, which is great. On the other hills I was in 4th holding 60 and gaining speed in 3rd. On the flats the rig towed just fine in 6th gear at 60 to 65. I did have to anticipate the hills, though. I needed to downshift before the rig began to slow or else I'd lose 5 mph very quickly.
    evansdmax and Bowers86 like this.
  10. May 27, 2018 at 6:25 PM
    evansdmax
    evansdmax Well-Known Member
    Evan
    Western NC
    2017 TRD OR BBP 6 SPEED MT
    Very nice info....I’m debating between Tacoma or a bigger truck now for getting camper
  11. May 27, 2018 at 7:01 PM
    n1as
    How big of a camper? What sort of camper? The Tacoma seems well suited to tent campers and small to medium size travel trailers (~4500 lbs or less) but I think it is not really enough truck if you're over that.
    tacoguy88 likes this.
  12. May 28, 2018 at 3:43 AM
    evansdmax
    Evan
    Western NC
    Probably in the 35-4500 range. Small 18-22’ maybe slideout. Maybe a hybrid with popout ends? Can’t decoded just like I can’t decide on a truck. I’m goin to look at a truck tomorrow it’s a 17 model trd off road with 6 speed. 7k miles salvage title.
  13. Jun 5, 2018 at 9:28 PM
    n1as
    I just pulled my 3900 lb (dry weight) camper over the coastal mountain range (750 foot summit - big whoop) and back for a camping weekend at the OR coast. In the hills, the Taco definitely had to work to keep speed. Steepest hill had me in 3rd running 3000 rpms for 40 mph. But it did it.
    On the flats I could easily drive in 6th.
    MPG on the way out was 11.5. On the way back was 13.1. 150 Miles total. I was pleasantly surprised my the MPG; I expected 10. I wonder if perhaps the MT is more fuel efficient than the AT when running 40 to 60?
    Bowers86 likes this.
  14. Jun 8, 2018 at 1:39 AM
    TacoTrooper
    TacoTrooper Well-Known Member
    James
    Vancouver, Canada
    2013 TRD Double Cab 6-spd manual
    2013 TRD Sport DCSB 6-spd manual
    I too was surprised by the fuel economy when towing, expecting much worse than reality. Being a Canadian, my numbers are in L/100K, which is typically 14.5 ish, mostly city driving. When I head out for a road trip, which is usually hilly terrain around here, I would get 11-12 L/100km. Towing a 3400lb Rpod same conditions I am getting 18L/100km. Not great by any stretch, but really not nearly as bad as I had thought it would be.
    Tomorrow I'm heading out for 9 days camping trip with 3 stops. I'll see how she does this go.
    2013 6spd Manual
