Gauge cluster replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rwheeler, Dec 15, 2022.
  1. Dec 15, 2022 at 7:22 AM
    Rwheeler
    Rwheeler [OP] New Member
    2000 tacoma base double cab 2.4 L sr5
    None
    I have a base 2000 tacoma 2.4 sr5 extra cab long bed. My gauge cluster has no tachometer or trip odometer. By the way the odometer I have is not digital.
    I was wondering if anyone knows much about swapping out compatible gauge clusters that have tachometer and trip odometer. Any advice would be appreciated Thanks Ralph
  2. Dec 15, 2022 at 7:48 AM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    Get a scanguage. Lots less hassle and you can read CEL codes. Saw it here in forums, read up and rigged a way to mount it below ash tray. Spikerengineering also offers a mount for drivers side window brace at oh crap handle.
    808BOGEYMAN likes this.
  3. Dec 15, 2022 at 10:28 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    It's possible. Theres a few wires that need to be switched or added to the D plug on cluster. Just find one without digital odometer and doesn't use a speedo cable. Assuming yours doesn't have a speedo cable.
  4. Dec 15, 2022 at 11:11 AM
    Sfish2002
    Sfish2002 Well-Known Member
    Stanley
    2003 2wd M/T regular cab Tacoma
    Topper w/racks, bug/rock shield, hood thermal mat, bed liner, hitch
    I have almost the same situation. The dealer broke my lens and as the part is out of production all they did was give me $50 to replace a part that can’t be found. Very annoying. Thanks Mueller Toyota.
    My temp gauge broke years ago and i put in a scan gauge and it is great (just plugs into the OBD 2 outlet). It even lets me reset the P0136 code every time it comes up! It’s worth the investment and additional data that you get when you don’t have a tach or other useful gauges (including instantaneous and avg gas mileage, rpm, coolant temp, inlet air temp, and numerous other bits of interesting data).
    Please let us know how you solve this as I’d be interested to have a new lens and possibly gauge if the price is right.
    Good luck.
  5. Dec 16, 2022 at 5:59 PM
    WTORRES141
    WTORRES141 Active Member
    2004 Tacoma std cab
