Gas theft prevention
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ComaChameleon, Aug 15, 2024.
  1. Aug 15, 2024 at 1:00 PM
    ComaChameleon
    ComaChameleon [OP] 2008 Tacoma TRD
    Karla
    2008 Tacoma TRD
    Siderails
    Theves drilled my gas tank.
    How do I prevent it from happening again? (Already moved parking location)
    Is there a gaurd I can get installed?
    Thanks in advance for any help.
    TegoTaco and TacoSR523 like this.
  2. Aug 15, 2024 at 1:47 PM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    i dunno, doesn't seem like theres much you can do if someone is willing to drill aside from keeping the truck in a more secure location. even a steel skid plate wouldn't offer much resistance to someone with a drill. people suck :(
    edit: also, that's a rough first post. but welcome to TW anyway!
    Jakerou, Knudsen and Sandman614 like this.
  3. Aug 15, 2024 at 1:48 PM
    ucdbiendog
    Reno, NV
    2014 DCSB TRD OR
    StihlToyota and Knudsen like this.
  4. Aug 15, 2024 at 1:51 PM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    2023 TRD OR
    Crazy someone would want to steal like thirty bucks in fuel that bad
    ucdbiendog likes this.
  5. Aug 15, 2024 at 1:53 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    Pretty hard problem. Very large area to try to protect. 1/4" AR500 (hardened) steel would discourage the casual driller but probably cost about $1,000 in materials + fabrication costs, plus adding 25-30 lbs of weight.
    I'm trying to think what I would do if I had no alternative parking location. The only thing that comes to mind is coating the entire bottom half of tank with some kind of gummy epoxy putty that could be embedded with a mix of steel + kevlar wires & threads, to try to jam up a drill bit. With a layer of ceramic floor tiles under that.
  6. Aug 15, 2024 at 1:53 PM
    545 Well-Known Member
    2015 Access Cab
    Skid plates really only protect from the bottom, still pretty easy to get at it from the side
    Garage is about it
  7. Aug 15, 2024 at 1:58 PM
    GilbertOz
    GilbertOz Driver
    CA
    Actually, if there was a way to securely glue 1/4" thick ceramic floor tiles to the tank, that alone would slow down a casual driller. Ceramic is impossible to drill with any normal drill bit. But the problem would be how to get the tiles really permanently bonded to either the bottom of the tank, or the bottom of the plastic tank skid-guard. Polyethylene is pretty hard to bond anything to.
    Wouldn't be good to be occasionally shedding ceramic tiles, no matter how small, out from under the truck at highway speeds.
  8. Aug 15, 2024 at 2:27 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    They had fuel thief’s in mad max. What was their solution?
    Overlandin likes this.
  9. Aug 15, 2024 at 2:31 PM
    02hilux
    Planet: EARTH
    Have a good insurance company. There’s nothing you can do, even with a steel skid plate, they will drilled through it if they want it that bad.
  10. Aug 15, 2024 at 2:35 PM
    yujemas
    yujemas Active Member
    James
    Brooklyn
    2013 Prerunner TRD OR
    Scum of the earth
  11. Aug 15, 2024 at 2:49 PM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    Man, I would be afraid of the drill motor igniting the fuel as it just started to drip from the tank onto the drill. Gotta be really desperate to do something like this, and it’s not like they’re going to sell it. It probably when into their car.
  12. Aug 15, 2024 at 3:13 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Nothing you can do really,too bad you don't have a garage.
  13. Aug 15, 2024 at 3:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
